AD9834是使用spi通信連接來操作的信號發(fā)生模塊
直接上傳
example中的第二個ino,直接運行,親測有效
程序?qū)懙姆浅n櫭剂x,函數(shù)名稱就是字面含義
- * AD9833.cpp
- * Copyright 2016 Bill Williams <wlwilliams1952@gmail.com, github/BillWilliams1952>
- * Thanks to john@vwlowen co uk for his work on the AD9833. His web page
- * This program is free software; you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation; either version 2 of the License, or
- * (at your option) any later version.
- * This program is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with this program; if not, write to the Free Software
- * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston,
- * MA 02110-1301, USA.
- #include "AD9833.h"
- * Create an AD9833 object
- AD9833 :: AD9833 ( uint8_t FNCpin, uint32_t referenceFrequency ) {
- // Pin used to enable SPI communication (active LOW)
- #ifdef FNC_PIN
- pinMode(FNC_PIN,OUTPUT);
- #else
- this->FNCpin = FNCpin;
- pinMode(FNCpin,OUTPUT);
- #endif
- WRITE_FNCPIN(HIGH);
- /* TODO: The minimum resolution and max frequency are determined by
- * by referenceFrequency. We should calculate these values and use
- * them during setFrequency. The problem is if the user programs a
- * square wave at refFrequency/2, then changes the waveform to sine.
- * The sine wave will not have enough points?
- refFrequency = referenceFrequency;
- // Setup some defaults
- DacDisabled = false;
- IntClkDisabled = false;
- outputEnabled = false;
- waveForm0 = waveForm1 = SINE_WAVE;
- frequency0 = frequency1 = 1000; // 1 KHz sine wave to start
- phase0 = phase1 = 0.0; // 0 phase
- activeFreq = REG0; activePhase = REG0;
- * This MUST be the first command after declaring the AD9833 object
- * Start SPI and place the AD9833 in the RESET state
- void AD9833 :: Begin ( void ) {
- SPI.begin();
- delay(100);
- Reset(); // Hold in RESET until first WriteRegister command
- * Setup and apply a signal. phaseInDeg defaults to 0.0 if not supplied.
- * phaseReg defaults to value of freqReg if not supplied.
- * Note that any previous calls to EnableOut,
- * SleepMode, DisableDAC, or DisableInternalClock remain in effect.
- void AD9833 :: ApplySignal ( WaveformType waveType,
- Registers freqReg, float frequencyInHz,
- Registers phaseReg, float phaseInDeg ) {
- SetFrequency ( freqReg, frequencyInHz );
- SetPhase ( phaseReg, phaseInDeg );
- SetWaveform ( freqReg, waveType );
- SetOutputSource ( freqReg, phaseReg );
- Control Register
- D15,D14(MSB) 10 = FREQ1 write, 01 = FREQ0 write,
- 11 = PHASE write, 00 = control write
- D13 If D15,D14 = 00, 0 = individual LSB and MSB FREQ write,
- 1 = both LSB and MSB FREQ writes consecutively
- If D15,D14 = 11, 0 = PHASE0 write, 1 = PHASE1 write
- D12 0 = writing LSB independently
- 1 = writing MSB independently
- D11 0 = output FREQ0,
- 1 = output FREQ1
- D10 0 = output PHASE0
- 1 = output PHASE1
- D9 Reserved. Must be 0.
- D8 0 = RESET disabled
- 1 = RESET enabled
- D7 0 = internal clock is enabled
- 1 = internal clock is disabled
- D6 0 = onboard DAC is active for sine and triangle wave output,
- 1 = put DAC to sleep for square wave output
- D5 0 = output depends on D1
- 1 = output is a square wave
- D4 Reserved. Must be 0.
- D3 0 = square wave of half frequency output
- 1 = square wave output
- D2 Reserved. Must be 0.
- D1 If D5 = 1, D1 = 0.
- Otherwise 0 = sine output, 1 = triangle output
- D0 Reserved. Must be 0.
- * Hold the AD9833 in RESET state.
- * Resets internal registers to 0, which corresponds to an output of
- * midscale - digital output at 0.
- * The difference between Reset() and EnableOutput(false) is that
- * EnableOutput(false) keeps the AD9833 in the RESET state until you
- * specifically remove the RESET state using EnableOutput(true).
