串口數(shù)據(jù)接收 及發(fā)送處理 節(jié)省空間 高效率
- #include <stdlib.h>
- #include <string.h>
- #include "ring_buffer.h"
- * Private types/enumerations/variables
- #define RB_INDH(rb) ((rb)->head & ((rb)->count - 1))
- #define RB_INDT(rb) ((rb)->tail & ((rb)->count - 1))
- #if !defined(MAX)
- #define MAX(a, b) (((a) > (b)) ? (a) : (b))
- #endif
- #if !defined(MIN)
- #define MIN(a, b) (((a) < (b)) ? (a) : (b))
- #endif
- * Public types/enumerations/variables
- * Private functions
- * Public functions
- * @brief Resets the ring buffer to empty
- * @param RingBuff : Pointer to ring buffer
- * @return Nothing
- void RingBuffer_Flush(RINGBUFF_T *RingBuff)
- RingBuff->head = RingBuff->tail = 0;
- * @brief Return size the ring buffer
- * @return Size of the ring buffer in bytes
- int RingBuffer_GetSize(RINGBUFF_T *RingBuff)
- return RingBuff->count;
- * @brief Return number of items in the ring buffer
- * @return Number of items in the ring buffer
- static int RingBuffer_GetCount(RINGBUFF_T *RingBuff)
- return RB_VHEAD(RingBuff) - RB_VTAIL(RingBuff);
- * @brief Return number of free items in the ring buffer
- * @return Number of free items in the ring buffer
- static int RingBuffer_GetFree(RINGBUFF_T *RingBuff)
- return RingBuff->count - RingBuffer_GetCount(RingBuff);
- * @return 1 if the ring buffer is full, otherwise 0
- int RingBuffer_IsFull(RINGBUFF_T *RingBuff)
- return (RingBuffer_GetCount(RingBuff) >= RingBuff->count);
- * @brief Return empty status of ring buffer
- * @return 1 if the ring buffer is empty, otherwise 0
- int RingBuffer_IsEmpty(RINGBUFF_T *RingBuff)
- return RB_VHEAD(RingBuff) == RB_VTAIL(RingBuff);
- /* Initialize ring buffer */
- int RingBuffer_Init(RINGBUFF_T *RingBuff, void *buffer, int itemSize, int count)
- RingBuff->data = buffer;
- RingBuff->count = count;
- RingBuff->itemSz = itemSize;
- return 1;
- /* Insert a single item into Ring Buffer */
- int RingBuffer_Insert(RINGBUFF_T *RingBuff, const void *data)
- u8 *ptr = RingBuff->data;
- /* We cannot insert when queue is full */
- if (RingBuffer_IsFull(RingBuff))
- return 0;
- ptr += RB_INDH(RingBuff) * RingBuff->itemSz;
- memcpy(ptr, data, RingBuff->itemSz);
- RingBuff->head++;
- return 1;
- /* Insert multiple items into Ring Buffer */
- int RingBuffer_InsertMult(RINGBUFF_T *RingBuff, const void *data, int num)
- int cnt1, cnt2;
- return 0;
- /* Calculate the segment lengths */
- cnt1 = cnt2 = RingBuffer_GetFree(RingBuff);
- if (RB_INDH(RingBuff) + cnt1 >= RingBuff->count)
- cnt1 = RingBuff->count - RB_INDH(RingBuff);
- cnt2 -= cnt1;
- cnt1 = MIN(cnt1, num);
- num -= cnt1;
- cnt2 = MIN(cnt2, num);
- num -= cnt2;
- /* Write segment 1 */
- memcpy(ptr, data, cnt1 * RingBuff->itemSz);
- RingBuff->head += cnt1;
- /* Write segment 2 */
- ptr = (u8 *) RingBuff->data + RB_INDH(RingBuff) * RingBuff->itemSz;
- data = (const u8 *) data + cnt1 * RingBuff->itemSz;
- memcpy(ptr, data, cnt2 * RingBuff->itemSz);
- RingBuff->head += cnt2;
- return cnt1 + cnt2;
- /* Pop single item from Ring Buffer */
- int RingBuffer_Pop(RINGBUFF_T *RingBuff, void *data)
- /* We cannot pop when queue is empty */
- if (RingBuffer_IsEmpty(RingBuff))
- return 0;
- ptr += RB_INDT(RingBuff) * RingBuff->itemSz;
- memcpy(data, ptr, RingBuff->itemSz);
- RingBuff->tail++;
- return 1;
- /* Pop multiple items from Ring buffer */
- int RingBuffer_PopMult(RINGBUFF_T *RingBuff, void *data, int num)
- int cnt1, cnt2;
- /* We cannot insert when queue is empty */
- return 0;
- cnt1 = cnt2 = RingBuffer_GetCount(RingBuff);
- if (RB_INDT(RingBuff) + cnt1 >= RingBuff->count)
- cnt1 = RingBuff->count - RB_INDT(RingBuff);
- cnt2 -= cnt1;
- num -= cnt1;
- num -= cnt2;
- memcpy(data, ptr, cnt1 * RingBuff->itemSz);
- RingBuff->tail += cnt1;
- ptr = (u8 *) RingBuff->data + RB_INDT(RingBuff) * RingBuff->itemSz;
- data = (u8 *) data + cnt1 * RingBuff->itemSz;
- memcpy(data, ptr, cnt2 * RingBuff->itemSz);
- RingBuff->tail += cnt2;
ring_buffer.zip
(3.77 KB, 下載次數(shù): 31)
2018-11-13 17:06 上傳
下載積分: 黑幣 -5
