原理圖按照三樓的那樣連接,程序如下:
#include <reg52.h>
#include <intrins.h>
sbit RS485_DIR = P1^7; //RS485方向選擇引腳
bit flagFrame = 0; //幀接收完成標(biāo)志,即接收到一幀新數(shù)據(jù)
bit flagTxd = 0; //單字節(jié)發(fā)送完成標(biāo)志,用來(lái)替代TXD中斷標(biāo)志位
unsigned char cntRxd = 0; //接收字節(jié)計(jì)數(shù)器
unsigned char pdata bufRxd[64]; //接收字節(jié)緩沖區(qū)
extern void UartAction(unsigned char *buf, unsigned char len);
/* 串口配置函數(shù),baud-通信波特率 */
void ConfigUART(unsigned int baud)
RS485_DIR = 0; //RS485設(shè)置為接收方向
SCON = 0x50; //配置串口為模式1
TMOD &= 0x0F; //清零T1的控制位
TMOD |= 0x20; //配置T1為模式2
TH1 = 256 - (11059200/12/32)/baud; //計(jì)算T1重載值
TL1 = TH1; //初值等于重載值
ET1 = 0; //禁止T1中斷
ES = 1; //使能串口中斷
TR1 = 1; //啟動(dòng)T1
/* 軟件延時(shí)函數(shù),延時(shí)時(shí)間(t*10)us */
void DelayX10us(unsigned char t)
do {
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
} while (--t);
/* 串口數(shù)據(jù)寫(xiě)入,即串口發(fā)送函數(shù),buf-待發(fā)送數(shù)據(jù)的指針,len-指定的發(fā)送長(zhǎng)度 */
void UartWrite(unsigned char *buf, unsigned char len)
RS485_DIR = 1; //RS485設(shè)置為發(fā)送
while (len--) //循環(huán)發(fā)送所有字節(jié)
flagTxd = 0; //清零發(fā)送標(biāo)志
SBUF = *buf++; //發(fā)送一個(gè)字節(jié)數(shù)據(jù)
while (!flagTxd); //等待該字節(jié)發(fā)送完成
DelayX10us(5); //等待最后的停止位完成,延時(shí)時(shí)間由波特率決定
/* 串口數(shù)據(jù)讀取函數(shù),buf-接收指針,len-指定的讀取長(zhǎng)度,返回值-實(shí)際讀到的長(zhǎng)度 */
unsigned char UartRead(unsigned char *buf, unsigned char len)
unsigned char i;
if (len > cntRxd) //指定讀取長(zhǎng)度大于實(shí)際接收到的數(shù)據(jù)長(zhǎng)度時(shí),
{ //讀取長(zhǎng)度設(shè)置為實(shí)際接收到的數(shù)據(jù)長(zhǎng)度
len = cntRxd;
for (i=0; i<len; i++) //拷貝接收到的數(shù)據(jù)到接收指針上
*buf++ = bufRxd[i];
cntRxd = 0; //接收計(jì)數(shù)器清零
return len; //返回實(shí)際讀取長(zhǎng)度
/* 串口接收監(jiān)控,由空閑時(shí)間判定幀結(jié)束,需在定時(shí)中斷中調(diào)用,ms-定時(shí)間隔 */
void UartRxMonitor(unsigned char ms)
static unsigned char cntbkp = 0;
static unsigned char idletmr = 0;
if (cntRxd > 0) //接收計(jì)數(shù)器大于零時(shí),監(jiān)控總線空閑時(shí)間
if (cntbkp != cntRxd) //接收計(jì)數(shù)器改變,即剛接收到數(shù)據(jù)時(shí),清零空閑計(jì)時(shí)
cntbkp = cntRxd;
idletmr = 0;
else //接收計(jì)數(shù)器未改變,即總線空閑時(shí),累積空閑時(shí)間
if (idletmr < 30) //空閑計(jì)時(shí)小于30ms時(shí),持續(xù)累加
idletmr += ms;
if (idletmr >= 30) //空閑時(shí)間達(dá)到30ms時(shí),即判定為一幀接收完畢
flagFrame = 1; //設(shè)置幀接收完成標(biāo)志
cntbkp = 0;
/* 串口驅(qū)動(dòng)函數(shù),監(jiān)測(cè)數(shù)據(jù)幀的接收,調(diào)度功能函數(shù),需在主循環(huán)中調(diào)用 */
void UartDriver()
unsigned char len;
unsigned char pdata buf[40];
if (flagFrame) //有命令到達(dá)時(shí),讀取處理該命令
flagFrame = 0;
len = UartRead(buf, sizeof(buf)-2); //將接收到的命令讀取到緩沖區(qū)中
UartAction(buf, len); //傳遞數(shù)據(jù)幀,調(diào)用動(dòng)作執(zhí)行函數(shù)
/* 串口中斷服務(wù)函數(shù) */
void InterruptUART() interrupt 4
if (RI) //接收到新字節(jié)
RI = 0; //清零接收中斷標(biāo)志位
if (cntRxd < sizeof(bufRxd)) //接收緩沖區(qū)尚未用完時(shí),
{ //保存接收字節(jié),并遞增計(jì)數(shù)器
bufRxd[cntRxd++] = SBUF;
if (TI) //字節(jié)發(fā)送完畢
TI = 0; //清零發(fā)送中斷標(biāo)志位
flagTxd = 1; //設(shè)置字節(jié)發(fā)送完成標(biāo)志
