查看: 6464|回復: 3
error C267: 'SectorErase': requires ANSI-style prototype編譯錯誤
ID:420280 發表于 2018-11-3 22:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
哪位大佬知道這個是什么意思嗎
K.C(65): error C267: 'SectorErase': requires ANSI-style prototype
ID:420280 發表于 2018-11-3 22:20 | 只看該作者
#include <REG52.h>
#include<intrins.h>
#include "main.h"
#include<rc522.c>
#include<eeprom52.h>
#define LCM_Data  P0
#define uint  unsigned int
sbit lcd1602_rs=P2^5;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^7;
sbit ALAM = P2^1;                //報警
sbit KEY = P3^6;                //開鎖
bit  operation=0;                //操作標志位
bit  pass=0;                        //密碼正確標志
bit  ReInputEn=0;                //重置輸入充許標志
bit  s3_keydown=0;                //3秒按鍵標志位
bit  key_disable=0;                //鎖定鍵盤標志
bit  chushihua=0;       //可以注冊卡標志位
unsigned char countt0,second;        //t0中斷計數器,秒計數器
//解碼變量
unsigned char Im[4]={0x00,0x00,0x00,0x00};
//全局變量
uchar f,a_a;
unsigned long m,Tc;
unsigned char   IrOK;
unsigned char xdata CardRevBuf[16] = { 0 };
//void Delay5Ms(void);
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};        //控盤掃描控制表
unsigned char code start_line[]        = {"password:       "};
unsigned char code name[]                  = {"===Coded Lock==="};        //顯示名稱
unsigned char code Correct[]         = {"     correct    "};        //輸入正確
unsigned char code Error1[]           = {"      error     "};        //輸入錯誤
unsigned char code codepass[]        = {"      pass      "};
unsigned char code LockOpen[]        = {"      open      "};        //OPEN
unsigned char code SetNew[]         = {"SetNewWordEnable"};
unsigned char code Input[]           = {"input:          "};        //INPUT
unsigned char code ResetOK[]         = {"ResetPasswordOK "};
unsigned char code initword[]        = {"Init password..."};
unsigned char code Er_try[]                = {"error,try again!"};
unsigned char code again[]                = {"input again     "};
unsigned char InputData[6];        //輸入密碼暫存區
unsigned char CurrentPassword[6]={1,3,1,4,2,0};        //當前密碼值
unsigned char TempPassword[6];
unsigned char N=0;                                //密碼輸入位數記數
unsigned char ErrorCont;                        //錯誤次數計數
unsigned char CorrectCont;                        //正確輸入計數
unsigned char ReInputCont;                         //重新輸入計數
unsigned char code initpassword[6]={0,0,0,0,0,0};
unsigned char current_id;
char xdata DisplayBuf[10];  //當前讀出卡的ID
char xdata DisplayBuf_c[10];  //當前單片機里存的卡ID
void write_eeprom()
        SectorErase(0x200a);                   //清空
    byte_write(0x2000,TempPassword[0]);
         byte_write(0x2001,TempPassword[1]);
         byte_write(0x2002,TempPassword[2]);
         byte_write(0x2003,TempPassword[3]);
         byte_write(0x2004,TempPassword[4]);
         byte_write(0x2005,TempPassword[5]);
        byte_write(0x2060,0x02);
void write_eeprom_j(unsigned char j)                  //將對應的ID寫入到單片機
        SectorErase(0x2200+j*0x0200);                   //清空
        byte_write(0x2200+j*0x0200,DisplayBuf[0]);
        byte_write(0x2201+j*0x0200,DisplayBuf[1]);
        byte_write(0x2202+j*0x0200,DisplayBuf[2]);
        byte_write(0x2203+j*0x0200,DisplayBuf[3]);
        byte_write(0x2204+j*0x0200,DisplayBuf[4]);
        byte_write(0x2205+j*0x0200,DisplayBuf[5]);
        byte_write(0x2206+j*0x0200,DisplayBuf[6]);
        byte_write(0x2207+j*0x0200,DisplayBuf[7]);
void write_eeprom_jj(unsigned char j)         //將對應的ID清空
        byte_write(0x2200+j*0x0200,' ');
        byte_write(0x2201+j*0x0200,' ');
        byte_write(0x2202+j*0x0200,' ');
        byte_write(0x2203+j*0x0200,' ');
        byte_write(0x2204+j*0x0210,' ');
        byte_write(0x2205+j*0x0200,' ');
        byte_write(0x2206+j*0x0200,' ');
        byte_write(0x2207+j*0x0200,' ');
void read_eeprom_j(uchar j)
  DisplayBuf_c[0]= byte_read(0x2200+j*0x0200);
  DisplayBuf_c[1]= byte_read(0x2201+j*0x0200);
  DisplayBuf_c[2]= byte_read(0x2202+j*0x0210);
  DisplayBuf_c[3]= byte_read(0x2203+j*0x0200);
  DisplayBuf_c[4]= byte_read(0x2204+j*0x0200);
  DisplayBuf_c[5]= byte_read(0x2205+j*0x0200);
  DisplayBuf_c[6]= byte_read(0x2206+j*0x0200);
  DisplayBuf_c[7]= byte_read(0x2207+j*0x0200);
/******************把數據從單片機內部eeprom中讀出來*****************/
void read_eeprom()
    CurrentPassword[0]= byte_read(0x2000);
        CurrentPassword[1]= byte_read(0x2011);
        CurrentPassword[2]= byte_read(0x2002);
