查看: 4143|回復: 1
pcf8563+12864顯示萬年歷時間不動,求大神解答
ID:264663 發表于 2018-11-22 07:03 | 顯示全部樓層 |閱讀模式
#include <STC15.H>                   // 該程序具有顯示日期、月份、日期和時間功能
#include <GPIO.H>
#include<stdio.h>
#include<intrins.h>
#define uchar                 unsigned char
#define uint                 unsigned int
#define sint        signed int
#define disp_off          0x3e             //顯示關
#define disp_on           0x3f             //顯示開
#define disp_x           0xb8             //頁地址為0頁
#define disp_z           0xc0             //行地址為0行
#define disp_y           0x40             //列地址為0列
#define comm             0                     //命令標志位
#define dat1              1                     //數據標志位
//#define data_ora           P0                     //液晶12864的數據端與單片機的P0相連
sbit di =P2^0;                                         //Data or Instrument Select,H:寫數據,L:寫指令
sbit rw =P2^1;                                         //Write or Read,H:read,L:write
sbit e         =P2^4;                                         //讀寫使能
sbit cs1=P2^2;                                         //cs1=H,選擇左半屏
sbit cs2=P2^3;                                         //cs2=H,選擇右半屏
sbit clk=P1^0;                                //8563 clk
sbit dat=P1^1;                                //8563 data
sbit DS = P2^5;   //SER 串行數據
sbit SHCP= P2^6;    //SCK 串行時鐘信號
sbit STCP  = P2^7;    //ST 鎖存輸出信號
uchar fen=0x42,miao=0x38,shi=0x17,riqi=0x02,//設置時間用
yuefen=0x09,xingqi=0x00,nian=0x07,zhongduan;//設置時間用
uchar code tabma[10][16]=
//陰碼點陣格式、取模方式為列行式、逆向取模(低位在前),
//十六進制輸出,中文16*16,英文8*16 宋體
//0(0) 1(1) 2(2) 3(3) 4(4) 5(5) 6(6) 7(7) 8(8) 9(9)
{0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,
0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00},        /*"0",0*/
{0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,
0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00},        /*"1",1*/
{0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,
0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00},        /*"2",2*/
{0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,
0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00},        /*"3",3*/
{0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,
0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00},        /*"4",4*/
{0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,
0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00},        /*"5",5*/
{0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,
0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00},        /*"6",6*/
{0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,
0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00},        /*"7",7*/
{0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,
0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00},        /*"8",8*/
0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00},        /*"9",9*/
uchar code tab2ma[7][32]=
//  日(0) 一(1) 二(2) 三(3) 四(4) 五(5) 六(6)
{0x00,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,
0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x3F,0x10,0x10,0x10,0x10,
0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00},        /*"日",0*/
{0x00,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x80,0x80,0x80,0x80,0x80,0xC0,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},        /*"一",1*/
{0x00,0x00,0x04,0x04,0x04,0x04,0x04,0x04,
0x04,0x04,0x04,0x06,0x04,0x00,0x00,0x00,
0x00,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
0x10,0x10,0x10,0x10,0x10,0x18,0x10,0x00},        /*"二",2*/
{0x00,0x04,0x84,0x84,0x84,0x84,0x84,0x84,
0x84,0x84,0x84,0x84,0x84,0x04,0x00,0x00,
0x00,0x20,0x20,0x20,0x20,0x20,0x20,0x20,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00},        /*"三",3*/
{0x00,0xFE,0x02,0x02,0x02,0xFE,0x02,0x02,
0xFE,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,
0x00,0x7F,0x28,0x24,0x23,0x20,0x20,0x20,
