本人想用STM32的DMA和串口1 的ILDE模式接收不定長數(shù)據(jù)幀,遇到一個(gè)奇怪的現(xiàn)象,當(dāng)串口助手V2.0(正點(diǎn)原子的)手動(dòng)發(fā)送所需要的數(shù)據(jù)包時(shí),誤包率很高,而改為60ms自動(dòng)發(fā)送就幾乎沒有出現(xiàn)誤包的問題,所謂的誤包問題要不出現(xiàn)功能碼出錯(cuò),要不幀長度出現(xiàn)錯(cuò)誤了。- void Configuration_GPIO()
- GPIO_InitTypeDef GPIO_InitStructure;
- // USART1_TX:PA9
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- // USART1_RX:PA10
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
復(fù)制代碼- #include "Configuration_DMA.h"
- u8 RecBuffer[RecLength] = {0};
- u8 Usart1_Rec_Cnt = 0;
- void Configuration_DMA_USART()
- DMA_InitTypeDef DMA_InitStructure;
- /* 該DMA用于USART快速傳輸一幀數(shù)據(jù),單字節(jié)時(shí)不需要 */
- DMA_DeInit(DMA1_Channel5);
- DMA_InitStructure.DMA_PeripheralBaseAddr = (u32) &USART1->DR;
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32) &RecBuffer;//這是初始化時(shí)候配置,可以根據(jù)程序運(yùn)行重新設(shè)置。
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = RecLength;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
- DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel5, &DMA_InitStructure);
- DMA_Cmd(DMA1_Channel5, ENABLE);
復(fù)制代碼- void Control_NVIC_USART1(FunctionalState NewStatus)
- NVIC_InitTypeDef NVIC_InitStructure;
- // 設(shè)置NVIC中斷分組4:4位搶占優(yōu)先級,0位響應(yīng)優(yōu)先級
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);
- NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;
- NVIC_InitStructure.NVIC_IRQChannelCmd = NewStatus;
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
- NVIC_Init(&NVIC_InitStructure);
復(fù)制代碼- void Configuration_USART(u32 baudrate)
- USART_InitTypeDef USART_InitStructure;
- USART_InitStructure.USART_BaudRate = baudrate;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- USART_Init(USART1, &USART_InitStructure);
- USART_ITConfig(USART1, USART_IT_RXNE, DISABLE); // 不使能接收中斷
- USART_ITConfig(USART1, USART_IT_TC, DISABLE); // 不使能發(fā)送中斷
- USART_ITConfig(USART1, USART_IT_IDLE, ENABLE); // 使能空閑中斷
- USART_ClearFlag(USART1, USART_FLAG_TC);
- USART_DMACmd(USART1, USART_DMAReq_Rx, ENABLE);
- USART_Cmd(USART1, ENABLE);
- // 防止首字節(jié)丟失
- while(USART_GetFlagStatus(USART1,USART_FLAG_TC) == RESET);
- void USART1_SendByte(uint8_t c)
- USART_SendData(USART1, (uint8_t)c);
- void USART1_SendNByte(u8 *pData,u8 Length)
- while(Length--)
- USART1_SendByte(*pData);
- pData++;
- void USART1_IRQHandler(void)
- u8 i;
- if(USART_GetITStatus(USART1, USART_IT_IDLE) != RESET)
- // 關(guān)閉USART1 TX DMA1 所指示的通道
- DMA_Cmd(DMA1_Channel5, DISABLE);
- // 讀取數(shù)據(jù) 注意:這句必須要,否則不能夠清除中斷標(biāo)志位。我也不知道為啥!
- USART_ReceiveData(USART1);
- // 算出接本幀數(shù)據(jù)長度
- Usart1_Rec_Cnt = RecLength - DMA_GetCurrDataCounter(DMA1_Channel5);
- if(Usart1_Rec_Cnt != 8)
- Usart1_Rec_Cnt = 0;
- /*------------------------串口測試段--------------------------------*/
- for(i = 0;i < Usart1_Rec_Cnt;i++)
- RecBuffer1[i] = RecBuffer[i];
- //***********幀數(shù)據(jù)處理函數(shù)************//
- // printf ("The lenght:%d\r\n",Usart1_Rec_Cnt);
- // printf ("The data:\r\n");
- // USART1_SendNByte(RecBuffer, Usart1_Rec_Cnt);
- // printf ("\r\nOver! \r\n");
- // 清除中斷標(biāo)志
- USART_ClearITPendingBit(USART1, USART_IT_IDLE);
- // DMA通道的DMA緩存的大小
- DMA_SetCurrDataCounter(DMA1_Channel5, RecLength);
- // 使能USART1 TX DMA1 所指示的通道
復(fù)制代碼 以上是我的GPIO。DMA、USART和中斷的配置,請遇到過類似問題的大佬能夠伸出援手,在下感激不盡! |
