#include <reg51.h>
#define ulong unsigned long
uchar code table8[]={0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87,0x88,0x89}; //最左邊顯示0-9
uchar code table7[]={0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97,0x98,0x99}; //左邊倒數(shù)第二
uchar code table6[]={0xa0,0xa1,0xa2,0xa3,0xa4,0xa5,0xa6,0xa7,0xa8,0xa9}; //左邊倒數(shù)第二
uchar code table5[]={0xb0,0xb1,0xb2,0xb3,0xb4,0xb5,0xb6,0xb7,0xb8,0xb9};
uchar code table4[]={0xc0,0xc1,0xc2,0xc3,0xc4,0xc5,0xc6,0xc7,0xc8,0xc9};
uchar code table3[]={0xd0,0xd1,0xd2,0xd3,0xd4,0xd5,0xd6,0xd7,0xd8,0xd9}; //左邊倒數(shù)第二
uchar code table2[]={0xe0,0xe1,0xe2,0xe3,0xe4,0xe5,0xe6,0xe7,0xe8,0xe9};
uchar code table1[]={0xf0,0xf1,0xf2,0xf3,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9};
ulong dat; //數(shù)據(jù)
ulong datA; //過度數(shù)據(jù)
uchar addflag; //加法標志位
uchar subflag; //減法標志位
uchar mulflag; //乘法標志位
uchar divflag; //除法標志位
uchar overflow; //溢出標志位
uchar clrflag; //數(shù)據(jù)處理標志位
uchar illegal; //除法的非法標志位
uchar keynum; //按鍵鍵值
uchar keycode; //按鍵IO口狀態(tài)值
uchar scanok; //IO口掃描結(jié)束
uchar checkok; //鍵值獲取結(jié)束
void delay_ms(uint z) //1ms的延時函數(shù)
uchar x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void scankeyboard() //scankeyboard()函數(shù)(用于掃描鍵值)
{ //反轉(zhuǎn)法測鍵值。。。
uchar a,b;
P2=0x0f;
keycode=P2;
if(keycode!=0x0f)
delay_ms(10); //按鍵閉合消抖。。
a=keycode;
P2=0xf0;
b=P2;
keycode=a|b;
while(P2!=0xf0);
delay_ms(10);//按鍵釋放消抖。。
P1=keycode;
scanok=1;//鍵值測完后。。scanok置1。。。
void checkkeycode(void)
if(scanok) //如果鍵值測完后,則執(zhí)行以下。。。
scanok=0; //scanok清零。。為下次使用準備
switch(keycode) //用開關(guān)語句查找鍵值對應(yīng)的邏輯功能...
case 0xee: keynum=0 ;break; //數(shù)字鍵
case 0xed: keynum=1 ;break;
case 0xdd: keynum=2 ;break;
case 0xbd: keynum=3 ;break;
case 0xeb: keynum=4 ;break;
case 0xdb: keynum=5 ;break;
case 0xbb: keynum=6 ;break;
case 0xe7: keynum=7 ;break;
case 0xd7: keynum=8 ;break;
case 0xb7: keynum=9 ;break;
case 0x77: keynum=10 ;break; // +
case 0x7b: keynum=11 ;break; // -
case 0x7d: keynum=12 ;break; // *
case 0x7e: keynum=13 ;break; // /
case 0xbe: keynum=14 ;break; // =
case 0xde: keynum=15 ;break; //清零
checkok=1; //查完后,checkok置1.
