GSM 遠程控制密碼鎖的設(shè)計的工程文件程序(C語言編寫),詳情見附件,歡迎評論,51單片機制作
- #include <reg52.h> //調(diào)用單片機頭文件
- #define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
- uchar value,i; //變量
- #include "lcd1602.h"
- #include "iic.h"
- uchar flag_lj_en; //邊加
- uchar flag_lj_en_value;
- sbit relay = P2^2; //繼電器定義
- sbit beep = P3^3; //蜂鳴器定義
- sbit beiguang = P2^3; //背光
- //sbit red = P2^4;
- uint flag_time;
- uint flag_guan;
- sbit VBUSY= P3^4; //語音模塊IO口定義
- sbit VSDA = P3^5;
- sbit VCS = P3^6;
- sbit VSCL = P3^7;
- uchar lcd_i;
- uchar dis_lcd[7]={0};
- uchar dis_smg[11];
- uchar idata password1[7]={3,2,1,3,2,1}; //密碼保存
- uchar idata password_bj[7]={1,2,3,4,5,6}; //密碼比較
- uchar code password_r1[6] = {3,2,1,3,2,1} ;
- uchar code password_gl[6] = {5,2,0,0,2,5} ;
- uchar idata password_xg[6]; //密碼修改
- uchar flag_password; //密碼正確否
- uchar flag_password_cichu1;//密碼錯誤次數(shù)
- bit flag_200ms=1; //200ms標志位
- uchar phone1_i = 0; //電話號碼是多少位
- uchar phone1_call[11]={1,8,3, 2,4,1,3, 1,8,3,2};
- uchar key_can; //鍵值
- uchar flag_mm1; //判斷密碼是否正確
- uchar flag_en1;
- uchar menu_1;
- char menu_i ;
- uchar smg_i;
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***************把數(shù)組清空**********************/
- void clear1_shuzu(uchar *p,uchar num)
- for(i=0;i<num;i++)
- p[i] = ' ';
- #include "iic.h"
- #include "gsm.h"
- void key() //獨立按鍵程序
- static uchar key_new = 0, key_l;
- key_can = 20; //按鍵值還原
- P1 = 0x0f;
- if((P1 & 0x0f) != 0x0f) //按鍵按下
- delay_1ms(1); //按鍵消抖動
- if(((P1 & 0x0f) != 0x0f) && (key_new == 1))
- { //確認是按鍵按下
- key_new = 0; //清零
- key_l = (P1 | 0xf0); //矩陣鍵盤掃描
- P1 = key_l; //讀P1端口的值
- switch(P1)
- case 0xee: key_can = 10; break; //得到按鍵值
- case 0xde: key_can = 7; break; //得到按鍵值
- case 0xbe: key_can = 4; break; //得到按鍵值
- case 0x7e: key_can = 1; break; //得到按鍵值
- case 0xed: key_can = 0; break; //得到按鍵值
- case 0xdd: key_can = 8; break; //得到按鍵值
- case 0xbd: key_can = 5; break; //得到按鍵值
- case 0x7d: key_can = 2; break; //得到按鍵值
- case 0xeb: key_can = 3; break; //得到按鍵值
- case 0xdb: key_can = 6; break; //得到按鍵值
- case 0xbb: key_can = 9; break; //得到按鍵值
- case 0x7b: key_can = 11; break; //得到按鍵值
- case 0xe7: key_can = 15; break; //得到按鍵值
- case 0xd7: key_can = 14; break; //得到按鍵值
- case 0xb7: key_can = 13; break; //得到按鍵值
- case 0x77: key_can = 12; break; //得到按鍵值
- beep = 0;
- delay_1ms(20);
- beep = 1;
- else
- key_new = 1; //無鍵按下
- flag_lj_en = 0;
- void write_mm() //保存密碼
- write_24c02_8(6,0,password1);
- write_24c02(30,phone1_call[0]) ;
- write_24c02(31,phone1_call[1]) ;
- write_24c02(32,phone1_call[2]) ;
- write_24c02(33,phone1_call[3]) ;
- write_24c02(34,phone1_call[4]) ;
- write_24c02(35,phone1_call[5]) ;
- write_24c02(36,phone1_call[6]) ;
- write_24c02(37,phone1_call[7]) ;
- write_24c02(38,phone1_call[8]) ;
- write_24c02(39,phone1_call[9]) ;
- write_24c02(40,phone1_call[10]) ;
- write_24c02(58,phone1_i) ;
- void read_mm() //讀出密碼
- read_24c02_8(6,0,password1);
- phone1_call[0] = read_24c02(30);
- phone1_call[1] = read_24c02(31);
- phone1_call[2] = read_24c02(32);
- phone1_call[3] = read_24c02(33);
- phone1_call[4] = read_24c02(34);
- phone1_call[5] = read_24c02(35);
- phone1_call[6] = read_24c02(36);
