查看: 3554|回復(fù): 0
Proteus仿真51簡易計算器
ID:322402 發(fā)表于 2018-11-23 11:22 | 顯示全部樓層 |閱讀模式
單片機(jī)源程序如下:
  1. #include "reg52.h"
  2. typedef unsigned int uint;
  3. typedef unsigned char uchar;
  4. sbit rw=P2^5;
  5. sbit rs=P2^6;
  6. sbit e=P2^7;
  7. //sbit led=P3^7;
  8. //sbit beep=P2^0;
  9. uint fuhao,flag,k,i,j,num;
  10. uchar disp[]="rorrE";
  11. uchar wel[]="    Welcome!";
  12. long a,b,c,x;
  13. void delay(long i)  //延時
  14. {
  15.         while(i--);
  16. }
  17. void lcdwrc(uint c) //設(shè)置LCD寫命令
  18. {
  19.         delay(1000);
  20.         rs=0;
  21.         rw=0;
  22.         e=0;
  23.         P0=c;
  24.         e=1;
  25.         delay(1000);
  26.         e=0;
  27. }
  28. void lcdwrd(uint dat) //設(shè)置LCD寫數(shù)據(jù)
  29. {
  30.         delay(1000);
  31.         rs=1;
  32.         rw=0;
  33.         e=0;
  34.         P0=dat;
  35.         e=1;
  36.         delay(1000);
  37.         e=0;
  38.         rs=0;
  39. }
  40. void lcdinit()          //初始化LCD
  41. {
  42.         delay(1500);
  43.         lcdwrc(0x38);
  44.         delay(500);
  45.         lcdwrc(0x38);
  46.         delay(500);
  47.         lcdwrc(0x38);
  48.         delay(500);
  49.         lcdwrc(0x38); //功能設(shè)定指令
  50.         lcdwrc(0x08);  //
  51.         lcdwrc(0x01); //清屏
  52.         lcdwrc(0x06);  //設(shè)置LCD顯示
  53.         lcdwrc(0x0c); //顯示開關(guān)控制指令
  54.     num=0;
  55.         fuhao=0;
  56.         flag=0;
  57.         a=0;
  58.         b=0;
  59.         c=0;
  60.         x=0;
  61.         k=0;
  62.         j=0;
  63. }
  64. void KeyDown()
  65. {
  66.     k=0;
  67.         P1=0x0f;
  68.         if(P1!=0x0f)
  69.         {
  70.                 delay(1000);
  71.                   if(P1!=0x0f)
  72.                 {
  73.                         P1=0x0f;
  74.                         switch(P1)
  75.                         {
  76.                                 case 0x07:
  77.                                 {
  78.                                         P1=0xf0;
  79.                                         switch(P1)
  80.                                        {
  81.                                      case 0x70: k=1; break;
  82.                                      case 0xb0: k=4; break;
  83.                                          case 0xd0: k=7; break;
  84.                                          case 0xe0: k=0; break;
  85.                                 }
  86.                                     if(fuhao==0)
  87.                                      a=a*10+k;
  88.                                     else
  89.                                       b=b*10+k;
  90.                              }
  91.                                  lcdwrd(0x30+k);
  92.                              while(P1!=0xf0);break;
  93.                     case 0x0b:
  94.                                          {
  95.                                            P1=0xf0;
  96.                                switch(P1)
  97.                                              {
  98.                                          case 0x70: num=2;k=2; break;
  99.                                      case 0xb0: num=6;k=5; break;
  100.                                      case 0xd0: num=10;k=8; break;
  101.                                          case 0xe0: num=14; break;
  102.                                        }
  103.                                                  if(num!=14)
  104.                                                 {
  105.                                              if(fuhao==0)
  106.                                                     a=a*10+k;
  107.                                                  else
  108.                                                    b=b*10+k;
  109.                                                    lcdwrd(0x30+k);
  110.                                                 }
  111.                                                  if(num==14)
  112.                                                 {
  113.                                                   lcdwrc(0x01);        //清屏指令
  114.                                                  lcdinit();
  115.                                             }
  116.                                           }
  117.                                           while(P1!=0xf0); break;
  118.                                  case 0x0d:
  119.                                      {
  120.                                                  P1=0xf0;
  121.                                     switch(P1)
  122.                                        {
  123.                                      case 0x70: num=3;  k=3;  break;
  124.                                      case 0xb0: num=7;  k=6;  break;
  125.                                      case 0xd0: num=11; k=9;  break;
  126.                                      case 0xe0: num=15;       break;
  127.                                     }
  128.                                                 if(num!=15)
  129.                                             {
  130.                                               if(fuhao==0)
  131.                                                    a=a*10+k;
  132.                                                   else
  133.                                                   b=b*10+k;
  134.                                                   lcdwrd(0x30+k);