        CurrentPassword[3]= byte_read(0x2003);
        CurrentPassword[4]= byte_read(0x2004);
    CurrentPassword[5]= byte_read(0x2005);
        a_a = byte_read(0x2060);
/**************開機自檢eeprom初始化*****************/
void init_eeprom()
    uchar i,j;
        if(a_a != 1)                //新的單片機初始單片機內問eeprom
                a_a = 1;
                for(i=0;i<6;i++)
                  SectorErase(0x2200+i*0x0200);
                  for(j=0;j<8;j++)
                  byte_write(0x2200+i*0x0200+j,'0');
            write_eeprom();           //保存數據
//=====================5ms延時==============================
void Delay5Ms()
        unsigned int TempCyc = 5552;
        while(TempCyc--);
//===================400ms延時==============================
void Delay400Ms()
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//=======================================LCD1602====================================================
#define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
#define er 0x80+40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
//----------------延時函數,后面經常調用----------------------
void delay(uint xms)//延時函數,有參函數
        uint x,y;
        for(x=xms;x>0;x--)
         for(y=110;y>0;y--);
//--------------------------寫指令---------------------------
void write_1602com(uchar com)//****液晶寫入指令函數****
        lcd1602_rs=0;//數據/指令選擇置為指令
        lcd1602_rw=0; //讀寫選擇置為寫
        P0=com;//送入數據
        delay(1);
        lcd1602_en=0;//拉高使能端,為制造有效的下降沿做準備
        delay(1);
        lcd1602_en=1;//en由高變低,產生下降沿,液晶執行命令
//-------------------------寫數據-----------------------------
void write_1602dat(uchar dat)//***液晶寫入數據函數****
        lcd1602_rs=1;//數據/指令選擇置為數據
        lcd1602_rw=1; //讀寫選擇置為寫
        P0=dat;//送入數據
        delay(1);
        lcd1602_en=0; //en置高電平,為制造下降沿做準備
        delay(1);
        lcd1602_en=1; //en由高變低,產生下降沿,液晶執行命令
//-------------------------初始化-------------------------
void lcd_init()
        write_1602com(0x01);//清顯示
        write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
        write_1602com(0x0c);//開顯示不顯示光標
        write_1602com(0x06);//整屏不移動,光標自動右移
//==============將按鍵值編碼為數值=========================
unsigned char coding(unsigned char m1,unsigned char hh)
        unsigned char k;
        if(IrOK==1)
                IrOK=0;
                switch(m1)
                        case (0x0c): k=1;break;
                        case (0x18): k=2;break;
                        case (0x5e): k=3;break;
//                        case (0xff): k='A';break;         //
                        case (0x08): k=4;break;
                        case (0x1c): k=5;break;
                        case (0x50): k=6;break;
//                        case (0x82): k='B';break;           //
                        case (0x42): k=7;break;
                        case (0x52): k=8;break;
                        case (0x4a): k=9;break;
//                        case (0x84): k='C';break;        //
                        case (0x43): k='*';break;          //撤銷
                        case (0x16): k=0;break;
                        case (0x15): k='#';break;           //確認鍵
                        case (0x0d): k='D';break;           //重設密碼
                        case (0x4e): k='B';break;         //
                        case (0x47): k='C';break;         //
                        case (0x44): k='A';break;         //
                        case (0x40): k='A';break;         //
                        case (0x07): k='A';break;         //
                        case (0x09): k='A';break;         //
                        case (0x19): k='A';break;         //
//                        default:;
                switch(hh)
                        case (0x11): k=1;break;
                        case (0x21): k=2;break;
                        case (0x41): k=3;break;
                        case (0x81): k='A';break;
                        case (0x12): k=4;break;
                        case (0x2a): k=5;break;
                        case (0x42): k=6;break;
                        case (0x14): k=7;break;
                        case (0x24): k=8;break;
                        case (0x4b): k=9;break;
                        case (0x18): k='*';break;
                        case (0x28): k=0;break;
                        case (0x48): k='#';break;
                        case (0x88): k='D';break;
//                        default:;
        return(k);
