查看: 1519|回復: 0
RX TX 收發程序
ID:423822 發表于 2018-11-9 21:59 | 顯示全部樓層 |閱讀模式
define    SDA                    P20#define    IOSDA                DDR20#define    SCL                     P21#define     KEY_L                   P17            #define     KEY_R                  P00              #define     KEY_F                   P01             #define     KEY_B                  P02               #define     L_LED                  P07#define     R_LED                  P04#define     F_LED                  P05#define     B_LED                  P06#define     BUZER                  P03#define     PKT_FLAG              P14     // INPUT,#define     MISO                        P10     // INPUT,  SPI data in#define     MOSI                        P11     // OUTPUT, SPI data out#define     CLK                        P13              // OUTPUT, SPI clock#define     NSS                              P15     // OUTPUT#define     RESET_N                     P20            // OUTPUT//==========================================================#define    Sync_Word_2ndAddr      37#define    Sync_Word_1stAddr      36#define     SPI_Delay                   3const uchar PWM_Table[11]={1,4,7,10,13,16,19,22,25,28,31};const Com_SyncWord_Table[4]={0x55,0x55,0x55,0x55};const Channeal_TAB[9]={3,32,65,10,35,70,18,44,75};///////R_channelֵ///////////////////// 003              ; freq:2402 ;@0X03// 032              ; freq:2428 ;@0X20// 065              ; freq:2456 ;@0X41// 010              ; freq:2406 ;@0X0A// 035              ; freq:2433 ;@0X23// 070              ; freq:2461 ;@0X46// 018              ; freq:2410 ;@0X12// 044              ; freq:2438 ;@0X28// 075              ; freq:2466 ;@0X4Bconst KEY_TAB[16]={0,0x51,0x52,0,0x54,0x55,0x56,0,0x58,0x59,0x5a,0,0,0,0,0};uchar  R_channel,channel_count;uchar  R_Dlenth,R_DATA1,R_DATA2,R_DATA3;uchar  RegL,RegH;uchar  R_10mscount,R_tscancount;uchar  R_Test;uchar   KeyLRcount,KeyFBcount,KeyData;uchar   R_LRcount,R_FBcount,R_Nosindelay;