- * With a call to Reset(), ANY subsequent call to ANY function (other
- * than Reset itself and Set/IncrementPhase) will also remove the RESET
- * state.
- void AD9833 :: Reset ( void ) {
- WriteRegister(RESET_CMD);
- delay(15);
- * Set the specified frequency register with the frequency (in Hz)
- void AD9833 :: SetFrequency ( Registers freqReg, float frequency ) {
- // TODO: calculate max frequency based on refFrequency.
- // Use the calculations for sanity checks on numbers.
- // Sanity check on frequency: Square - refFrequency / 2
- // Sine/Triangle - refFrequency / 4
- if ( frequency > 12.5e6 ) // TODO: Fix this based on refFreq
- frequency = 12.5e6;
- if ( frequency < 0.0 ) frequency = 0.0;
- // Save frequency for use by IncrementFrequency function
- if ( freqReg == REG0 ) frequency0 = frequency;
- else frequency1 = frequency;
- int32_t freqWord = (frequency * pow2_28) / (float)refFrequency;
- int16_t upper14 = (int16_t)((freqWord & 0xFFFC000) >> 14),
- lower14 = (int16_t)(freqWord & 0x3FFF);
- // Which frequency register are we updating?
- uint16_t reg = freqReg == REG0 ? FREQ0_WRITE_REG : FREQ1_WRITE_REG;
- lower14 |= reg;
- upper14 |= reg;
- // I do not reset the registers during write. It seems to remove
- // 'glitching' on the outputs.
- WriteControlRegister();
- // Control register has already been setup to accept two frequency
- // writes, one for each 14 bit part of the 28 bit frequency word
- WriteRegister(lower14); // Write lower 14 bits to AD9833
- WriteRegister(upper14); // Write upper 14 bits to AD9833
- * Increment the specified frequency register with the frequency (in Hz)
- void AD9833 :: IncrementFrequency ( Registers freqReg, float freqIncHz ) {
- // Add/subtract a value from the current frequency programmed in
- // freqReg by the amount given
- float frequency = (freqReg == REG0) ? frequency0 : frequency1;
- SetFrequency(freqReg,frequency+freqIncHz);
- * Set the specified phase register with the phase (in degrees)
- * The output signal will be phase shifted by 2π/4096 x PHASEREG
- void AD9833 :: SetPhase ( Registers phaseReg, float phaseInDeg ) {
- // Sanity checks on input
- phaseInDeg = fmod(phaseInDeg,360);
- if ( phaseInDeg < 0 ) phaseInDeg += 360;
- // Phase is in float degrees ( 0.0 - 360.0 )
- // Convert to a number 0 to 4096 where 4096 = 0 by masking
- uint16_t phaseVal = (uint16_t)(BITS_PER_DEG * phaseInDeg) & 0x0FFF;
- phaseVal |= PHASE_WRITE_CMD;
- // Save phase for use by IncrementPhase function
- if ( phaseReg == REG0 ) {
- phase0 = phaseInDeg;
- else {
- phase1 = phaseInDeg;
- phaseVal |= PHASE1_WRITE_REG;
- WriteRegister(phaseVal);
- * Increment the specified phase register by the phase (in degrees)
- void AD9833 :: IncrementPhase ( Registers phaseReg, float phaseIncDeg ) {
- // Add/subtract a value from the current phase programmed in
- // phaseReg by the amount given
- float phase = (phaseReg == REG0) ? phase0 : phase1;
- SetPhase(phaseReg,phase + phaseIncDeg);
- * Set the type of waveform that is output for a frequency register
- * SINE_WAVE, TRIANGLE_WAVE, SQUARE_WAVE, HALF_SQUARE_WAVE
- void AD9833 :: SetWaveform ( Registers waveFormReg, WaveformType waveType ) {
- // TODO: Add more error checking?
- if ( waveFormReg == REG0 )
- waveForm0 = waveType;
- else
- waveForm1 = waveType;
- * EnableOutput(false) keeps the AD9833 is RESET state until a call to
- * EnableOutput(true). See the Reset function description.
- void AD9833 :: EnableOutput ( bool enable ) {
- outputEnabled = enable;
- * Set which frequency and phase register is being used to output the
- * waveform. If phaseReg is not supplied, it defaults to the same
- * register as freqReg.
