查看: 933|回復(fù): 0
單片機(jī)音樂
ID:436032 發(fā)表于 2018-11-29 20:19 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
[文件名]  C51音樂程序(生日快樂)
[功能]    通過單片機(jī)演奏音樂
#include <REG52.H>
#include <INTRINS.H>
//本例采用89C52, 晶振為12MHZ
//關(guān)于如何編制音樂代碼, 其實(shí)十分簡單,各位可以看以下代碼.
//頻率常數(shù)即音樂術(shù)語中的音調(diào),而節(jié)拍常數(shù)即音樂術(shù)語中的多少拍;
//所以拿出譜子, 試探編吧!
sbit Beep =  P1^5;
//unsigned char n=0; //n為節(jié)拍常數(shù)變量
unsigned char TimeH0,TimeL0; //定時器初值
unsigned char code music_tab1[] ={    //格式為: 頻率常數(shù)+節(jié)拍常數(shù)
0x83,0X81,0X94,0X84,0XB4,0XA4,0X04,
0x83,0X81,0X94,0X84,0XC4,0XB4,0X04,
0x83,0X81,0XF4,0XD4,0XB4,0XA4,0X94,
0XE3,0XE1,0XD4,0XB4,0XC4,0XB4,0X04,
0XE3,0XE1,0XD4,0XB4,0XC4,0XB4,0X04,0X00
unsigned int  music_tab2[] ={    //定時器初值
64260,64400,64524,64580,64684,64777,64820,64898,
       64968,65030,65058,65110,65157,65178,65217
unsigned int code music_tab2[] =    //定時器初值低音Do到高音Ti
{   63628,63835,64021,64103,64260,64400,64524,64580,64684,64777,
64820,64898,64968,65030,65058,65110,65157,65178,65217,65252,65283};
void int0()  interrupt 1   //采用中斷0 控制節(jié)拍
   TH0=TimeH0;
   TL0=TimeL0;
   Beep=~Beep;
* 函 數(shù) 名:Delay20ms(u8 y)
* 函數(shù)功能:延時20ms
* 輸    入:y
* 輸    出:無
void Delay20ms(unsigned char y)
unsigned int x;
for( ; y>0; y--)
  for(x=20000;x>0;x--);
void time0_init(void)
TMOD&=0xf0;
TMOD|=0x01;
IE=0x82;
TimeH0 = 0xff;
TimeL0 = 0x00;
TR0=0;
unsigned char p,temp;   //m為頻率常數(shù)變量
unsigned char i=0;
unsigned int time0;
unsigned char t;
time0_init();
  p=music_tab1[i];
     if(p==0x00)
   {   //如果碰到結(jié)束符,延時1秒,回到開始再來一遍
   i=0;
   TR0=0;
   Delay20ms(10);
   temp=p;
   temp=temp>>4;
   temp=temp &0x0f;
   if(temp==0)
    TR0=0;
    time0 = music_tab2[temp-1];
    TimeH0 = time0/256;
    TimeL0 = time0%256;
    TH0=TimeH0;
    TL0=TimeL0;
    TR0=1;
   t = p;
   t &= 0x0f;
   Delay20ms(t);
   i++;
