#include "iom48v.h"
#include "macros.h"
#define KEY_Press keycode!=0x00
#pragma interrupt_handler T1_refresh: 12
void delay(uint a)
while(a--);
const uchar disp[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,
0x80,0x90,0x88,0x83,0xA7,0xA1,0x86,0x8E};
uchar segcode[4]={0XFF,0XFF,0XFF,0XFF}; //段碼 (存放譯碼值)
uchar data[4]; //顯示數(shù)據(jù)
uchar keycode; //判斷按鍵位置
uchar n=0; //顯示刷新標(biāo)志
uchar key=0; //鍵值 PINB!=0X0F
uchar digit=0;
/***IO口初始化函數(shù)***/
void IO_Init(void)
DDRB = 0xF0;
PORTB = 0x0F; //上拉
DDRC = 0xFF;
PORTC = 0xFF;
DDRD = 0xFF;
PORTD = 0xFF;
/***定時(shí)器T1初始化***/
void T1_Init(void)
TCCR1A = 0x00; //CTC
TCCR1B = 0x0B; // 64分頻
OCR1A = 78; // 5ms
TIFR1 = 0x02;
TIMSK1 = 0X02; //開中斷
/***定時(shí)器T1中斷服務(wù)---數(shù)據(jù)刷新***/
void T1_refresh(void)
n=(++n)%4;
//PORTC |=0X0F; //關(guān)閉位選(必須)
PORTC =0X0F;
PORTD = segcode[n]; //傳送數(shù)據(jù)位
switch(n)
case 0: PORTC = ~0x01; //顯示千位
break;
case 1: PORTC = ~0x02;
break; //顯示百位
case 2: PORTC = ~0x04;
break; //顯示十位
case 3: PORTC = ~0x08;
break; //顯示個(gè)位
default: break;
TIFR1 = 0X02; //清標(biāo)志
/***譯碼函數(shù)***/
void decode(uchar *num)
if(digit==1)
segcode[3]=disp[num[3]];
else if(digit==2)
segcode[2]=disp[num[2]];
else if(digit==3)
segcode[1]=disp[num[1]];
else if(digit>3)
segcode[3]=disp[num[3]]; //個(gè)位
segcode[2]=disp[num[2]]; //十位
segcode[1]=disp[num[1]]; //百位
segcode[0]=disp[num[0]]; //千位
// segcode[0] &= ~0x80; // 加小數(shù)點(diǎn)
/***輸入移位函數(shù)***/
void Digit_Move(uchar *b)
uchar i,j;
for(i=0;i<3;i++)
b[i]=b[i+1];
b[3]=key;
/***按鍵掃描及數(shù)據(jù)處理***/
void KEY_Scan(void)
//keycode = (~PINB)&0X0F; //記錄按鍵在第幾行
PORTB = ~0X10; //掃描第一列
delay(10);
while(PINB!=~0X10); //等待按鍵釋放(消抖)
//delay(20000);
switch(keycode) //讀取鍵值
case 0X01: key=0; Digit_Move(data); digit++;decode(data);break;
case 0X02: key=1; Digit_Move(data); digit++;decode(data);break;
case 0X04: key=2; Digit_Move(data); digit++;decode(data);break;
case 0X08: key=3; Digit_Move(data); digit++;decode(data);break;
default:break;
PORTB = ~0X20;delay(10);
keycode = (~PINB) & 0X0F;
while(PINB!=~0X20);
//delay(20000);
switch(keycode)
case 0X01: key=4; Digit_Move(data); digit++;decode(data);break;
case 0X02: key=5; Digit_Move(data); digit++;decode(data);break;
case 0X04: key=6; Digit_Move(data); digit++;decode(data);break;
case 0X08: key=7; Digit_Move(data); digit++;decode(data);break;
default:break;
PORTB = ~0X40;delay(10);
while(PINB!=~0X40);
//delay(20000);
switch(keycode)
case 0X01: key=8; Digit_Move(data); digit++;decode(data);break;
case 0X02: key=9; Digit_Move(data); digit++;decode(data);break;
case 0X04: key=10;Digit_Move(data); digit++;decode(data);break;
case 0X08: key=11;Digit_Move(data); digit++;decode(data);break;
default:break;
PORTB = ~0X80;delay(10);
while(PINB!=~0X80);
//delay(20000);
switch(keycode)
case 0X01: key=12;Digit_Move(data); digit++;decode(data);break;
case 0X02: key=13;Digit_Move(data); digit++;decode(data);break;
case 0X04: key=14;Digit_Move(data); digit++;decode(data);break;
case 0X08: key=15;Digit_Move(data); digit++;decode(data);break;
default:break;
/***主函數(shù)***/
void main(void)
CLI();
IO_Init();
T1_Init() ;
SEI();
PORTB = 0X0F;
if(KEY_Press) //檢測(cè)按鍵是否按下
KEY_Scan();
delay(30000);
/*void delay(uint ms)
uint i,j;
for(i=0;i<ms;i++)
for(j=0;j<1141;j++);
