我給你來個DS18B20程序試試
- #include <reg52.H>
- #include <intrins.H>
- #include <math.H>
- #define uchar unsigned char
- #define uint unsigned int
- sbit dula = P2^6;
- sbit wela = P2^7;
- sbit rw = P3^6;
- sbit RS = P3^5;
- sbit LCDEN = P3^4;
- void delayUs()
- _nop_();
- void delayMs(uint a)
- uint i, j;
- for(i = a; i > 0; i--)
- for(j = 100; j > 0; j--);
- void writeComm(uchar comm)
- RS = 0;
- P0 = comm;
- LCDEN = 1;
- delayUs();
- LCDEN = 0;
- delayMs(1);
- //寫數據:RS=1, RW=0;
- void writeData(uchar dat)
- RS = 1;
- P0 = dat;
- LCDEN = 1;
- delayUs();
- LCDEN = 0;
- delayMs(1);
- void init()
- rw = 0;
- dula = wela = 0;
- writeComm(0x38);
- writeComm(0x0c);
- writeComm(0x06);
- writeComm(0x01);
- void writeString(uchar * str, uchar length)
- uchar i;
- for(i = 0; i < length; i++)
- writeData(str[i]);
- /**//*****************************DS18B20*******************************/
- sbit ds = P2^2;
- void dsInit()
- unsigned int i;
- ds = 0;
- i = 100;
- while(i>0) i--;
- ds = 1;
- i = 4;
- while(i>0) i--;
- void dsWait()
- unsigned int i;
- while(ds);
- while(~ds);
- i = 4;
- while(i > 0) i--;
- bit readBit()
- unsigned int i;
- bit b;
- ds = 0;
- i++;
- ds = 1;
- i++; i++;
- b = ds;
- i = 8;
- while(i>0) i--;
- return b;
- unsigned char readByte()
- unsigned int i;
- unsigned char j, dat;
- dat = 0;
- for(i=0; i<8; i++)
- j = readBit();
- dat = (j << 7) | (dat >> 1);
- return dat;
- void writeByte(unsigned char dat)
- unsigned int i;
- unsigned char j;
- bit b;
- for(j = 0; j < 8; j++)
- b = dat & 0x01;
- dat >>= 1;
- if(b)
- ds = 0; i++; i++;
- ds = 1;
- i = 8; while(i>0) i--;
- else
- ds = 0;
- ds = 1;
- i++; i++;
- void sendChangeCmd()
- dsInit();
- dsWait();
- delayMs(1);
- writeByte(0xcc);
- writeByte(0x44);
- void sendReadCmd()
- dsInit();
- dsWait();
- delayMs(1);
- writeByte(0xcc);
- writeByte(0xbe);
- int getTmpValue()
- unsigned int tmpvalue;
- int value;
- float t;
- unsigned char low, high;
- sendReadCmd();
- low = readByte();
- high = readByte();
- tmpvalue = high;
- tmpvalue <<= 8;
- tmpvalue |= low;
- value = tmpvalue;
- t = value * 0.0625;
- value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0減0.5
- return value;
- void display(int v)
- unsigned char count;
- unsigned char datas[] = {0, 0, 0, 0, 0};
- unsigned int tmp = abs(v);
- datas[0] = tmp / 10000;
- datas[1] = tmp % 10000 / 1000;
- datas[2] = tmp % 1000 / 100;
- datas[3] = tmp % 100 / 10;
- datas[4] = tmp % 10;
- writeComm(0xc0+3);
- if(v < 0)
- writeString("- ", 2);
- else
- writeString("+ ", 2);
- if(datas[0] != 0)
- writeData('0'+datas[0]);
- for(count = 1; count != 5; count++)
- writeData('0'+datas[count]);
- if(count == 2)
- writeData('.');
- void main()
- uchar table[] = " xianzaiwendu: ";
- sendChangeCmd();
- init();
- writeComm(0x80);
- writeString(table, 16);
- while(1)
- delayMs(1000); //溫度轉換時間需要750ms以上
- writeComm(0xc0);
- display(getTmpValue());
- sendChangeCmd();
復制代碼 |