  135.                                              }
  136.                                                  if(num==15)
  137.                                                 {
  138.                                                     switch(flag)
  139.                                                         {
  140.        case 1:
  141.        {
  142.        c=a+b;
  143.        lcdwrc(0x4f+0x80);
  144.                                                      lcdwrc(0x04);
  145.        if(c==0)
  146.        lcdwrd(0x30);
  147.                                                              while(c!=0)
  148.                                                      {
  149.        lcdwrd(0x30+c%10);
  150.                                                             c=c/10;
  151.                                                          }
  152.        lcdwrd(0x3d);
  153.        }break;
  154.        case 2:
  155.        {
  156.        if(a>b)
  157.        c=a-b;
  158.                                                           else
  159.        c=b-a;
  160.        lcdwrc(0x4f+0x80);
  161.                                               lcdwrc(0x04);
  162.        if(c==0)
  163.        lcdwrd(0x30);
  164.        while(c!=0)
  165.                                                       {
  166.        lcdwrd(0x30+c%10);
  167.        c=c/10;
  168.                                                              }
  169.        if(a<b)
  170.        lcdwrd(0x2d);
  171.                                                         lcdwrd(0x3d);
  172.        }break;
  173.                                                              case 3:
  174.                                                             {
  175.        c=a*b;
  176.        lcdwrc(0x4f+0x80);
  177.                                                 lcdwrc(0x04);
  178.        if(c==0)
  179.        lcdwrd(0x30);
  180.                                                              while(c!=0)
  181.        {
  182.                                                               lcdwrd(0x30+c%10);
  183.                                                        c=c/10;
  184.                                                             }
  185.        lcdwrd(0x3d);
  186.        }    break;
  187.        case 4:
  188.        {
  189.        if(b==0)
  190.        {
  191.        lcdwrc(0x4f+0x80);
  192.        lcdwrc(0x04);
  193.        for(i=0;i<5;i++)
  194.        lcdwrd(disp[i]);
  195.        }
  196.        else
  197.        {
  198.        c=(long)(((float)a/b)*10000);
  199.        x=c;
  200.        lcdwrc(0x4f+0x80);
  201.        lcdwrc(0x04);
  202.        while(c!=0)         //一位一位顯示
  203.                                                               {
  204.        k++;
  205.        lcdwrd(0x30+c%10);//顯示結(jié)果的最后一位在0x4f的位置
  206.        c=c/10;//取前面的結(jié)果數(shù)據(jù)
  207.        if(x>0&&x<=9)
  208.        {
  209.        if(k==1)
  210.        {
  211.        lcdwrd(0x30);
  212.        lcdwrd(0x30);
  213.        lcdwrd(0x30);
  214.        lcdwrd(0x2e);
  215.        k=0;
  216.        }
  217.        }
  218.        if(x>9&&x<=99)
  219.        {
  220.        if(k==2)
  221.        {
  222.        lcdwrd(0x30);
  223.        lcdwrd(0x30);
  224.        lcdwrd(0x2e);
  225.        k=0;
  226.        }
  227.        }
  228.        if(x>99&&x<=999)
  229.        {
  230.        if(k==3)
  231.        {
  232.        lcdwrd(0x30);
  233.        lcdwrd(0x2e);
  234.        k=0;
  235.        }
  236.        }
  237.        else
  238.        if(k==4)
  239.        {
  240.        lcdwrd(0x2e);
  241.        k=0;
  242.                                                               }
  243.        }
  244.                                    if(x<10000)
  245.        lcdwrd(0x30);
  246.        lcdwrd(0x3d);
  247.                                                      }
  248.                                                    }        break;
  249.                                                    }
  250.                                                 }
  251.                                    }while(P1!=0xf0);break;
  252.                                    case 0x0e:
  253.                                          {
  254.                                              fuhao=1;
  255.                                                 P1=0xf0;
  256.                                     switch(P1)
  257.                                       {
  258.                                             case 0x70: flag=1;lcdwrd(0x2b);   break;
  259.                                             case 0xb0:flag=2; lcdwrd(0x2d);  break;
  260.                                              case 0xd0: flag=3;lcdwrd(0x2a);  break;
  261.                                             case 0xe0: flag=4; lcdwrd(0x2f); break;
  262.                                     }
  263.                         }  while(P1!=0xf0);  break;
  264.                         }
  265.                  }
  266.          }
  267. }
  268.
  269. void main()
  270. {
  271.     uint x;
  272.         lcdinit();
  273.         for(x=0;x<12;x++)
  274.         lcdwrd(wel[x]);
  275.         delay(50000);
  276.         lcdwrc(0x01);
  277.         while(1)
  278.            KeyDown();
  279. }
51簡易計算器.zip (60.71 KB, 下載次數(shù): 59)
ID:423139 發(fā)表于 2019-5-8 15:23
為什么在下載不了,老是下載失敗
