STM32采集卡程序,需要自取
STM32F103C8T6與ADS1256連線說(shuō)明
F103C8T6開(kāi)發(fā)板GPIOB11 --- ADS1256板子RESET 相連
F103C8T6開(kāi)發(fā)板GPIOB10 --- ADS1256板子 DRDY 相連
F103C8T6開(kāi)發(fā)板GPIOB12 --- ADS1256板子CS 相連
F103C8T6開(kāi)發(fā)板GPIOB13 --- ADS1256板子SCLK 相連
F103C8T6開(kāi)發(fā)板GPIOB14 --- ADS1256板子DOUT 相連
F103C8T6開(kāi)發(fā)板GPIOB15 --- ADS1256板子DIN 相連
F103C8T6開(kāi)發(fā)板GND --- ADS1256板子DGND 相連
實(shí)際測(cè)試連線圖
單片機(jī)源程序如下:
- #include "stm32f10x.h"
- #include "stm32_eval.h"
- #include "flash.h"
- #include "delay.h"
- #include "ADS1256.h"
- #include <stdio.h>
- /** @addtogroup STM32F10x_StdPeriph_Examples
- /** @addtogroup USART_Printf
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- /* Values magic to the Board keys */
- #define NOKEY 0
- #define KEY1 1
- #define KEY2 2
- #define KEY3 3
- #define KEY4 4
- unsigned char data[16];
- /* Private function prototypes -----------------------------------------------*/
- #ifdef __GNUC__
- /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
- set to 'Yes') calls __io_putchar() */
- #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
- #endif /* __GNUC__ */
- /* Private functions ---------------------------------------------------------*/
- void Init_UART2()
- USART_InitTypeDef USART_InitStructure;
- /* USARTx configured as follow:
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- USART_InitStructure.USART_BaudRate = 9600;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- STM_EVAL_COMInit(COM1, &USART_InitStructure);
- * @brief Main program
- * @param None
- * @retval None
- int main(void)
- unsigned char i=0;
- long ulResult;
- long double ldVolutage;
- Init_UART2();
- Init_ADS1256_GPIO(); //初始化ADS1256 GPIO管腳
- Delay(0x1ffFF);
- GPIO_SetBits(GPIOB, GPIO_Pin_11 );
- ADS1256_Init();
- while(1)
- for(i = 0;i < 8;i++)
- ulResult = ADS_sum( (i << 4) | ADS1256_MUXN_AINCOM);
- //ulResult = ADS_sum( ADS1256_MUXP_AIN0 | ADS1256_MUXN_AINCOM);
- if( ulResult & 0x800000 )
- ulResult = ~(unsigned long)ulResult;
- ulResult &= 0x7fffff;
- ulResult += 1;
- ulResult = -ulResult;
- ldVolutage = (long double)ulResult*0.59604644775390625;
- printf("第%d通道:",(i & 0x07)?(i & 0x07) - 1:7);
- printf("%lf",ldVolutage); //double
- printf("uV\r");
- //printf("%x",(unsigned long)ulResult);//16
- Delay(0x3fFFF);
- printf("\n");
- // printf("123456\n");
- * @brief Retargets the C library printf function to the USART.
- * @param None
- * @retval None
- PUTCHAR_PROTOTYPE
- /* Place your implementation of fputc here */
- /* e.g. write a character to the USART */
- USART_SendData(EVAL_COM1, (uint8_t) ch);
- /* Loop until the end of transmission */
- while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
- return ch;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /******************* (C) COPYRIGHT 2010 STMicroelectronics *****END OF FILE****/
STM32F103C8T6測(cè)試OK.rar
(5.14 MB, 下載次數(shù): 185)
2018-11-21 18:02 上傳
點(diǎn)擊文件名下載附件