0x21,0x22,0x22,0x22,0x22,0x7F,0x00,0x00},        /*"四",4*/
{0x00,0x02,0x82,0x82,0x82,0x82,0xFE,0x82,
0x82,0x82,0xC2,0x82,0x02,0x00,0x00,0x00,
0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,
0x20,0x20,0x3F,0x20,0x20,0x30,0x20,0x00},        /*"五",5*/
{0x10,0x10,0x10,0x10,0x10,0x91,0x12,0x1E,
0x94,0x10,0x10,0x10,0x10,0x10,0x10,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x00,
0x00,0x01,0x02,0x0C,0x78,0x30,0x00,0x00},        /*"六",6*/
uchar code nianma[]=
//年(0) 月(1) 日(2) 星(3) 期(4)
{0x40,0x20,0x10,0x0C,0xE3,0x22,0x22,0x22,
0xFE,0x22,0x22,0x22,0x22,0x02,0x00,0x00,
0x04,0x04,0x04,0x04,0x07,0x04,0x04,0x04,
0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x00};        /*"年",0*/
uchar code yuema[]=
{0x00,0x00,0x00,0x00,0x00,0xFF,0x11,0x11,
0x11,0x11,0x11,0xFF,0x00,0x00,0x00,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x01,0x01,
0x01,0x21,0x41,0x3F,0x00,0x00,0x00,0x00};        /*"月",1*/
uchar code rima[]=
0x10,0x10,0x10,0x3F,0x00,0x00,0x00,0x00};        /*"日",2*/
uchar code xingqima[]=
{0x00,0x00,0x00,0xBE,0x2A,0x2A,0x2A,0xEA,
0x2A,0x2A,0x2A,0x2A,0x3E,0x00,0x00,0x00,
0x00,0x48,0x46,0x41,0x49,0x49,0x49,0x7F,
0x49,0x49,0x49,0x49,0x49,0x41,0x40,0x00,        /*"星",3*/
0x00,0x04,0xFF,0x54,0x54,0x54,0xFF,0x04,
0x00,0xFE,0x22,0x22,0x22,0xFE,0x00,0x00,
0x42,0x22,0x1B,0x02,0x02,0x0A,0x33,0x62,
0x18,0x07,0x02,0x22,0x42,0x3F,0x00,0x00};        /*"期",4*/
//時(0) 分(1) 秒(2)
uchar code shima[]=
{0x00,0xFC,0x44,0x44,0x44,0xFC,0x10,0x90,
0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,
0x00,0x07,0x04,0x04,0x04,0x07,0x00,0x00,
0x03,0x40,0x80,0x7F,0x00,0x00,0x00,0x00};        /*"時",0*/
uchar code fenma[]=
{0x80,0x40,0x20,0x98,0x87,0x82,0x80,0x80,
0x83,0x84,0x98,0x30,0x60,0xC0,0x40,0x00,
0x00,0x80,0x40,0x20,0x10,0x0F,0x00,0x00,
0x20,0x40,0x3F,0x00,0x00,0x00,0x00,0x00};        /*"分",1*/
uchar code miaoma[]=
{0x12,0x12,0xD2,0xFE,0x91,0x11,0xC0,0x38,
0x10,0x00,0xFF,0x00,0x08,0x10,0x60,0x00,
0x04,0x03,0x00,0xFF,0x00,0x83,0x80,0x40,
0x40,0x20,0x23,0x10,0x08,0x04,0x03,0x00};        /*"秒",2*/
void delay(sint n);                                     //延時程序
void xie_start();                                            //開始條件
void xie_stop();                                                   //停止條件
bit xie1(uchar shu);                                           //向8563中寫入1個字
uchar du1();                                                           //從8563中讀出1個字
uchar du();                                                           //從8563中讀出時間和日期
uchar xie();                                                           //向8563中設置時間和日期
//uchar xie_dingshi();                                   //8563定時器設置
//uchar xie_fangbo_dingshi();                   //8563的方波設置
void delay1 (uint ms);                                   //延時
void wr_lcd (uchar dat_comm,uchar content);        //向12864中寫命令
//uchar rd_lcd ();                                                        //讀12864數據
void chk_busy ();                                                        //忙閑檢測
void lat_disp (uchar data1,uchar data2);        //寫點鐘
//void img_disp (uchar code *img) ;                        //顯示圖像
void chn_disp (uchar x,uchar y,uchar xl,uchar yl,uchar row_xl,uchar row_yl,uchar code *chn);
        //顯示漢字
void init_lcd ();                                                        //12864初始化
void disp();        //128顯示程序
void hc595SendByte(unsigned char dat)
    unsigned char i;
    for(i=0; i<8; i++)
                SHCP=0;
        DS=dat&0x80;
                _nop_();
        dat=dat<<1;
                _nop_();
        SHCP=1;
                _nop_();
                SHCP=0;
void Out595(void)
    STCP=1;
    STCP=0;
//-------------主函數--------------------
        uchar ml=0;
    init_lcd ();                                                        //LCD初始化
        lat_disp(0x00,0x00);
    xie();        //預設時間用,設置好時間后可以屏蔽
        for(;;)