- void AD9833 :: SetOutputSource ( Registers freqReg, Registers phaseReg ) {
- activeFreq = freqReg;
- if ( phaseReg == SAME_AS_REG0 ) activePhase = activeFreq;
- else activePhase = phaseReg;
- //---------- LOWER LEVEL FUNCTIONS NOT NORMALLY NEEDED -------------
- * Disable/enable both the internal clock and the DAC. Note that square
- * wave outputs are avaiable if using an external Reference.
- * TODO: ?? IS THIS TRUE ??
- void AD9833 :: SleepMode ( bool enable ) {
- DacDisabled = enable;
- IntClkDisabled = enable;
- * Enables / disables the DAC. It will override any previous DAC
- * setting by Waveform type, or via the SleepMode function
- void AD9833 :: DisableDAC ( bool enable ) {
- * Enables / disables the internal clock. It will override any
- * previous clock setting by the SleepMode function
- void AD9833 :: DisableInternalClock ( bool enable ) {
- // ------------ STATUS / INFORMATION FUNCTIONS -------------------
- * Return actual frequency programmed
- float AD9833 :: GetActualProgrammedFrequency ( Registers reg ) {
- float frequency = reg == REG0 ? frequency0 : frequency1;
- int32_t freqWord = (uint32_t)((frequency * pow2_28) / (float)refFrequency) & 0x0FFFFFFFUL;
- return (float)freqWord * (float)refFrequency / (float)pow2_28;
- * Return actual phase programmed
- float AD9833 :: GetActualProgrammedPhase ( Registers reg ) {
- float phase = reg == REG0 ? phase0 : phase1;
- uint16_t phaseVal = (uint16_t)(BITS_PER_DEG * phase) & 0x0FFF;
- return (float)phaseVal / BITS_PER_DEG;
- * Return frequency resolution
- float AD9833 :: GetResolution ( void ) {
- return (float)refFrequency / (float)pow2_28;
- // --------------------- PRIVATE FUNCTIONS --------------------------
- * Write control register. Setup register based on defined states
- void AD9833 :: WriteControlRegister ( void ) {
- uint16_t waveForm;
- // TODO: can speed things up by keeping a writeReg0 and writeReg1
- // that presets all bits during the various setup function calls
- // rather than setting flags. Then we could just call WriteRegister
- // directly.
- if ( activeFreq == REG0 ) {
- waveForm = waveForm0;
- waveForm &= ~FREQ1_OUTPUT_REG;
- else {
- waveForm = waveForm1;
- waveForm |= FREQ1_OUTPUT_REG;
- if ( activePhase == REG0 )
- waveForm &= ~PHASE1_OUTPUT_REG;
- else
- waveForm |= PHASE1_OUTPUT_REG;
- if ( outputEnabled )
- waveForm &= ~RESET_CMD;
- else
- waveForm |= RESET_CMD;
- if ( DacDisabled )
- waveForm |= DISABLE_DAC;
- else
- waveForm &= ~DISABLE_DAC;
- if ( IntClkDisabled )
- waveForm |= DISABLE_INT_CLK;
- else
- waveForm &= ~DISABLE_INT_CLK;
- WriteRegister ( waveForm );
- void AD9833 :: WriteRegister ( int16_t dat ) {
- * We set the mode here, because other hardware may be doing SPI also
- SPI.setDataMode(SPI_MODE2);
- /* Improve overall switching speed
- * Note, the times are for this function call, not the write.
- * digitalWrite(FNCpin) ~ 17.6 usec
- * digitalWriteFast2(FNC_PIN) ~ 8.8 usec
- WRITE_FNCPIN(LOW); // FNCpin low to write to AD9833
- //delayMicroseconds(2); // Some delay may be needed
- // TODO: Are we running at the highest clock rate?
- SPI.transfer(highByte(dat)); // Transmit 16 bits 8 bits at a time
- SPI.transfer(lowByte(dat));
- WRITE_FNCPIN(HIGH); // Write done
AD9833-Library-Arduino-master.rar
(15.59 KB, 下載次數(shù): 47)
2018-11-8 15:57 上傳
下載積分: 黑幣 -5
