查看: 1534|回復(fù): 0
如何實(shí)現(xiàn)LCD1602的顯示 求幫助
ID:431340 發(fā)表于 2018-11-25 22:26 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <LiquidCrystal_I2C.h> //引用I2C庫(kù)
LiquidCrystal_I2C lcd(0x27, 16, 2);//I2C設(shè)備地址、列數(shù),行數(shù)
unsigned long starttime;//計(jì)時(shí)開始時(shí)刻
unsigned long stoptime;//計(jì)時(shí)終止時(shí)刻
unsigned long looptime;//計(jì)時(shí)長(zhǎng)度
unsigned char k=0;//光標(biāo)初始位置
unsigned char Nowhour=12;//小時(shí)調(diào)整
unsigned char Nowminute=13;//分鐘調(diào)整
void setup() {
  // put your setup code here, to run once:
  lcd.init(); // 初始化LCD
  lcd.backlight(); //設(shè)置LCD背景燈亮
  starttime = millis();//上電計(jì)時(shí)開始(毫秒)
void loop() {
  // put your main code here, to run repeatedly:
  unsigned char Second, Hsecond, Lsecond, Minute, Hminute, Lminute, Hour, Hhour, Lhour;
  stoptime = millis();
  looptime = stoptime - starttime;
  Second = (looptime / 1000) % 60;//計(jì)算秒
  Hsecond = Second / 10;//秒的十位
  Lsecond = Second % 10;//秒的個(gè)位
  Minute = (Nowminute+(looptime / 1000) / 60) % 60;
  Hminute = Minute / 10;//分鐘的十位
  Lminute =Minute % 10;//分鐘的個(gè)位
  Hour = (Nowhour+(looptime / 1000) / 3600) % 24;
  Hhour = Hour / 10;//小時(shí)的十位
  Lhour = Hour% 10;//小時(shí)的個(gè)位
  Lcd_XianShi(k%16, 0, Hhour);//顯示小時(shí)的十位
  Lcd_XianShi((k+1)%16, 0, Lhour);//顯示小時(shí)的個(gè)位
  Lcd_XianShi((k+3)%16, 0, Hminute);//顯示分鐘的十位
  Lcd_XianShi((k+4)%16, 0, Lminute);//顯示分鐘的個(gè)位
  Lcd_XianShi((k+6)%16, 0, Hsecond);//顯示秒的十位
  Lcd_XianShi((k+7)%16, 0, Lsecond);//顯示秒的個(gè)位
  if (Second % 2 == 1)//顯示冒號(hào)
    lcd.setCursor((k+2)%16, 0);
    lcd.print(":");
    lcd.setCursor((k+5)%16, 0);
    lcd.print(":");
  if (Second % 2 == 0)//不顯示冒號(hào)
    lcd.print(" ");
    lcd.print(" ");
void Lcd_XianShi(unsigned char a, unsigned char b, unsigned char c)
  lcd.setCursor(a, b); //設(shè)置顯示光標(biāo)位置
  lcd.print(c);
收藏收藏 分享淘帖 頂1 踩