//=====================按鍵檢測并返回按鍵值===============================
unsigned char keynum()
        unsigned char row,col,i;
        P1=0xf0;
        if((P1&0xf0)!=0xf0)
                   Delay5Ms();
        Delay5Ms();
                   if((P1&0xf0)!=0xf0)
                    row=P1^0xf0;          //確定行線
                        i=0;
                        P1=a[i];                  //精確定位
                        while(i<4)
                                 if((P1&0xf0)!=0xf0)
                                           col=~(P1&0xff);          //確定列線
                                           break;            //已定位后提前退出
                                           i++;
                                           P1=a[i];
                        return 0;
                while((P1&0xf0)!=0xf0);
                return (row|col);                         //行線與列線組合后返回
        else return 0;                                 //無鍵按下時返回0
//=======================一聲提示音,表示有效輸入========================
void OneAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================二聲提示音,表示操作成功========================
void TwoAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//========================三聲提示音,表示錯誤========================
void ThreeAlam()
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
    Delay5Ms();
        ALAM=0;
        Delay5Ms();
    ALAM=1;
//=====================顯示輸入的N個數字,用H代替以便隱藏============================
void DisplayOne()
//        DisplayOneChar(9+N,1,'*');
        write_1602com(yi+5+N);
        write_1602dat('*');
//=======================顯示提示輸入=========================
void DisplayChar()
        unsigned char i;
        if(pass==1)
                //DisplayListChar(0,1,LockOpen);
                write_1602com(er);
                for(i=0;i<16;i++)
                        write_1602dat(LockOpen[i]);
                if(N==0)
                        //DisplayListChar(0,1,Error);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(Error1[i]);
                        //DisplayListChar(0,1,start_line);
                        write_1602com(er);
                        for(i=0;i<16;i++)
                                write_1602dat(start_line[i]);
void DisplayInput()
        unsigned char i;
        if(CorrectCont==1)
                //DisplayListChar(0,0,Input);
                write_1602com(er);
                for(i=0;i<16;i++)
                        write_1602dat(Input[i]);
//========================重置密碼==================================================
void ResetPassword()
        unsigned char i;
        unsigned char j;
        if(pass==0)
                pass=0;
                DisplayChar();
                ThreeAlam();
            if(ReInputEn==1)
                        if(N==6)
                                ReInputCont++;
                                if(ReInputCont==2)
                                        for(i=0;i<6;)
                                                if(TempPassword[i]==InputData[i])        //將兩次輸入的新密碼作對比
                                                        i++;
                                                        write_1602com(er);
                                                        for(j=0;j<16;j++)
        write_1602dat(Error1[j]);
                                                        ThreeAlam();                        //錯誤提示
                                                        pass=0;
                                                        ReInputEn=0;                        //關閉重置功能,
                                                        ReInputCont=0;
                                                        DisplayChar();
                                                        break;
                                        if(i==6)
                                                //DisplayListChar(0,1,ResetOK);
                                                write_1602com(er);
                                                for(j=0;j<16;j++)
                                                        write_1602dat(ResetOK[j]);
                                                TwoAlam();                                //操作成功提示
                        write_eeprom();
                                                ReInputEn=0;
                                        ReInputCont=0;
                                        CorrectCont=0;
                                        OneAlam();
