查看: 1248|回復: 0
hip4082 datasheet下載
ID:429190 發(fā)表于 2018-11-19 14:15 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
hip4082 datasheet
Features
• Independently Drives 4 N-Channel FET in Half Bridge or
Full Bridge Configurations
• Bootstrap Supply Max Voltage to 95VDC
• Drives 1000pF Load in Free Air at 50°C with Rise and Fall
Times of Typically 15ns
• User-Programmable Dead Time (0.1 to 4.5s)
• DIS (Disable) Overrides Input Control and Refreshes
Bootstrap Capacitor when Pulled Low
• Input Logic Thresholds Compatible with 5V to 15V Logic
Levels
• Shoot-Through Protection
• Undervoltage Protection
• Pb-Free Plus Anneal Available (RoHS Compliant)
hip4082.pdf
687.33 KB, 下載次數: 8, 下載積分: 黑幣 -5
