查看: 4176|回復(fù): 0
一個基于單片機的秒表出現(xiàn)的問題,求高手解答~~~~
ID:37990 發(fā)表于 2012-4-7 16:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit b=P2^3;
sbit key1=P3^4;
sbit key2=P3^5;
uchar aa;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f};
uchar code table1[]={
 0xBF,0x86,0xDB,0xCF,0xE6,
0xED,0xFD,0x87,0xFF,0xEF};
uchar time[]={0,0,0,0,0,0};
 void delay(uint z)
	uint x,y;
	for(x=z;x>0;x--)
		for(y=120;y>0;y--);
void init()
    TMOD=0x01;
	TH0=(65536-1000)/256;
	TL0=(65536-1000)%256;
void display()
        dula=1;
		P0=table[time[0]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xdf;
		wela=0;
		delay(1);
		dula=1;
		P0=table[time[1]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xef;
		wela=0;
		delay(1);
		dula=1;
		P0=table1[time[2]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xf7;
		wela=0;
		delay(1);
		 dula=1;
		P0=table[time[3]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xfb;
		wela=0;
		delay(1);
		dula=1;
		P0=table1[time[4]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xfd;
		wela=0;
		delay(1);
		dula=1;
		P0=table[time[5]];
		dula=0;
		P0=0xff;
		wela=1;
		P0=0xfe;
		wela=0;
		delay(1);
		if(aa==1)
 aa=0; time[0]++;
   if(time[0]==10)
 {time[0]=0;time[1]++;
     if(time[1]==10)
	  {time[1]=0;time[2]++;
 	     if(time[2]==10)
	     {time[2]=0;time[3]++;
		   if(time[3]==6)
	        {time[3]=0;time[4]++;
		      if(time[4]==10)
			   {time[4]=0;time[5]++;
			    if(time[5]==6)
	              {time[5]=0;time[6]++;}}}}}
 void keyscan()
 if(key1==0)
delay(5);
if(key1==0)
	{	b=0;
     EA=~EA;
	ET0=~ET0;
	TR0=~TR0;
	while(!key1);
b=1;
if(key2==0)
delay(5);
if(key2==0)
	{	b=0;
     	time[0]=time[1]=time[2]=time[3]=time[4]=time[5]=0;
	while(!key2);
b=1;
 init();
while(1) {keyscan();
display();}
void timer0() interrupt 1
	aa++;
這是我用51單片機寫的秒表程序,其他很正常,就是秒表太不準了,本該顯示微秒的數(shù)碼管變化的時間一秒差不多,這是怎么回事啊。。。