                du();        //讀8563的時間
                disp();        //顯示時間
                delay1(100);
//-------------------延時---------------------------//
void delay(sint n)
        for(n;n>0;n--);
/////////////////////以下是PCF8563讀寫/////////////////////以下是PCF8563讀寫
/* I2C的起始條件,在時鐘端SCK為高電平時,數據端SDA發生由高到低的變化,為起始條件,
啟動I2C總線。程序代碼如下。 */
void xie_start()
        clk=1;
        _nop_();
        dat=1;
        _nop_();
        dat=0;
        _nop_();
        clk=0;
        _nop_();
/* I2C的停止條件,在時鐘端SCL為高電平時,數據端SDA發生由低到高的變化,
為停止條件,停止I2C總線數據傳輸。 */
void xie_stop()
        dat=0;
        _nop_();
        clk=1;
        _nop_();
        dat=1;
        _nop_();
bit xie1(uchar shu)                                      //向8563中寫入1個字
        uchar i=8;
        bit fan_w;
        clk=0;
        _nop_();
        while(i--)
                dat=(bit)(shu&0x80);                                 //取字節的最高位
                _nop_();
                shu<<=1;                                                     //字節左移一位
                clk=1;                                                             //上升沿鎖存數據
                _nop_();
                clk=0;
                _nop_();
        dat=1;
        _nop_();
        clk=1;
        _nop_();
        fan_w=dat;                                                    //讀應答信號
        clk=0;
        _nop_();
        return(fan_w);                                                //返回應答信號
uchar du1()                                                        //從8563中讀出1個字
        uchar shu=0;
        uchar data rdata;
        uchar i=8;
        while(i--)
                rdata<<=1;                                                    //字節左移一位
                dat=1;
                clk=1;_nop_();                                          //上升沿鎖存數據
                if(dat) rdata|=0x01;                                  //數據線為1時 對應位存1
                clk=0;_nop_();
        shu=rdata;                                                          //讀到的數據存于SHU
        return(shu);                                                         //返回讀到的數據
uchar du()
        EA=0;        //關總中斷
        xie_start();                                                         //起始條件
        if(xie1(0xa2)!=0){xie_stop();return(0);}//取器件地址 寫
        if(xie1(0x02)!=0){xie_stop();return(0);}//取讀時間的首字節地址從秒開始讀
        xie_start();                                                         //起始條件
        if(xie1(0xa3)!=0){xie_stop();return(0);}//取器件地址 讀
        miao=du1()&0x7f;                                                //讀秒 屏蔽最高位
        xie_stop();        //停止條件
        xie_start();                                         //起始條件
        if(xie1(0x03)!=0){xie_stop();return(0);}//取讀分鐘字節地址
        xie_start();                                                         //起始條件
        fen=du1()&0x7f;                                        //讀分 屏蔽最高位
        xie_stop();        //停止條件
        xie_start();                                          //起始條件
        if(xie1(0x04)!=0){xie_stop();return(0);}//取讀小時字節地址
        xie_start();                                          //起始條件
        shi=du1();                                                 //讀時
        shi&=0x3f;        //屏蔽最高2位
        xie_stop();        //停止條件
        xie_start();                                          //起始條件
        if(xie1(0xa2)!=0){xie_stop();return(0);}//寫
        if(xie1(0x05)!=0){xie_stop();return(0);}//取讀日期字節地址
        xie_start();                                          //起始條件
        if(xie1(0xa3)!=0){xie_stop();return(0);}//讀
        riqi=du1();        //讀日期
        riqi&=0x3f;        //屏蔽最高2位
        xie_stop();        //停止條件
        xie_start();                                    //起始條件
        if(xie1(0x07)!=0){xie_stop();return(0);}//取讀月份字節地址
        xie_start();                                          //起始條件
