查看: 15257|回復: 3
用Arduino控制無刷電機電調的最簡方法
ID:426571 發表于 2018-11-14 18:46 | 顯示全部樓層 |閱讀模式
關于電調的控制信號:電調信號是pwm信號,信號頻率為50Hz,一個周期為20ms。對于電調來講,高電平脈寬為1ms表示停轉,高電平脈寬為2ms表示滿油門運轉;對于舵機來說1.5ms是歸中,1ms和2ms分別為左右滿舵。(因此下面才直接用Servo庫來給實現ESC信號的輸出)。
關于Servo.write()Servo.writeMicroseconds()
0.Servo.writeMicroseconds(): Writes a value in microseconds (uS) tothe servo, controlling the shaft accordingly. On a standard servo, this willset the angle of the shaft. On standard servos a parameter value of 1000 isfully counter-clockwise, 2000 is fully clockwise, and 1500 is in the middle.
1.servo.write() allows a maximum of 180 servo positions
  servo.writeMicroseconds() allows a maximum of 1000 servo positions
2.The "write" method simply maps the"degrees" to microseconds and calls the "writeMicroseconds"method anyway.
   The "degree" of turn is simply a convenientabstraction, and few bother to calibrate it.
控制程序:
1.  #include<Servo.h> // Using servo library to control ESC
2.  Servo esc; //Creating a servo class with name as esc
3.  int val; //Creating a variable val
4.  void setup()
5.  {
6.  esc.attach(9); //Specify the esc signal pin,Here as D9
7.  esc.writeMicroseconds(1000);// initialize the signal to 1000
8.  Serial.begin(9600);
9.  }
10. void loop()
11. {
12. val=analogRead(A0); // Read input from analog pin a0 and store in val
13. val= map(val, 0,1023,1000,2000); // mapping val to minimum and maximum(Change if needed)
14. Serial.println(val);
15. esc.writeMicroseconds(val);// using val as the signal to esc
16. }
補充:電調1ms停轉,2ms滿油門運轉,是指的單向電調,且是方波脈沖。而一般雙向電調,1ms反轉最大油門,1.5油門中點,2ms滿油門正轉。
ID:514567 發表于 2019-7-28 20:27 | 顯示全部樓層
正好需要,謝謝樓主
ID:79544 發表于 2019-9-3 08:53 | 顯示全部樓層
感謝樓主分享,學習啦!!!!!
ID:728839 發表于 2021-1-12 20:09 | 顯示全部樓層
怎么同時控制四個電調呢?
