查看: 4026|回復: 11
單片機用byte定義數組keil編譯警告 missing';'before
回帖獎勵 3 黑幣 回復本帖可獲得 3 黑幣獎勵! 每人限 1 次(中獎概率 50%)
警告如下:
missing';'before sz
單片機源碼如下:
#include <REG52.H>
#include "intrins.h"
int x;
sbit d6=P2^6;
sbit d5=P2^5;
sbit d4=P2^4;
byte[8] sz=={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
BYTE code sz1[]={0x35,0xAD,0xAD,0x98,0x0D,0x6B,0x08,0xFD};//×£
BYTE code sz2[]={0x99,0x5A,0x00,0xFF,0x16,0x55,0x10,0xFD};//oØ
BYTE code sz3[]={0x00,0xDB,0xC3,0xDB,0xC3,0x7E,0x00,0xE7};//òË
BYTE code sz4[]={0xBD,0xDB,0x00,0xEB,0xC3,0x5E,0x00,0xE7};//±ö
BYTE code sz5[]={0xEF,0x2D,0x6D,0x6D,0x01,0xEF,0x01,0xC7};//êD
BYTE code sz6[]={0x81,0xED,0x81,0xAF,0x81,0xFF,0xAA,0x99};//μú
BYTE code sz7[]={0xEF,0xEF,0xEF,0x01,0xEF,0xEF,0xEF,0xFF};//ê®
BYTE code sz8[]={0x82,0xAA,0xAA,0x82,0xEE,0x00,0x7E,0x00};//½ì
BYTE code sz9[]={0xEF,0xEF,0xEF,0x01,0x6D,0x01,0xEF,0xEF};//ÖD
BYTE code sz10[]={0xF7,0x50,0x55,0xF1,0x15,0x51,0x15,0xE0};//Ö°
BYTE code sz11[]={0xEF,0xEF,0x03,0xEF,0xDF,0x45,0x01,0xAB};//ѧ
BYTE code sz12[]={0x01,0xEF,0xEF,0x01,0xEF,0x01,0xEB,0xEF};//éú
BYTE code sz13[]={0xAD,0xAD,0xDD,0xA8,0x8D,0xD8,0x8D,0xDD};//¼¼
BYTE code sz14[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//Äü
BYTE code sz15[]={0x7D,0xBB,0xD7,0xD7,0xEF,0x01,0xEF,0xEF};//′ó
BYTE code sz16[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//èü
BYTE code sz17[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//è¡
BYTE code sz18[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//μÃ
BYTE code sz19[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//Ô°
BYTE code sz20[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//Âú
BYTE code sz21[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//3é
BYTE code sz22[]={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};//1|
void ys (int q)
        int w;
        for (;q>0;q--)
        for(w=0;w<115;w++);
void hc595 (char bat)
        char w;
        d6=0;
        d5=0;
        for(w=0;w<8;w++)
                d4=bat>>7;
                bat<<=1;
                d6=1;
                _nop_();
                d6=0;
        d5=1;
        _nop_();
        _nop_();
        d5=0;
void sf ()
        char p;
         switch (x)
                 case 1:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz1[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 3:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz2[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 5:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz3[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 7:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz4[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 9:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz5[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 11:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz6[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 13:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz7[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 15:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz8[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 17:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz9[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 19:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz10[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 21:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz11[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
                         case 23:
                         for(p=0;p<8;p++)
                                 hc595 (sz[p]);
                                 P1=sz12[p];
                                 ys(1);
                                 P1=0xff;
                                 break;
void Timer0Init(void)                //20??@11.0592MHz
        TMOD = 0x01;
        TL0 = 0x00;                //??????
        TH0 = 0xB8;
        TF0 = 0;                //??TF0??
        TR0 = 1;                //???0????
        EA=1;
        Timer0Init();
                sf();
void tm0_isr() interrupt 1 using 1
        int y,s;
        TL0 = 0xEE;                //??????
        TH0 = 0xFF;                //??????
        y++;
        if(y==25)
                y=0;
                s++;
                if(s%2)
                        x++;
ID:421201 發表于 2018-11-5 17:40 | 只看該作者
可能又一個是中文的‘;’或是少了一個‘;’ 吧!再仔細檢查檢查
ID:261288 發表于 2018-11-5 17:55 | 只看該作者
數組byte[8] sz聲明不合法,改為byte sz[8]
ID:277550 發表于 2018-11-5 19:45 | 只看該作者
#include <REG52.H>
#define BYTE unsigned char
int x;
sbit d6=P2^6;
sbit d5=P2^5;
sbit d4=P2^4;
BYTE[8] sz=={0x80,0x40,0x20,0x10,0x08,0x04,0x02,0x01};
ID:149144 發表于 2018-11-6 11:22 | 只看該作者
== 是什么鬼 ?
ID:421670 發表于 2018-11-6 13:38 | 只看該作者
換成unsigned char試試
ID:387733 發表于 2018-11-6 14:21 | 只看該作者
數據類型 BYTE 沒有定義,使用“BYTE”前需要定義:
typedef        unsigned char BYTE;
或者
ID:421812 發表于 2018-11-6 16:29 | 只看該作者
可能存在漢字的分號,uchar code 干脆寫成 code char 。忽視那個#define uchar unsigned char,頭文件 "1602.h" 有殘缺,你可以先屏蔽掉,或者搞個空文件給她引用,看看是否任然有錯。
ID:396996 發表于 2018-11-6 19:16 | 只看該作者
多了一個=
ID:422055 發表于 2018-11-6 23:05 | 只看該作者
在第十行上面有中文;
ID:421986 發表于 2018-11-7 11:04 | 只看該作者
BYTE[8] sz==
改成BYTE sz[8]=試試?
ID:420218 發表于 2018-11-7 11:45 | 只看該作者
寫完后檢查一下,缺個分號能讓你愁一天,
