查看: 2498|回復(fù): 0
多點(diǎn)(八組DS18B20)溫度測(cè)量的單片機(jī)仿真+代碼
ID:432698 發(fā)表于 2018-11-25 09:26 | 顯示全部樓層 |閱讀模式
多點(diǎn)溫度測(cè)量仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機(jī)源程序如下:
  1. //頭文件包含
  2. #include <AT89X51.H>
  3. #include <Intrins.h>
  4. #include "DS18B20.H"
  5. //引腳定義
  6. sbit                                                         DQ = P2^7;                                                        //數(shù)據(jù)線端口
  7. //DS18B20序列號(hào),通過調(diào)用GetROMSequence()函數(shù)在P1口讀出(讀8次)
  8. const unsigned char code ROMData1[8] = {0x28, 0x33, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xD7};        //U1
  9. const unsigned char code ROMData2[8] = {0x28, 0x30, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x8E};        //U2
  10. const unsigned char code ROMData3[8] = {0x28, 0x31, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xB9};        //U3
  11. const unsigned char code ROMData4[8] = {0x28, 0x32, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0xE0};        //U4
  12. const unsigned char code ROMData5[8] = {0x28, 0x34, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x52};        //U5
  13. const unsigned char code ROMData6[8] = {0x28, 0x35, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x65};        //U6
  14. const unsigned char code ROMData7[8] = {0x28, 0x36, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x3C};        //U7
  15. const unsigned char code ROMData8[8] = {0x28, 0x37, 0xC5, 0xB8, 0x00, 0x00, 0x00, 0x0B};        //U8
  16. //延時(shí)16us子函數(shù)
  17. void Delay16us()
  18. {
  19.         unsigned char a;
  20.         for (a = 0; a < 4; a++);
  21. }
  22. //延時(shí)60us子函數(shù)
  23. void Delay60us()
  24. {
  25.         unsigned char a;
  26.         for (a = 0; a < 18; a++);
  27. }
  28. //延時(shí)480us子函數(shù)
  29. void Delay480us()
  30. {
  31.         unsigned char a;
  32.         for (a = 0; a < 158; a++);
  33. }
  34. //延時(shí)240us子函數(shù)
  35. void Delay240us()
  36. {
  37.         unsigned char a;
  38.         for (a = 0; a < 78; a++);
  39. }
  40. //延時(shí)500ms子函數(shù)
  41. void Delay500ms()
  42. {
  43.         unsigned char a, b, c;
  44.         for (a = 0; a < 250; a++)
  45.         for (b = 0; b < 3; b++)
  46.         for (c = 0; c < 220; c++);
  47. }
  48. //芯片初始化
  49. void Initialization()
  50. {
  51.         while(1)
  52.         {
  53.                 DQ = 0;
  54.                 Delay480us();                         //延時(shí)480us
  55.                 DQ = 1;
  56.                 Delay60us();                        //延時(shí)60us
  57.                 if(!DQ)                                  //收到ds18b20的應(yīng)答信號(hào)
  58.                 {
  59.                         DQ = 1;
  60.                         Delay240us();                //延時(shí)240us
  61.                         break;
  62.                 }
  63.         }
  64. }
  65. //寫一個(gè)字節(jié)(從低位開始寫)
  66. void WriteByte(unsigned char btData)
  67. {
  68.         unsigned char i, btBuffer;
  69.         for (i = 0; i < 8; i++)
  70.         {
  71.                 btBuffer = btData >> i;
  72.                 if (btBuffer & 1)
  73.                 {
  74.                         DQ = 0;
  75.                         _nop_();
  76.                         _nop_();
  77.                         DQ = 1;
  78.                         Delay60us();
  79.                 }
  80.                 else
  81.                 {
  82.                         DQ = 0;
  83.                         Delay60us();
  84.                         DQ = 1;
  85.                 }
  86.         }
  87. }
  88. //讀一個(gè)字節(jié)(從低位開始讀)
  89. unsigned char ReadByte()
  90. {
  91.         unsigned char i, btDest;
  92.         for (i = 0; i < 8; i++)
  93.         {
  94.                 btDest >>= 1;
