查看: 2954|回復(fù): 4
請問,如何用stm32通過串口調(diào)試助手控制燈的亮滅?
ID:435050 發(fā)表于 2018-11-28 15:54 | 顯示全部樓層 |閱讀模式
大家有沒有源碼可以分享
ID:303383 發(fā)表于 2018-11-28 16:54 | 顯示全部樓層
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:308437 發(fā)表于 2018-11-29 09:07 | 顯示全部樓層
用正點原子的歷程,直接可以使用。具體你去官方論壇看下(開源電子網(wǎng))(不做伸手黨)
ID:437134 發(fā)表于 2018-12-1 14:41 | 顯示全部樓層
1.串口配置;2.串口中斷接收;3.通過串口數(shù)據(jù)判斷是否點亮led
ID:436509 發(fā)表于 2018-12-1 16:29 | 顯示全部樓層
#include "main.h"
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
#include "lcd.h"
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  /* USER CODE BEGIN 2 */
        Lcd_Init();
        Lcd_Clear(WHITE);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
        Gui_DrawFont_GBK16(0, 0, BLACK, WHITE, "LED1 OFF");
        Gui_DrawFont_GBK16(0, 25, BLACK, WHITE, "LED2 OFF");
        Gui_DrawFont_GBK16(0, 50, BLACK, WHITE, "LED3 OFF");
        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
                uint8_t data = 0;
                HAL_UART_Receive_IT(&huart1, &data, 1);
                if(data == '1')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_RESET);
                        HAL_UART_Transmit(&huart1, &data, 1, 0);
                        Gui_DrawFont_GBK16(0, 0, BLACK, WHITE, "LED1  ON");
                        //HAL_Delay(500);
                else if(data == '2')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0, GPIO_PIN_SET);
                        //HAL_Delay(500);
                else if(data == '3')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_1, GPIO_PIN_RESET);
                        Gui_DrawFont_GBK16(0, 25, BLACK, WHITE, "LED2  ON");
                        //HAL_Delay(500);
                else if(data == '4')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_1, GPIO_PIN_SET);
                        //HAL_Delay(500);
                else if(data == '5')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_2, GPIO_PIN_RESET);
                        Gui_DrawFont_GBK16(0, 50, BLACK, WHITE, "LED3  ON");
                        //HAL_Delay(500);
                else if(data == '6')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_2, GPIO_PIN_SET);
                        //HAL_Delay(500);
  /* USER CODE END 3 */
作者:烏云的暮年下著雪
來源:CSDN
原文:https://blog.csdn.net/qq_40390825/article/details/80994900
版權(quán)聲明:本文為博主原創(chuàng)文章,轉(zhuǎn)載請附上博文鏈接!
