查看: 1496|回復: 0
簡易時鐘代碼供參考
ID:430893 發(fā)表于 2018-11-21 22:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit rs=P3^5;
sbit lcden=P3^4;
sbit s1=P3^0;
sbit s2=P3^1;
sbit s3=P3^2;
sbit rd=P3^7;
uchar count,s1num;
char miao,shi,fen;
uchar code table[]="  2018-11-20 MON";
uchar code table1[]="    00:00:00";
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void write_com(uchar com)
rs=0;
lcden=0;
P0=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
lcden=0;
P0=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
dula=0;
wela=0;
lcden=0;
// fen=59;
// miao=53;
// shi=23;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
for(num=0;num<16;num++)
   write_date(table[num]);
   delay(5);
write_com(0x80+0x40);
for(num=0;num<12;num++)
   write_date(table1[num]);
   delay(5);
TMOD=0x01;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void write_sfm(uchar add,uchar date)
uchar shi,ge;
shi=date/10;
ge=date%10;
write_com(0x80+0x40+add);
write_date(0x30+shi);
write_date(0x30+ge);
void keyscan()
rd=0;
if(s1==0)
  delay(5);
  if(s1==0)
  { s1num++;
   while(!s1);
   if(s1num==1)
    TR0=0;
    write_com(0x80+0x40+10);
    write_com(0x0f);
   if(s1num==2)
    write_com(0x80+0x40+7);
   if(s1num==3)
    write_com(0x80+0x40+4);
   if(s1num==4)
    s1num=0;
    write_com(0x0c);
    TR0=1;
  if(s1num!=0)
   if(s2==0)
    delay(5);
    if(s2==0)
     while(!s2);
     if(s1num==1)
      miao++;
      if(miao==60)
       miao=0;
      write_sfm(10,miao);
     if(s1num==2)
      fen++;
      if(fen==60)
       fen=0;
      write_sfm(7,fen);
     if(s1num==3)
      shi++;
      if(shi==24)
       shi=0;
      write_sfm(4,shi);
   if(s3==0)
    delay(5);
    if(s3==0)
     while(!s3);
     if(s1num==1)
     /* if(miao==0)
       miao=59;
       write_sfm(10,miao);
      miao--;
      if(miao==-1)
       miao=59;
      write_sfm(10,miao);
     if(s1num==2)
      fen--;
      if(fen==-1)
       fen=59;
      write_sfm(7,fen);
     if(s1num==3)
      shi--;
      if(shi==-1)
       shi=23;
      write_sfm(4,shi);
init();
  keyscan();
// while(1);
void timer0() interrupt 1
count++;
if(count==18)
   count=0;
   miao++;
   if(miao==60)
    miao=0;
    fen++;
    if(fen==60)
     fen=0;
     shi++;
     if(shi==24)
      shi=0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
