STM32F030
Read the temperature sensor through ADC
2018-11-13 16:13 上傳
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stdio.h"
- /** @addtogroup STM32F0308-Discovery_Demo
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- static __IO uint32_t TimingDelay;
- uint8_t BlinkSpeed = 0;
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- * @brief Main program.
- * @param None
- * @retval None
- float Tmp275_temperature(void);
- void Tmp275_Init(void);
- extern void lcd_init(void);
- void PutStr(unsigned char row,unsigned char col,unsigned char *puts);
- void LcmClearTXT(void);
- int main(void)
- float temperature;
- char msg[64];
- RCC_ClocksTypeDef RCC_Clocks;
- /* Configure LED3 and LED4 on STM32F0308-Discovery */
- STM_EVAL_LEDInit(LED3);
- STM_EVAL_LEDInit(LED4);
- /* Initialize User_Button on STM32F0308-Discovery */
- STM_EVAL_PBInit(BUTTON_USER, BUTTON_MODE_GPIO);
- /* SysTick end of count event each 1ms */
- RCC_GetClocksFreq(&RCC_Clocks);
- SysTick_Config(RCC_Clocks.HCLK_Frequency / 1000);
- /* Initiate Blink Speed variable */
- BlinkSpeed = 1;
- lcd_init();
- Tmp275_Init();
- while(1)
- temperature = Tmp275_temperature();
- sprintf(msg, "溫度: %6.1f℃", temperature);
- //LcmClearTXT();
- PutStr(0, 0, " HELLO EEWORLD! ");
- PutStr(1, 0, msg);
- Delay(2000);
- // lcd_test();
- // while(1)
- // /* Check if the user button is pressed */
- // if(STM_EVAL_PBGetState(BUTTON_USER)== SET)
- // /* BlinkSpeed: 1 -> 2 -> 0, then re-cycle */
- // /* Turn on LD4 Blue LED during 1s each time User button is pressed */
- // STM_EVAL_LEDOn(LED4);
- // /* wait for 1s */
- // Delay(1000);
- // /* Turn off LD4 Blue LED after 1s each time User button is pressed */
- // STM_EVAL_LEDOff(LED4);
- // /* Increment the blink speed counter */
- // BlinkSpeed++;
- // /* Default value for blink speed counter */
- // if(BlinkSpeed == 3)
- // BlinkSpeed = 0;
- // /* Test on blink speed */
- // if(BlinkSpeed == 2)
- // /* LED3 toggles each 100 ms */
- // STM_EVAL_LEDToggle(LED3);
- // /* maintain LED3 status for 100ms */
- // Delay(100);
- // else if(BlinkSpeed == 1)
- // /* LED3 toggles each 200 ms */
- // /* maintain LED3 status for 200ms */
- // Delay(200);
- // else
- // /* LED3 Off */
- // STM_EVAL_LEDOff(LED3);
- * @brief Inserts a delay time.
- * @param nTime: specifies the delay time length, in 1 ms.
- * @retval None
- void Delay(__IO uint32_t nTime)
- TimingDelay = nTime;
- while(TimingDelay != 0);
- * @brief Decrements the TimingDelay variable.
- * @param None
- * @retval None
- void TimingDelay_Decrement(void)
- if (TimingDelay != 0x00)
- TimingDelay--;
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
全部資料51hei下載地址:
STM32F0308-Discovery_FW_V1.0.1_temperature.rar
(1.83 MB, 下載次數: 24)
2018-11-13 16:14 上傳
下載積分: 黑幣 -5
