查看: 1987|回復: 0
串口通信 PC機向單片機發送命令啟動或停止蜂鳴器播放音樂
ID:396671 發表于 2018-11-6 21:14 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
PC機向單片機發送命令啟動或停止蜂鳴器播放音樂,
當播放音樂時該怎么停止,這時是播放函數運行中,pc輸入數據要等到放完才接受,也就是停不下來
是不是應該換個播放函數?該怎么寫?
#include<reg52.h>
#include<string.h>
unsigned char Count;
sbit speak = P3^4;
unsigned char code SONG[] ={      //祝你平安
0x26,0x20,0x20,0x20,0x20,0x20,0x26,0x10,0x20,0x10,0x20,0x80,0x26,0x20,0x30,0x20,
0x30,0x20,0x39,0x10,0x30,0x10,0x30,0x80,0x26,0x20,0x20,0x20,0x20,0x20,0x1c,0x20,
0x20,0x80,0x2b,0x20,0x26,0x20,0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x80,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x60,0x40,0x10,0x39,0x10,0x26,0x20,
0x30,0x20,0x30,0x20,0x39,0x10,0x26,0x10,0x26,0x80,0x26,0x20,0x2b,0x10,0x2b,0x10,
0x2b,0x20,0x30,0x10,0x39,0x10,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x20,
0x20,0x10,0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x18,0x20,0x18,0x20,0x26,0x20,
0x20,0x20,0x20,0x40,0x26,0x20,0x2b,0x20,0x30,0x20,0x30,0x20,0x1c,0x20,0x20,0x20,
0x20,0x80,0x1c,0x20,0x1c,0x20,0x1c,0x20,0x30,0x20,0x30,0x60,0x39,0x10,0x30,0x10,
0x20,0x20,0x2b,0x10,0x26,0x10,0x2b,0x10,0x26,0x10,0x26,0x10,0x2b,0x10,0x2b,0x80,
0x18,0x20,0x18,0x20,0x26,0x20,0x20,0x20,0x20,0x60,0x26,0x10,0x2b,0x20,0x30,0x20,
0x30,0x20,0x1c,0x20,0x20,0x20,0x20,0x80,0x26,0x20,0x30,0x10,0x30,0x10,0x30,0x20,
0x39,0x20,0x26,0x10,0x2b,0x10,0x2b,0x20,0x2b,0x40,0x40,0x10,0x40,0x10,0x20,0x10,
0x20,0x10,0x2b,0x10,0x26,0x30,0x30,0x80,0x00};
void Delay_xMs(unsigned int x)
    unsigned int i,j;
    for( i =0;i < x;i++ )
        for( j =0;j<3;j++ );
void Play_Song(unsigned char i)
unsigned char Temp1,Temp2;
unsigned int Addr;
Count = 0;      //中斷計數器清0
Addr = i * 217;
  Temp1 = SONG[Addr++];
     if ( Temp1 == 0xFF )          //休止符
      TR0 = 0;
      Delay_xMs(100);
     else if ( Temp1 == 0x00 )   //歌曲結束符
      return;
      Temp2 = SONG[Addr++];
      TR0 = 1;
       speak = ~speak;
       Delay_xMs(Temp1);
       if ( Temp2 == Count )
        Count = 0;
        break;
void main (void)
{ char a,b=0;
  SCON=0x50;//串行口方式1
  PCON=0x00;//T1初始化,
  TMOD=0x21;//T1設為方式2  T0設為方式1
  TH1=0xFD;//選9600波特,fosc=11.0592MHz
  TR1=1;//啟動T1
  IE   = 0x82;
  TH0  = 0xD8;
  TL0  = 0xEF;
      if(RI)//如果接收到數據,就把接收到的數回發給PC
         { RI=0;//清接收標志
           a=SBUF ;//讀串行口數據
           SBUF=a;//把從PC機發送過來的數據返回給PC機
           while(!TI);//沒有發送完等待
           TI=0;//清發送完中斷標志
                   switch(a)
               case 0x00 : P0=0xff; break;
               case 0x01 : P0=0xAA; break;
               case 0x02 : P0=0x00; break;
               case 0x03 : Play_Song(0);break;  //播放
               case 0x04 : P0=0xff;
                                TR0 = 1;speak=0;
                                 break;
void Time0_Int() interrupt 1
TH0 = 0xD8;
TL0 = 0xEF;
Count++;   //長度加1
新建文件夾 (2).zip
65.57 KB, 下載次數: 12