- phone1_call[7] = read_24c02(37);
- phone1_call[8] = read_24c02(38);
- phone1_call[9] = read_24c02(39);
- phone1_call[10] = read_24c02(40);
- phone1_i = read_24c02(58);
- void clear_shuzu(uchar *p)
- for(i=0;i<8;i++)
- p[i] = 0;
- /*************定時器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X01; //定時器0、工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- /***********************語音子程序************************/
- void Send_threelines(unsigned char addr)
- unsigned char i;
- VCS=0;
- for(i=0;i<8;i++)
- VSCL=0;
- if(addr&0x80)
- VSDA=1;
- else
- VSDA=0;
- addr>>=1;
- VSCL=1;
- VCS=1;
- /****************按鍵功能處理********************/
- void key_with()
- static uchar value;
- if(key_can == 14) //手動關(guān)閉密碼鎖
- relay = 1;
- clear_shuzu(password_bj); //清空報警
- clear_shuzu(password_xg);
- clear_shuzu(dis_lcd);
- if(key_can == 10) //還原密碼
- flag_lj_en = 1; //連加使能
- flag_lj_en_value = 0;
- if(menu_1 == 0)
- if(key_can <= 9)
- if(menu_i < 6) //密碼輸入
- menu_i ++;
- if(menu_i > 6)
- menu_i = 6;
- lcd_i = menu_i;
- for(i=6;i>0;i--)
- password_bj[i] = password_bj[i-1]; //依次裝入密碼比較數(shù)組
- password_bj[0] = key_can;
- for(i=0;i<lcd_i;i++)
- dis_lcd[i] ='*';// 顯示占位符*
- write_string(2,7,dis_lcd);
- lcd1602_guangbiao(1,7 + menu_i + 0x40); //開光標
- if(key_can == 11) //密碼刪除
- if(menu_i != 0)
- for(i=0;i<menu_i;i++)
- password_bj[i] = password_bj[i+1]; //依次從比較數(shù)組中取出密碼
- menu_i --;
- password_bj[menu_i] = ' '; //清除占位符
- dis_lcd[menu_i] = ' ';
- if(key_can == 15) //確認鍵
- value = 0;
- for(i=0;i<6;i++)
- if(password_bj[i] == password_gl[i]) //判斷管理員密碼
- value ++;
- if(value >= 6) //密碼正確
- write_string(2,0," return ");
- beep = 0;
- write_24c02(10,value);
- delay_1ms(200);
- write_24c02_8(6,0,password_r1);
- delay_1ms(200);
- read_mm(); //讀出密碼
- delay_1ms(2000);
- beep = 1;
- if(value < 6)
- for(i=0;i<6;i++)
- if(password_bj[i] == password1[i])
- flag_password = 1 ; //密碼正確
- else
- flag_password = 0; //密碼錯誤
- flag_password_cichu1 ++; //密碼錯誤次數(shù)
- write_string(1,0," Password error ");
- write_string(2,0," cishu: ");
- write_sfm2(2,9,flag_password_cichu1);
- delay_1ms(280);
- for(i=0;i<6;i++)
- beep = ~beep; //提示三聲
- delay_1ms(200);
- beep = 1;
- //發(fā)送短信
- send_PUD_fdbj(); //發(fā)送報警信息 請注意!密碼錯誤!
- delay_1ms(800);
- break; //密碼不正確
- for(i=0;i<6;i++)
- dis_lcd[i] = 0xbf;
- if(flag_password == 1) //密碼正確
- flag_password_cichu1 = 0;
- relay = 0; //打開密碼鎖
- write_string(2,0," Input: Open ");
- delay_1ms(1500);
- clear_shuzu(password_bj); //數(shù)據(jù)清空
- write_string(1,0," Password Lock ");
- write_string(2,0," Input: ");
- lcd1602_guangbiao(1,7+0x40); //開光標
- menu_i = 0;
- #include "menu.h"
- /****************修改密碼********************/
- void xiugai_password()
- /*******************修改密碼******************/
- if(menu_2 == 1)
- if(menu_3 == 1) //第一次輸入修改的密碼
- if(key_can <= 9)
- if(menu_i < 6)
- menu_i ++;
- if(menu_i > 6)
- menu_i = 6;
- lcd_i = menu_i;
- for(i=5;i>0;i--)
- dis_lcd[i] ='*';
- write_string(1,7,dis_lcd);
- lcd1602_guangbiao(1,7 + menu_i); //開光標
- if(key_can == 11) //刪除鍵
- if(menu_i != 0)
- menu_i --;
- if(key_can == 15) //確定鍵
- lcd1602_guangbiao(1,7 + 0x40); //開光標
- menu_3 = 2;
- menu_i = 0;
- key_can = 20;