  95.                 DQ = 0;
  96.                 _nop_();
  97.                 _nop_();
  98.                 DQ = 1;
  99.                 Delay16us();
  100.                 if (DQ) btDest |= 0x80;
  101.                 Delay60us();
  102.         }
  103.         return btDest;
  104. }
  105. //序列號(hào)匹配
  106. void MatchROM(const unsigned char *pMatchData)
  107. {
  108.         unsigned char i;
  109.         Initialization();
  110.         WriteByte(MATCH_ROM);
  111.         for (i = 0; i < 8; i++) WriteByte(*(pMatchData + i));
  112. }
  113. //得到64位ROM序列(在P1口顯示,必須與Proteus聯(lián)調(diào)且在單步調(diào)試下才能得到)
  114. /*void GetROMSequence()
  115. {
  116.         unsigned char i;
  117.         Initialization();
  118.         WriteByte(READ_ROM);
  119.         for (i = 0; i < 8; i++)
  120.         P1 = ReadByte();
  121. }*/
  122. //讀取溫度值
  123. TEMPDATA ReadTemperature()
  124. {
  125.         TEMPDATA TempData;
  126.         unsigned int iTempDataH;
  127.         unsigned char btDot, iTempDataL;
  128.         static unsigned char i = 0;
  129.         TempData.btNegative = 0;                                                //為0溫度為正
  130.         i++;
  131.         if (i == 9) i = 1;
  132.         Initialization();
  133.         WriteByte(SKIP_ROM);                                                        //跳過ROM匹配
  134.         WriteByte(TEMP_SWITCH);                                                        //啟動(dòng)轉(zhuǎn)換
  135.         Delay500ms();        //調(diào)用一次就行
  136.         Delay500ms();
  137.         Initialization();
  138.         //多個(gè)芯片的時(shí)候用MatchROM(ROMData)換掉WriteByte(SKIP_ROM)
  139.         switch (i)
  140.         {
  141.                 case 1 : MatchROM(ROMData1); break;                        //匹配1
  142.                 case 2 : MatchROM(ROMData2); break;                        //匹配2
  143.                 case 3 : MatchROM(ROMData3); break;                        //匹配3
  144.                 case 4 : MatchROM(ROMData4); break;                        //匹配4
  145.                 case 5 : MatchROM(ROMData5); break;                        //匹配5
  146.                 case 6 : MatchROM(ROMData6); break;                        //匹配6
  147.                 case 7 : MatchROM(ROMData7); break;                        //匹配7
  148.                 case 8 : MatchROM(ROMData8); break;                        //匹配8
  149.         }
  150.         //WriteByte(SKIP_ROM);                                                        //跳過ROM匹配(單個(gè)芯片時(shí)用這句換掉上面的switch)
  151.         WriteByte(READ_MEMORY);                                                        //讀數(shù)據(jù)
  152.         iTempDataL = ReadByte();
  153.         iTempDataH = ReadByte();
  154.         iTempDataH <<= 8;
  155.         iTempDataH |= iTempDataL;
  156.         if (iTempDataH & 0x8000)
  157.         {
  158.                 TempData.btNegative = 1;
  159.                 iTempDataH = ~iTempDataH + 1;                                //負(fù)數(shù)求補(bǔ)
  160.         }
  161.         //為了省去浮點(diǎn)運(yùn)算帶來的開銷,而采用整數(shù)和小數(shù)部分分開處理的方法(沒有四舍五入)
  162.         btDot = (unsigned char)(iTempDataH & 0x000F);        //得到小數(shù)部分
  163.         iTempDataH >>= 4;        //得到整數(shù)部分
  164.         btDot *= 5;        //btDot*10/16得到轉(zhuǎn)換后的小數(shù)數(shù)據(jù)
  165.         btDot >>= 3;
  166.         //數(shù)據(jù)處理
  167.         TempData.btThird   = (unsigned char)iTempDataH / 100;
  168.         TempData.btSecond  = (unsigned char)iTempDataH % 100 / 10;
  169.         TempData.btFirst   = (unsigned char)iTempDataH % 10;
  170.         TempData.btDecimal = btDot;
  171.         return TempData;
  172. }
多點(diǎn)溫度測(cè)量.zip (82.37 KB, 下載次數(shù): 55)
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
