查看: 2910|回復: 1
FPGA狀態機源碼
ID:431476 發表于 2018-11-22 21:36 | 顯示全部樓層 |閱讀模式
module zhuangtai(clk,rst,led0,led1,led2,led3);
        input clk,rst;
        output led0,led1,led2,led3;
        wire [5:0]cnt;
        wire clk_1hz;
        fen1hz my_fen1hz(
        .clk(clk),
        .rst(rst),
        .c_out(clk_1hz)
        jishu my_jishu(
        .clk(clk),
        .rst(rst),
        .c_out(cnt)
        reg [1:0]curr_st;
        reg [1:0]next_st;
        parameter [1:0] IDLE=2'b00,
                                                 s1=2'b01,
                                                 s2=2'b10,
                                                 s3=2'b11;
        always@(posedge clk or negedge rst)
        if(!rst) curr_st<=IDLE;
        else curr_st<=next_st;
        begin
        case(curr_st)
        IDLE:begin
        if(cnt==6'd15) next_st=s1;
        else next_st=IDLE;
        end
        s1:begin
        if(cnt==6'd25) next_st=s2;
        else next_st=s1;
        end
        s2:begin
        if(cnt==6'd29) next_st=s3;
        else next_st=s2;
        end
        s3:begin
        if(cnt==6'd36) next_st=IDLE;
        else next_st=s3;
        end
        endcase
        end
        assign led0=(curr_st==IDLE)?0:1;
        assign led1=(curr_st==s1)?0:1;
        assign led2=(curr_st==s2)?clk_1hz:1;
        assign led3=(curr_st==s3)?0:1;
endmodule
ID:470289 發表于 2019-1-21 18:36 | 顯示全部樓層
感謝分享