                                        //DisplayListChar(0, 1, again);                 //顯示再次輸入一次
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(again[j]);
                                        for(i=0;i<6;i++)
                                                TempPassword[i]=InputData[i];                //將第一次輸入的數據暫存起來
                        N=0;                                                //輸入數據位數計數器清零
//=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
void Alam_KeyUnable()
        P1=0x00;
                ALAM=~ALAM;
                Delay5Ms();
//=======================取消所有操作============================================
void Cancel()
        unsigned char i;
        unsigned char j;
        //DisplayListChar(0, 1, start_line);
        write_1602com(er);
        for(j=0;j<16;j++)
                write_1602dat(start_line[j]);
        TwoAlam();                                //提示音
        for(i=0;i<6;i++)
                InputData[i]=0;
        KEY=1;                                        //關閉鎖
        ALAM=1;                                        //報警關
        operation=0;                        //操作標志位清零
        pass=0;                                        //密碼正確標志清零
        ReInputEn=0;                        //重置輸入充許標志清零
//        ErrorCont=0;                        //密碼錯誤輸入次數清零
        CorrectCont=0;                        //密碼正確輸入次數清零
        ReInputCont=0;                        //重置密碼輸入次數清零
        s3_keydown=0;
        key_disable=0;
        N=0;                                        //輸入位數計數器清零
//==========================確認鍵,并通過相應標志位執行相應功能===============================
void Ensure()
        unsigned char i,j;
//        RdFromROM(CurrentPassword,0,6);                                         //從24C02里讀出存儲密碼
    read_eeprom();
    if(N==6)
            if(ReInputEn==0)                                                        //重置密碼功能未開啟
                        for(i=0;i<6;)
                                if(CurrentPassword[i]==InputData[i])
                                        i++;
                                        i=7;
                                        ErrorCont++;
                                        if(ErrorCont>=3&&KEY==1)                        //錯誤輸入計數達三次時,報警并鎖定鍵盤
                                                write_1602com(er);
                                                for(i=0;i<16;i++)
                                                Alam_KeyUnable();
                                                TR0=0;                                //開啟定時
                                                key_disable=1;                        //鎖定鍵盤
                                                pass=0;
                                                break;
                        if(i==6)
                                CorrectCont++;
                                if(CorrectCont==1)                                //正確輸入計數,當只有一次正確輸入時,開鎖,
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(LockOpen[j]);
                                        TwoAlam();                        //操作成功提示音
                                        ErrorCont=0;
                                        KEY=0;        //開鎖
                                        pass=1;        //置正確標志位
                                        TR1=1;        //開啟定時
                                        for(j=0;j<6;j++)        //將輸入清除
                                                InputData[i]=0;
                                else        //當兩次正確輸入時,開啟重置密碼功能
                                        //DisplayListChar(0,1,SetNew);
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(SetNew[j]);
                                        TwoAlam();        //操作成功提示
                                        ReInputEn=1;        //允許重置密碼輸入
                                        CorrectCont=0;        //正確計數器清零
                        else                        //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
                                if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
//                                        WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
                                        //DisplayListChar(0,1,initword);                        //顯示初始化密碼
                                        TwoAlam();
                                        Delay400Ms();
