請幫忙用c編個程序,謝謝.......DS1302
please help debug
#include <reg52.h> #include <intrins.h> #define uchar unsigned char #define uint unsigned int sbit sclk=P1^0;//1302 sbit io=P1^1;//1302 sbit rst=P2^0;//1302 sbit lcden=P3^4;//1602 sbit lcdrs=P3^5;//1602 sbit lcdwr=P2^7;//1602 sbit led=P2^6;//????êy??1ü1???μ?£???è???μ??éóD?é?T£??÷òaê?ê?μ?£?è?1?òo?§áá?è2?1?£??éò?????ò????£áíía?1óDá÷??μ?μ?ò2?éò?????1?μ?p14 sbit set=P3^2;//éè???ü?¨ò?,°′??oóòà′?éè?¨?ê??è? D?ê±·???μè sbit addkey=P3^6;//éè?¨ê±??ê±?óêy?Y sbit deckey=P3^7;//éè?¨ê±??ê±??êy?Y uchar flag,add,dec,check; uchar sec,min,hr,day,mon,yr,week; uchar code table[]="SUNMONTUEWEDTHUFRISAT";//D??ú??ê?μ?×?·?′? uchar code table2[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39};//0-9??ó|μ?ASII?? /********************************************************************************************************************/ //ò????a1302μ??ù±?2ù×÷ void delayus()//4usμ??óê±£?ò???nopê?1us { _nop_(); _nop_(); _nop_(); _nop_(); } void write(uchar dat)//ò???×??úμ?êy?Y { uchar i; sclk=0; delayus(); for(i=0;i<8;i++) { dat=dat>>1;//ò?????′??÷2?1ü×óò??ò??óòò?£?±?ò?3?????′?è?ò?3???CY; io=CY; delayus(); sclk=1; delayus(); sclk=0; delayus(); } }
uchar read()//?áò???×??úμ?êy?Y { uchar i,dat=0; for(i=0;i<8;i++) { sclk=1; delayus(); sclk=0; delayus(); dat=_cror_(dat,1)|io;//′?′|2éó?μ?ê???·óòò???á?£?°?êy?Y?á3? } return dat; } uchar read1302(uchar cmd)//′ó1302μ?ì??¨????cmd?á3?êy?μ { uchar dat; rst=1; write(cmd); dat=read(); rst=0; return dat; } void write1302(uchar cmd,uchar dat)//°?êy?YdatD′μ?1302μ?cmd??ó|???? { rst=0; sclk=0; rst=1; write(cmd); write(dat); } /****************************************************************************/ void set1302()//1302éè??£?°?éè?¨o?μ?ê±??D′è?1302 { uchar shi,ge; write1302(0x8E,0x00); //?ù?YD′×′ì???′??÷?üá?×?£?D′è?2?±£?¤??á? shi=sec/10; ge=sec%10; sec=(shi<<4)|ge; write1302(0x80,sec); //?ù?YD′????′??÷?üá?×?£?D′è???μ?3?ê??μ shi=min/10; ge=min%10; min=(shi<<4)|ge; write1302(0x82,min); //?ù?YD′·???′??÷?üá?×?£?D′è?·?μ?3?ê??μ shi=hr/10; ge=hr%10; hr=(shi<<4)|ge; write1302(0x84,hr); //?ù?YD′D?ê±??′??÷?üá?×?£?D′è?D?ê±μ?3?ê??μ shi=day/10; ge=day%10; day=(shi<<4)|ge; write1302(0x86,day); //?ù?YD′è???′??÷?üá?×?£?D′è?è?μ?3?ê??μ shi=mon/10; ge=mon%10; mon=(shi<<4)|ge; write1302(0x88,mon); //?ù?YD′????′??÷?üá?×?£?D′è???μ?3?ê??μ shi=yr/10; ge=yr%10; yr=(shi<<4)|ge; write1302(0x8c,yr); //?ù?YD′?ê??′??÷?üá?×?£?D′è??êμ?3?ê??μ write1302(0x8f,0x00); } void readtime()//′ó1302?D?áè?ê±??2¢??D??ú??DD???? { uchar shi,ge; sec=read1302(0x81); shi=(sec&0xf0)>>4; ge=sec&0x0f; sec=10*shi+ge; min=read1302(0x83); shi=(min&0xf0)>>4; ge=min&0x0f; min=10*shi+ge; hr=read1302(0x85); shi=(hr&0xf0)>>4; ge=hr&0x0f; hr=10*shi+ge; day=read1302(0x87); shi=(day&0xf0)>>4; ge=day&0x0f; day=10*shi+ge; mon=read1302(0x89); shi=(mon&0xf0)>>4; ge=mon&0x0f; mon=10*shi+ge; yr=read1302(0x8d); shi=(yr&0xf0)>>4; ge=yr&0x0f; yr=10*shi+ge; if(day!=check)//????D??ú?μ { week++; if(week>6)week=0; check=day; } } /****************************************************************************************************/ /*ò???ê?1602μ??ù±?2ù×÷*/ void delay(uint z)//1mS?óê±×ó3ìDò { uint a,b; for(a=z;a>0;a--) for(b=110;b>0;b--); } void write_com(uchar com)//D′????×?LCD { lcdrs=0;//????×? P0=com; delay(5); lcden=1; delay(5); lcden=0; } void write_data(uchar date)//D′êy?YLCD { lcdrs=1;//êy?Y P0=date; delay(5); lcden=1; delay(5); lcden=0; } void write_week(uchar i)//??ê?D??úμ?oˉêy { write_data(table[3*i]); write_data(table[3*i+1]); write_data(table[3*i+2]); } void write_time(uchar time)//??ê?2??êyê±??£??ê??è??ùê?2??êyμ???ê? { uchar shi,ge; shi=time/10; ge=time%10; write_data(table2[shi]); write_data(table2[ge]); } void display()//??ê??ê??è??°D??úμè { write_com(0x80); write_time(yr); write_data('-'); write_time(mon); write_data('-'); write_time(day); write_data(' '); write_data(' '); write_week(week); write_com(0x80+0x40); write_time(hr); write_data(':'); write_time(min); write_data(':'); write_time(sec); write_data(' '); write_data(' '); write_data('C'); write_data('h'); write_data('e'); write_data('n'); write_data('g'); } void initlcd()//LCD??ê?3?ê??ˉ?£ { led=0; lcdwr=0; lcden=0; write_com(0x38);//°′??1602μ?éè?¨?3Dòòà′???DDéè?¨?¢ write_com(0x0c);//2???ê?1a±êoíéá?? write_com(0x06);//??D′ò???×?·?£?1a±ê+1 write_com(0x01);//???á } /************************************************************************************/ //ò???ê??ü?ì????2?·? void keyscan()//?ü?ìé¨?è3ìDò£??′°′??μ?ê??????ü { if(set==0) { delay(30); if(set==0) { while(!set); delay(30); while(!set); flag=1; } } if(addkey==0) {