        yuefen=du1();                                                        //讀月份
        yuefen&=0x1f;                                                        //屏蔽最高3位
        xie_stop();        //停止條件
        xie_start();                                          //起始條件
        if(xie1(0x06)!=0){xie_stop();return(0);}//星期字節地址
        xie_start();                                          //起始條件
        xingqi=du1();                                                        //讀星期
        xingqi&=0x07;                                                        //保留低3位
        xie_stop();        //停止條件
        xie_start();                                          //起始條件
        if(xie1(0x08)!=0){xie_stop();return(0);}//年份字節地址
        xie_start();                                          //起始條件
        nian=du1();        //讀年份
        xie_stop();        //停止條件
        EA=1;        //開總中斷
        return(1);
uchar xie()
        EA=0;
        xie_start();                                           //起始條件
        if(xie1(0x02)!=0){xie_stop();return(0);}//寫秒地址
        if(xie1(miao)!=0){xie_stop();return(0);}//寫秒
        xie_stop();        //停止條件
        xie_start();                                    //起始條件
        if(xie1(0x03)!=0){xie_stop();return(0);}//寫分地址
        if(xie1(fen)!=0){xie_stop();return(0);}        //寫分
        xie_stop();
        xie_start();                                     //起始條件
        if(xie1(0x04)!=0){xie_stop();return(0);}//寫小時地址
        if(xie1(shi)!=0){xie_stop();return(0);}        //寫時
        xie_stop();
        xie_start();                                          //寫日期
        if(xie1(riqi)!=0){xie_stop();return(0);}
        xie_stop();
        xie_start();                                          //寫月份
        if(xie1(yuefen)!=0){xie_stop();return(0);}
        xie_stop();
        xie_start();                                          //寫星期
        if(xie1(xingqi)!=0){xie_stop();return(0);}
        xie_stop();
    xie_start();                                          //寫年份
        if(xie1(nian)!=0){xie_stop();return(0);}
        xie_stop();
        EA=1;
        return(1);
/* uchar xie_dingshi()                              //定時器
        xie_start();                                          // 控制中斷開關
        if(xie1(0x01)!=0){xie_stop();return(0);}
        xie_start();                                          //定時器控制器
        if(xie1(0x0e)!=0){xie_stop();return(0);}
        if(xie1(0x82)!=0){xie_stop();return(0);}
        xie_start();                                          //計數器
        if(xie1(0x0f)!=0){xie_stop();return(0);}
        if(xie1(5)!=0){xie_stop();return(0);}
        xie_stop();
        return(1);
/* uchar xie_fangbo_dingshi()
        xie_start();                                          //方波頻率
        if(xie1(0x0d)!=0){xie_stop();return(0);}
        xie_stop();
        return(1);
/////////////////////以上是PCF8563讀寫/////////////////////以上是PCF8563讀寫
/*---------------延時子程序----------------*/
        uint i,j;
        for(i=0;i<ms;i++)
                for(j=0;j<1000;j++);
/*------------寫數據或命令到LCD--------------*/
        chk_busy ();                                //
        di=dat_comm;                                //命令標志
        rw=0;         //寫
        hc595SendByte(content);
  Out595();        //寫數據到LCD的數據端
        e=1;                                                            //下降沿鎖定數據
        e=0;
/*--------------讀LCD數據---------------*/
/* uchar rd_lcd ()
        uchar rddata;
        chk_busy ();
        di=1;
        rw=1;                                                      //讀
        e=1;
        rddata=data_ora;                                //讀數據
        e=0;                                                           //下降沿鎖定數據
        return rddata;
void chk_busy()
        hc595SendByte(1);
        Out595();                                        //寫1到LCD的數據端