                                        TwoAlam();
                                        N=0;
                                        chushihua=1;
                                else if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==1))
                     TempPassword[0]=0;
                                         TempPassword[1]=0;
                                         TempPassword[2]=0;
                                         TempPassword[3]=0;
                                         TempPassword[4]=0;
                                         TempPassword[5]=0;
                     write_eeprom();
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                                write_1602dat(initword[j]);
                                        TwoAlam();
                                        Delay400Ms();
                                        TwoAlam();
                                        N=0;
                                        write_1602com(er);
                                        for(j=0;j<16;j++)
                                        ThreeAlam();        //錯誤提示音
                                        pass=0;
                else        //當已經開啟重置密碼功能時,而按下開鎖鍵,
                        //DisplayListChar(0,1,Er_try);
                        write_1602com(er);
                        for(j=0;j<16;j++)
                                write_1602dat(Er_try[j]);
                        ThreeAlam();
                write_1602com(er);
                for(j=0;j<16;j++)
                pass=0;
        N=0;        //將輸入數據計數器清零,為下一次輸入作準備
        operation=1;
void display_id( unsigned char xdata * SrcBuf )
        char xdata *pDisplayChar;
        unsigned char xdata Tmp, i;
        pDisplayChar = DisplayBuf;
        for( i = 0; i < 4; i++ )
                Tmp = ( ( *SrcBuf ) << 4 ) & 0x0F;
                if( ( Tmp >=0 ) && ( Tmp <= 9 )        )
                        *pDisplayChar ++ = '0' + Tmp;
                        *pDisplayChar ++ = 'A' + Tmp - 10;
                Tmp = ( *SrcBuf ) & 0x0F;
                SrcBuf ++;
        *pDisplayChar ++ = '\0';
//        DisplayListChar( 0, 4, DisplayBuf );
        if(chushihua==1)
    write_1602com(0xc0);
        write_1602dat('I');
        write_1602dat('D');
        write_1602dat(current_id+0x30);
        write_1602dat(':');
        write_1602dat(DisplayBuf[0]);
        write_1602dat(DisplayBuf[1]);
        write_1602dat(DisplayBuf[2]);
        write_1602dat(DisplayBuf[3]);
        write_1602dat(DisplayBuf[4]);
        write_1602dat(DisplayBuf[5]);
        write_1602dat(DisplayBuf[6]);
        write_1602dat(DisplayBuf[7]);
        write_1602dat(' ');
        write_1602dat(' ');write_1602dat(' ');write_1602dat(' ');write_1602dat(' ');
void display_no_id()
          write_1602dat('I');
        write_1602dat('D');
        write_1602dat(':');
        write_1602dat(DisplayBuf_c[0]);
        write_1602dat(DisplayBuf_c[1]);
        write_1602dat(DisplayBuf_c[2]);
        write_1602dat(DisplayBuf_c[3]);
        write_1602dat(DisplayBuf_c[4]);
        write_1602dat(DisplayBuf_c[5]);
        write_1602dat(DisplayBuf_c[6]);
        write_1602dat(DisplayBuf_c[7]);
                write_1602dat(' ');
void ctrl( void )
    uchar j,i;
        if( PcdRequest( PICC_REQIDL, &CardRevBuf[0] ) != MI_OK )//尋天線區內未進入休眠狀態的卡,返回卡片類型 2字節
                 if(chushihua==1)
                 read_eeprom_j(current_id);
                 display_no_id();
                        return;
        if( PcdAnticoll( &CardRevBuf[2] ) != MI_OK ) //防沖撞,返回卡的序列號 4字節
        if(chushihua==1)
        display_no_id();
                return;
        if( PcdSelect( &CardRevBuf[2] ) != MI_OK )//選卡
        if(chushihua==1)
          display_no_id();
                return;
        display_id( &CardRevBuf[2] );
        if(CorrectCont==0&&pass==0)
          for(j=0;j<6;j++)
          read_eeprom_j(j);
           if(DisplayBuf[0]==DisplayBuf_c[0]&&DisplayBuf[1]==DisplayBuf_c[1]&&DisplayBuf[2]==DisplayBuf_c[2]&&DisplayBuf[3]==DisplayBuf_c[3]&&DisplayBuf[4]==DisplayBuf_c[4]&&DisplayBuf[5]==DisplayBuf_c[5])
                  CorrectCont=1;
                  write_1602com(er);
                        for(j=0;j<16;j++)
                        ErrorCont=0;
                        KEY=0;        //開鎖
                        pass=1;        //置正確標志位
                        TR0=1;        //開啟定時
                                InputData[i]=0;
