查看: 1302|回復(fù): 0
定時(shí)器數(shù)字時(shí)鐘文件
ID:434360 發(fā)表于 2018-11-27 17:26 | 顯示全部樓層 |閱讀模式
#include <REGX51.H>
#define u8 unsigned char
#define u16 unsigned int
u16 const table [10] = {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
u16 x;
u16 hour=0,m=0,s=0;
u16 n=0;
void delay_ms(u16 x)
u16 i,j;
for(;x>0;x--)
for(i=2;i>0;i--)
for(j=250;j>0;j--);
void display(u16 x,y)
P2=0xff;
P0=table[x/10];
P2=0xfe;
delay_ms(1);
P2=0xff;
P0=table[x];
P2=0xfd;
delay_ms(1);
P2=0xff;
P0=table[y/10];
P2=0xfb;
delay_ms(1);
P2=0xff;
P0=table[y];
P2=0xf7;
delay_ms(1);
TMOD=0x01;
TH0=(65536-50000)/256;  //50ms
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
  display (hour,m);
void timer_0 () interrupt 1
TH0=(65536-46083) / 256;
TL0=(65536-46083) % 256;
n++;
if(n == 20)
  s++;
  n=0;
if(s>59)
   m++;
   s = 0;
   if(m>59)
    hour++;
    m = 0;
    if(hour>23)
     hour = 0;
