查看: 1479|回復: 0
Infineon-TLE6251DS-DS-v03_10-EN資料下載
Description
The CAN-transceiver TLE6251DS is a monolithic integrated circuit in a PG-DSO-8 package for
high speed differential mode data transmission (up to 1 Mbaud) and reception in automotive and
industrial applications. It works as an interface between the CAN protocol controller and the
physical bus lines compatible to ISO/DIS 11898.
As a successor to the first generation of HS CAN (TLE6250), the TLE6251DS is designed to
provide an excellent passive behavior when the  transceiver is switched off (mixed networks,
terminal 15/30 applications) and a remote wake-up capability via CAN bus in low power mode.
This supports networks with partially un-powered nodes.
The TLE6251DS has two operation modes, the normal and the stand-by mode. These modes can
be chosen by the STB pin. If the TLE6251DS is in stand-by mode and a message on the bus is
Infineon-TLE6251DS-DS-v03_10-EN.pdf
555.54 KB, 下載次數: 4, 下載積分: 黑幣 -5