delay(30); if(addkey==0) { while(!addkey); delay(30); while(!addkey); add=1; } } if(deckey==0) { delay(30); if(deckey==0) { while(!deckey); delay(30); while(!deckey); dec=1; } } } void timeset()//ê±??éè?¨oˉêy£?òà′?éè???ê£???£?è?£¨D??ú£?£?D?ê±£?·??? { if(flag==1) { flag=0; write_com(0x0f);//?a??1a±êéá?? write_com(0x80);//éè???êμ??eê?×?±ê while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag) { keyscan(); if(add==1) { add=0; yr++; write_time(yr); } if(dec==1) { dec=0; yr--; write_time(yr); } write_com(0x80);//?ê1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+3);//éè????×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag)//è?1?óD?aê??D??°′?ü£? { keyscan(); if(add==1) { add=0; mon++; if(mon>12)mon=1; write_time(mon); } if(dec==1) { dec=0; mon--; if(mon>12)mon=1; write_time(mon); } write_com(0x80+3);//??1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+6);//éè??ìì×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag)//è?1?óD?aê??D??°′?ü£? { keyscan(); if(add==1) { add=0; day++; if(day==29) { if((mon==2)&&(yr%4!=0))day=1; } if(day==30) { if((mon==2)&&(yr%4==0))day=1; } if(day==31) { if((mon==4)||(mon==6)||(mon==9)||(mon==11))day=1; } if(day>31)day=0; write_time(day); } if(dec==1) { dec=0; day--; if(day==0) { if((mon==2)&&(yr%4!=0))day=28; if((mon==2)&&(yr%4==0))day=29; if((mon==4)||(mon==6)||(mon==9)||(mon==11))day=30; if((mon==1)||(mon==3)||(mon==5)||(mon==7)||(mon==8)||(mon==10)||(mon==12))day=31; } write_time(day); check=day; } write_com(0x80+6);//ìì1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+10);//éè??D?ê±×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag) { keyscan(); if(add==1) { add=0; week++; if(week>6)week=0; write_week(week); } if(dec==1) { dec=0; week--; if(week>6)week=6; write_week(week); } write_com(0x80+10);//D?ê±1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+0x40);//éè??D?ê±×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag) { keyscan(); if(add==1) { add=0; hr++; if(hr>23)hr=0; write_time(hr); } if(dec==1) { dec=0; hr--; if(hr>23)hr=23; write_time(hr); } write_com(0x80+0x40);//D?ê±1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+0x40+3);//éè??·??ó×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag)//è?1?óD?aê??D??°′?ü£? { keyscan(); if(add==1) { add=0; min++; if(min>59)min=0; write_time(min); } if(dec==1) { dec=0; min--; if(min>59)min=59; write_time(min); } write_com(0x80+0x40+3);//D?ê±1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; write_com(0x80+0x40+6);//éè??·??ó×?±ê?eê??? while(!flag&&!add&&!dec)keyscan();//é¨?è?ü?ì£??′ê?·?óD°′?ü°′?? while(!flag)//è?1?óD?aê??D??°′?ü£? { keyscan(); if(add==1) { add=0; sec++; if(sec>59)sec=0; write_time(sec); } if(dec==1) { dec=0; sec--; if(sec>59)sec=59; write_time(sec); } write_com(0x80+0x40+6);//D?ê±1a±êéè??1é??£?μè′y??ò?′?μ?éè?¨ } flag=0; set1302(); write_com(0x0c); } } /**********************************************************************/ //?÷3ìDò void main() { while(set==0)//?aà?ê????μí3?í3?ê??μμ?£?ê1ó?μ?·?·¨ê???μ???oó£?°′×?set?ü£?è?oóé?μ?£?set?ü°′×?1~3s,?é?a?′éè??íê3é { sec=11;min=20;hr=13;day=29;mon=2;yr=12;week=3;//3?ê??μéè?¨£??aà?òa×¢òa£?D??úμ?éè?¨±?D??yè·£?2?è?oóD?μ?×?ê±?á3?′í?£ set1302(); initlcd(); readtime(); display(); } write1302(0x8f,0x00);//?áè?êy?Yê±£?±?D?°?1302éè???a′?×′ì?£??áêy?Yμ?D′±£?¤′ò?a initlcd(); while(1) { keyscan();//?ü?ìé¨?è timeset();//è?1?éè???ü°′???íéè?¨ê±??£?·??ò?ííù???′DD readtime(); display(); } }
clock_ok.txt
(10.03 KB, 下載次數(shù): 4)
2012-4-10 14:52 上傳
下載積分: 黑幣 -5