        di=0;
        rw=1;                                                      //讀
        e=1;
        //while(bf||res==1);
        e=0;
/*--------------寫點陣------------------*/
        uchar i,j;
        cs1=1;cs2=1;                                     //左右屏幕同時選中
        wr_lcd (comm,disp_on);                   //寫命令字,顯示開
        for(j=0;j<8;j++)
                wr_lcd (comm,disp_x+j);          //頁地址調整
                wr_lcd (comm,disp_z);                  //指向對應頁的0行
                wr_lcd (comm,disp_y);                  //指向對應頁的0列
                for(i=0;i<32;i++)                          //寫64個數據
                        wr_lcd (dat1,data1);
                        wr_lcd (dat1,data2);
/*--------------顯示圖片----------------*/
/* void img_disp (uchar code *img)
        uchar i,j;
        for(j=0;j<8;j++)
                cs1=0;cs2=1;                                            //左半屏幕選中
                for(i=0;i<64;i++)                                          //寫64個數據
                        wr_lcd (dat1,img[j*128+i]);
                cs1=1;cs2=0;                                                   //右半屏幕選中
                for(i=64;i<128;i++)                                 //寫64個數據
/*---指定位置(x,y)顯示row_xl行(每行row_yl個)漢字(大小8xl*yl)---*/
        uchar i,j,k,l,a;
        for(l=0;l<row_xl;l++)                                                //行數循環
                for(k=0;k<row_yl;k++)                                        //字數循環
                        for(j=0;j<xl;j++)
                                wr_lcd (comm,disp_x+x+l*xl+j);        //行數調整
                                wr_lcd (comm,disp_z);                        //列數調整
                                wr_lcd (comm,disp_y+y+k*yl);        //字數調整
                                a=l*xl*yl*row_yl+k*xl*yl+j*yl;
                                for(i=0;i<yl;i++)                                //寫數據
                                wr_lcd (dat1,chn[a+i]);
/*------------------初始化-----------------*/
void init_lcd ()
        //rst=0;
        delay(50);
        //rst=1;
        wr_lcd (comm,disp_off);                                           //寫命令字,顯示關
void disp()
        chn_disp (0,8,2,8,1,1,tabma[2]);                        //固定顯示數字“2”
        chn_disp (0,16,2,8,1,1,tabma[0]);                        //固定顯示數字“0”
        chn_disp (0,24,2,8,1,1,tabma[nian/16]);                //顯示年的數字十位
        chn_disp (0,32,2,8,1,1,tabma[nian%16]);                //顯示年的數字個位
        chn_disp (0,40,2,16,1,1,nianma);                        //固定顯示漢字“年”
        chn_disp (0,56,2,8,1,1,tabma[yuefen/16]);        //顯示月份的數字十位
        chn_disp (0,0,2,8,1,1,tabma[yuefen%16]);        //顯示月份的數字個位
        chn_disp (0,8,2,16,1,1,yuema);                                //固定顯示漢字“月”
        chn_disp (0,24,2,8,1,1,tabma[riqi/16]);                //顯示日期的數字十位
        chn_disp (0,32,2,8,1,1,tabma[riqi%16]);                //顯示日期的數字個位
        chn_disp (0,40,2,16,1,1,rima);                                //固定顯示漢字“日”
        chn_disp (3,8,2,16,1,2,xingqima);                        //固定顯示漢字“星期”
        chn_disp (3,40,2,16,1,1,tab2ma[xingqi]);        //顯示漢字星期幾
        chn_disp (6,16,2,8,1,1,tabma[shi/16]);                //顯示小時的數字十位
        chn_disp (6,24,2,8,1,1,tabma[shi%16]);                //顯示小時的數字個位
        chn_disp (6,32,2,16,1,1,shima);                                //固定顯示漢字“時”
        chn_disp (6,48,2,8,1,1,tabma[fen/16]);                //顯示分鐘的數字十位
        chn_disp (6,56,2,8,1,1,tabma[fen%16]);                //顯示分鐘的數字個位
        chn_disp (6,0,2,16,1,1,fenma);                                //固定顯示漢字“分”
        chn_disp (6,16,2,8,1,1,tabma[miao/16]);                //顯示秒的數字十位
        chn_disp (6,24,2,8,1,1,tabma[miao%16]);                //顯示秒的數字個位
        chn_disp (6,32,2,16,1,1,miaoma);                        //固定顯示漢字“秒”
ID:303383 發表于 2018-11-26 23:37 | 顯示全部樓層
提示: 作者被禁止或刪除 內容自動屏蔽