- if(menu_3 == 2) //第二次輸入修改的密碼
- if(key_can <= 9)
- if(menu_i < 6)
- menu_i ++;
- if(menu_i > 6)
- menu_i = 6;
- for(i=5;i>0;i--)
- password_xg[i] = password_xg[i-1];
- password_xg[0] = key_can;
- dis_lcd[i] ='*';//0x30 + password_xg[i];
- if(menu_i != 0)
- password_xg[i] = password_xg[i+1];
- menu_i --;
- password_xg[menu_i] = ' ';
- if((key_can == 15)) //確定鍵
- for(i=0;i<6;i++)
- if((password_bj[i] == password_xg[i]) && (menu_i >3 ))
- flag_password = 1; //兩次輸入的密碼一樣
- else
- write_string(1,0," Password Error ");
- write_string(2,0," reenter ");
- delay_1ms(300);
- Send_threelines(104); //語音
- for(i=0;i<6;i++)
- delay_1ms(300);
- beep = 1;
- delay_1ms(1000);
- break; //密碼不正確
- if(flag_password == 1) //兩次輸入的密碼一樣的
- for(i=0;i<6;i++)
- if(menu_1 == 1)
- password1[i] = password_bj[i]; //保存密碼
- write_string(1,0," Password ");
- if(menu_1 == 1)
- write_string(2,0," Succeed ");
- Send_threelines(111); //語音
- write_mm(); //保存密碼
- beep = 0;
- delay_1ms(2000);
- beep = 1;
- read_mm(); //讀出密碼
- menu_1 = 0;
- menu_2 = 0;
- menu_3 = 0;
- menu_i = 0;
- if((menu_1 != 0) && (menu_1 != 0))
- key_with1();
- if(key_can == 13) //修改密碼
- if((menu_1 == 0))
- key_sure_1(); // 確定鍵
- menu_1 = 1;
- menu_i = 0;
- /******************輸入手機號碼**********************/
- if(menu_1 == 2)
- if(key_can < 10) //只有數(shù)字鍵
- if(phone1_i < 11)
- phone1_call[phone1_i] = key_can;
- dis_smg[phone1_i] = 0x30 + key_can;
- phone1_i ++;
- if(phone1_i > 11)
- phone1_i = 11;
- write_string_num(2,0,dis_smg,phone1_i); //顯示號碼
- lcd1602_guangbiao(1,0 + phone1_i + 0x40); //開光標
- if(phone1_i != 0)
- phone1_i --;
- phone1_call[phone1_i] = ' ';
- dis_smg[phone1_i] = ' ';
- write_string(2,0," ");
- /******************主程序**********************/
- void main()
- static uint value ; //靜態(tài)變量
- beiguang = 0;
- delay_1ms(150);
- P0 = P1 = P2 = P3 = 0xff; //初始化單片機IO口為高電平
- time_init(); //定時器初始化
- init_1602();
- write_string(1,0," Init GSM ");
- beiguang = 0;
- beep = 0; //開機叫一聲
- init_uart(); //串口初始化
- delay_1ms(100);
- beep = 1; //開機叫一聲
- for(i=0;i<6;i++) //叫三聲說明已經(jīng)初始化
- beep = ~beep; //叫三聲
- delay_1ms(200);
- init_1602();
- delay_1ms(500);
- while(1)
- if(flag_password_cichu1 < 3) //錯誤三次按鍵不能用了
- key(); //按鍵函數(shù)
- if(key_can < 20)
- if(beiguang == 0)
- if(menu_1 == 0)
- key_with(); //按鍵處理函數(shù)
- xiugai_password(); //修改密碼
- else
- beiguang = 0;
- flag_time = 0;
- if(flag_200ms == 1)
- flag_200ms = 0;
- message_kaiguanmen(); //用短信接收處理函數(shù)
- if(beiguang == 0) //延時關(guān)閉鎖30秒關(guān)閉背光
- flag_time ++;
- if(flag_time >= 5 * 30) //30秒
- flag_time = 0;
- beiguang = 1; //關(guān)閉背光
- if(relay == 0) //延時關(guān)閉鎖
- flag_guan++;
- if(flag_guan >= 5 * 20) //20秒
- flag_guan = 0;
- relay = 1; //關(guān)閉密碼鎖
- flag_en1 = 0;
- }else
- flag_guan = 0;
- if(flag_password_cichu1 >= 3)
- value ++; //200ms
- beep = ~beep; //蜂鳴器報警
- if(value >= 5 * 60 * 2) //2分鐘
- value = 0;
- beep = 1;
- delay_1ms(1);
- /*************定時器0中斷服務(wù)程序***************/
- void time0_int() interrupt 1
- TH0 = 0x4c;
- TL0 = 0x00; // 50ms 12M
- value ++;
- if(value % 4 == 0)
- flag_200ms = 1;
程序.rar
(71.14 KB, 下載次數(shù): 28)
2018-11-20 23:46 上傳
GSM遠程控制密碼鎖設(shè)計 下載積分: 黑幣 -5
