查看: 3144|回復(fù): 1
89C52RC單片機(jī)做自動(dòng)喂食機(jī)
ID:417221 發(fā)表于 2018-11-13 17:28 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
閑來無事,給家里狗狗制作了自動(dòng)喂食機(jī),
代碼如下:
#include<reg52.h>
sbit led1=P2^0;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
sbit led5=P2^4;
sbit led6=P2^5;
sbit FZ  =P3^7;
sbit IN1=P1^3;
sbit IN2=P1^2;
sbit IN3=P2^7;
sbit IN4=P2^6;
void Delay10ms(unsigned int c) ;
unsigned char code LedChar[]={
        0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78,
        0x00, 0x10
unsigned char LedBuff[]={
        0xff, 0xff, 0xff, 0xff, 0xff, 0xff
unsigned int cnt = 0;
        unsigned long sec;
        sec=0x00;
    TMOD = 0x01;
        TH0 = 0xFC;
        TL0 = 0x66;
        TR0 = 1;
        EA = 1;
        ET0 = 1;
                   if(cnt >= 1000)
                        cnt = 0;
                        sec++;
                        //if(sec==20)
                //        FZ=0;Delay5ms(50)        ;FZ=1;Delay5ms(50)        ; FZ=0;Delay5ms(50);          FZ=1;Delay5ms(50);
                //         IN1=1;IN2=0;  Delay5ms(50)        ;IN1=0;IN2=1;         Delay5ms(50)        ;
                //         IN1=IN2=0;
                        LedBuff[0] = LedChar[sec%3600%60%10];
                        LedBuff[1] = LedChar[sec%3600%60/10];
                        LedBuff[2] = LedChar[sec%3600/60%10];
                        LedBuff[3] = LedChar[sec%3600/60/10];
                        LedBuff[4] = LedChar[sec/3600%10];
                        LedBuff[5] = LedChar[sec/3600/10];
               if(sec>=43200)
                 sec=0;
unsigned char i = 0;
void InterruptTimer0()  interrupt 1
        TH0 = 0xFC;
        TL0 = 0x66;
        cnt++;
        P0=P2 = 0xff;
        switch(i)
                case 0:led1=0; i++; P0=LedBuff[0];break;
                case 1:led2=0; i++; P0=LedBuff[1];break;
                case 2:led3=0; i++; P0=LedBuff[2];break;
                case 3:led4=0; i++; P0=LedBuff[3];break;
                case 4:led5=0; i++; P0=LedBuff[4];break;
                case 5:led6=0; i=0; P0=LedBuff[5];break;
        default:break;
    unsigned char a, b;
    for (;c>0;c--)
                for (b=249;b>0;b--)
                        for (a=17;a>0;a--);
ID:879963 發(fā)表于 2021-1-30 00:09 來自觸屏版 | 只看該作者
有電路圖