                return;
//==============================主函數===============================
        unsigned char KEY,NUM;
        unsigned char i,j;
        P1=0xFF;
        EA=1;
        TMOD=0x01;
        IT1=1;//下降沿有效
        EX1=1;//外部中斷1開
        TH0=0;//T0賦初值
        TL0=0;
        TR0=1;//t0開始計時
        TL1=0x3c;
        TH1=0xb0;
        ET1=1;
        TR1=0;
        Delay400Ms();         //啟動等待,等LCM講入工作狀態
        lcd_init();         //LCD初始化
        write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
        init_rc522();
        init_eeprom();
        read_eeprom();
        for(i=0;i<16;i++)
                write_1602dat(name[i]);//向液晶屏寫日歷顯示的固定符號部分
        write_1602com(er);//時間顯示固定符號寫入位置,從第2個位置后開始顯示
        for(i=0;i<16;i++)
                write_1602dat(start_line[i]);//寫顯示時間固定符號,兩個冒號
        write_1602com(er+9);        //設置光標位置
        write_1602com(0x0f);        //設置光標為閃爍
        Delay5Ms(); //延時片刻(可不要)
        N=0;        //初始化數據輸入位數
                ctrl();
                if(key_disable==1)
                        Alam_KeyUnable();
                        ALAM=1;        //關報警
                KEY=keynum();
                if(KEY!=0||IrOK==1)
                        if(key_disable==1)
                                second=0;
                                NUM=coding(Im[2],KEY);
                                        switch(NUM)
                                                case ('A'): if(chushihua==1)
                                                             current_id++;
                                                            if(current_id>5)
        current_id=0;
        }                                        break;
                                                case ('B'):        if(chushihua==1)
                                                             write_eeprom_jj(current_id)        ;                                             break;
                                                case ('C'): if(chushihua==1)
                                                             write_eeprom_j(current_id)        ;                                         break;
                                                case ('D'): chushihua=0;ResetPassword();                break;      //重新設置密碼
                                                case ('*'): chushihua=0;Cancel();                                break;      //取消當前輸入
                                                case ('#'): chushihua=0; Ensure();                                 break;           //確認鍵,
                                                default:
                                                    chushihua=0;
                                                        //DisplayListChar(0,1,Input);
                                                        write_1602com(er);
                                                        for(i=0;i<16;i++)
                                                    operation=0;
                                                        if(N<6)                                                           //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
        OneAlam();        //按鍵提示音
        //DisplayOneChar(6+N,1,'*');
        for(j=0;j<=N;j++)
        write_1602com(er+6+j);
        write_1602dat('*');
        InputData[N]=NUM;
        N++;
                                                        else        //輸入數據位數大于6后,忽略輸入
        N=6;
        break;
//*********************************中斷服務函數**************************************
void  time1_int() interrupt 3
        TL1=0x3c;
        TH1=0xb0;
        countt0++;
          if(countt0==20)
                countt0=0;
                second++;
                if(pass==1)
                        if(second==1)
                                TR1=0;                                //關定時器
                                TL1=0xB0;
                                TH1=0x3C;
                                second=0;
                        if(second==3)
                                TR1=0;
                                second=0;
                                key_disable=0;
                                s3_keydown=0;
                                TL1=0xB0;
                                TH1=0x3C;
                            TR1=1;
ID:505850 發表于 2019-4-15 21:18 | 只看該作者
樓主找到解決方法了嗎?
ID:782510 發表于 2020-12-9 10:41 | 只看該作者
樓主,這個怎么解決?