void datpros(void) //數(shù)據(jù)處理函數(shù)。。
if(keynum==15) //如果是15 則認為是清零的 進行清零
dat=0;
else //否則則認為是數(shù)字鍵 進行顯示 存貯 并運算
if(clrflag) //清除標志為1,則執(zhí)行以下。
dat=0;
clrflag=0; //為下次使用準備。
dat=dat*10+(ulong)keynum; //將每次按的數(shù)字合成一個整體。。比如按下"1","2","3"后就會把它合成"123"
if(dat>1000000000) overflow=1; //如果輸入值大于65535(所用的為int型數(shù)據(jù),最大為65535)的話則溢出標志置1,可供顯示程序查詢并顯示"EEEEEEE"
if(divflag&&!dat) illegal=1; //如果做除法時除了零,則非法標志置1,供顯示程序查詢
void add(void)
addflag++; //加法標志置1。。。
subflag=mulflag=divflag=0; //將其它運算標志清零。。(一次只能作一種運算)
clrflag=1; //清零標標置1,(當(dāng)按下加號后,再按第二個加數(shù)時,這時應(yīng)該顯示第二加數(shù)。。所以要清掉第一個加數(shù)。)
if(addflag>1) //此處用于邊加。。
{ //當(dāng)連續(xù)加的時候。。加號應(yīng)有等于的功能。。
dat=dat+datA; //算出和
datA=dat; //和保存,用于下一次連加。。
} //說明:比如進行"1+2+3"時,當(dāng)按第二個加時,應(yīng)該要顯示1+2的和。。
else datA=dat; //如果不是連加,將輸入的第一個加數(shù)暫存。。(因為顯示程序只顯示dat變量的值。)
void sub(void)
subflag++;
addflag=mulflag=divflag=0;
clrflag=1;
if(subflag>1) //連減。。
dat=datA-dat;
datA=dat;
else datA=dat;
void mul(void)
mulflag++;
addflag=subflag=divflag=0;
clrflag=1;
if(mulflag>1) //連乘
dat=datA*dat;
datA=dat;
else datA=dat;
void div(void)
divflag++;
addflag=subflag=mulflag=0;
clrflag=1;
if(divflag>1)
dat=datA/dat;
datA=dat;
else datA=dat;
void equ(void)
if(addflag) //如果些時做加法運算。。
dat=dat+datA; //計算各存入dat(顯示程序會將dat顯示的。。)
if(subflag)
dat=datA-dat;
if(mulflag)
dat=datA*dat;
if(divflag)
dat=datA/dat;
addflag=subflag=mulflag=divflag=0; //運算一次完成后將所有運標志清零。為下次運算作準備。。
void display(void)
uchar ge=0,shi=0,bai=0,qian=0,wan=0,shiwan=0,baiwan=0,qianwan=0;
if(!overflow&&!illegal)
ge=dat; //將數(shù)據(jù)分開然后分別顯示
shi=dat0/10;
bai=dat00/100;
qian=dat000/1000;
wan=dat0000/10000;
shiwan=dat00000/100000;
baiwan=dat000000/1000000;
qianwan=dat0000000/10000000;
P0=table1[ge]; //個位顯示
delay_ms(2);
P0=table2[shi]; //十位顯示
delay_ms(2);
P0=table3[bai]; //百位顯示
delay_ms(2);
P0=table4[qian]; //千位位顯示
delay_ms(2);
P0=table5[wan]; //wan位顯示
delay_ms(2);
P0=table6[shiwan]; //個位顯示
delay_ms(2);
P0=table7[baiwan]; //個位顯示
delay_ms(2);
P0=table8[qianwan]; //個位顯示
delay_ms(2);
P0=0xff;
P0=table1[0];
void calculate_handle(void)//計算大函數(shù)。。
if(checkok)//如果檢測鍵值完萬。。則執(zhí)行以下。。
checkok=0;//檢測完標志清零..
switch (keynum)//如果是+,-,*,/,=則進入相應(yīng)的函數(shù)。。
case 10 : add(); break; //如果是按了"+",則進入加法函數(shù)。
case 11 : sub(); break; //如果是按了"-",則進入加法函數(shù)。
case 12 : mul(); break; //如果是按了"*",則進入加法函數(shù)。
case 13 : div(); break; //如果是按了"/",則進入加法函數(shù)。
case 14 : equ(); break; //如果是按了"=",則進入加法函數(shù)。
default : datpros(); //如果不是,計算符(即為數(shù)字),則進入數(shù)據(jù)處理函數(shù)。
void main(void)
P0=0xff;
scankeyboard();
checkkeycode();
calculate_handle();
display();
