LED點陣數字倒計時
#include <REG51.H>
//--重定義函數變量--// #define uchar unsigned char #define uint unsigned int #define ulong unsigned long
//--定義SPI要使用的 IO--// sbit MOSIO = P3^4; sbit R_CLK = P3^5; sbit S_CLK = P3^6;
//---全局變量聲明--// ulong column; //點陣列 ulong row; //點陣行 ulong dt;
//--點陣顯示數組--// uchar code tab0[] = {0x00, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00,0x08, 0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00,0x80, 0x01, 0x00, 0x02, 0x00, 0x04, 0x00, 0x08,0x00, 0x10, 0x00, 0x20, 0x00, 0x40, 0x00, 0x80,0x00};
//--10字模--// uchar code tab1[] = {0, 0, 0, 0, 0, 0, 8, 24, 14, 36, 8, 66, 8,66, 8, 66, 8,66, 8, 66, 8, 66, 8, 36, 62, 24, 0, 0, 0, 0, 0, 0};
//--09字模--// uchar code tab2[] = {0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66,66, 66, 66, 66,66, 100, 66, 88, 66, 64, 66, 64, 36, 36, 24, 28, 0, 0, 0, 0} ;
//--08字模--// uchar code tab3[] = {0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 66, 66, 36, 66, 24, 66, 36, 66, 66, 66, 66, 36, 66, 24,60, 0, 0, 0, 0};
//--07字模--// uchar code tab4[] = {0, 0, 0, 0, 0, 0, 24, 126, 36, 34, 66, 34,66, 16, 66, 16, 66,8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 8, 0, 0, 0, 0};
//--06字模--// uchar code tab5[] = {0, 0, 0, 0, 0, 0, 24, 56, 36, 36, 66, 2,66, 2, 66, 26, 66, 38,66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0, 0, 0, 0};
//--05字模--// uchar code tab6[] = {0, 0, 0, 0, 0, 0, 24, 126, 36, 2, 66, 2,66, 2, 66, 26, 66, 38,66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--04字模--// uchar code tab7[] = {0, 0, 0, 0, 0, 0, 24, 32, 36, 48, 66, 40,66, 36, 66, 36, 66, 34, 66, 34, 66, 126, 66, 32, 36, 32, 24, 120,0, 0, 0, 0};
//--03字模--// uchar code tab8[] = {0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 32, 66, 24, 66, 32,66, 64, 66, 64, 66, 66, 36, 34, 24, 28, 0, 0, 0, 0};
//--02字模--// uchar code tab9[] = {0, 0, 0, 0, 0, 0, 24, 60, 36, 66, 66, 66,66, 66, 66, 32, 66, 32,66, 16, 66, 8, 66, 4, 36, 66, 24, 126, 0, 0, 0, 0};
//--01字模--// uchar code tab10[] = {0, 0, 0, 0, 0, 0, 24, 8, 36, 14, 66, 8,66, 8, 66, 8, 66, 8, 66, 8, 66, 8, 66, 8, 36, 8, 24, 62, 0, 0, 0,0};
//--00字模--// uchar code tab11[] = {0, 0, 0, 0, 0, 0, 24, 24, 36, 36, 66, 66,66, 66, 66, 66, 66, 66, 66, 66, 66, 66, 66, 66, 36, 36, 24, 24, 0,0, 0, 0};
//--GO--// uchar code tab12[] = {0, 0, 0, 0, 0, 0, 60, 28, 34, 34, 34, 65,1, 65, 1, 65, 1, 65, 113, 65,33, 65, 34, 65, 34, 34, 28, 28, 0, 0, 0, 0};
//--全局函數聲明--// void HC595SendData( uchar BT3, uchar BT2,uchar BT1,uchar BT0);
/******************************************************************************* * 函 數 名 : main * 函數功能 : 主函數 * 輸 入 : 無 * 輸 出 : 無 *******************************************************************************/
void main(void) { intk, i, ms;
i= 60; //顯示時間
while(1) { //--顯示10--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab1[2*k+1],~tab1[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--清屏--// HC595SendData(0xff,0xff,0,0);
//--顯示09--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab2[2*k+1],~tab2[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示08--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab3[2*k+1],~tab3[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示07--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab4[2*k+1],~tab4[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示06--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab5[2*k+1],~tab5[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示05--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) //歡 { HC595SendData(~tab6[2*k+1],~tab6[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示04--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab7[2*k+1],~tab7[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示03--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab8[2*k+1],~tab8[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示02--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab9[2*k+1],~tab9[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示01--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab10[2*k+1],~tab10[2*k],tab0[2*k],tab0[2*k + 1]); } }
//--顯示00--// for(ms= i; ms > 0; ms--) { for(k= 0; k < 16; k++) { HC595SendData(~tab11[2*k+1],~tab11[2*k],tab0[2*k],tab0[2*k + 1]); } } //--清屏--// HC595SendData(0xff,0xff,0,0); //清屏
//--一直顯示G0--// while(1) { for(k= 0; k < 16; k++) //中 { HC595SendData(~tab12[2*k+1],~tab12[2*k],tab0[2*k],tab0[2*k + 1]); } } } } /******************************************************************************* * 函 數 名 : HC595SendData * 函數功能 : 通過595發送四個字節的數據 * 輸 入 : BT3:第四個595輸出數值 * * BT2: 第三個595輸出數值 * * BT1:第二個595輸出數值 * * BT0:第一個595輸出數值 * 輸 出 : 無 *******************************************************************************/
void HC595SendData( uchar BT3, uchar BT2,uchar BT1,uchar BT0) { uchari;
//--發送第一個字節--// for(i=0;i<8;i++) { MOSIO= BT3 >> 7 ; //從高位到低位 BT3<<= 1;
S_CLK= 0; S_CLK= 1; }
//--發送第一個字節--// for(i=0;i<8;i++) { MOSIO= BT2 >>7; //從高位到低位 BT2<<= 1;
//--發送第一個字節--// for(i=0;i<8;i++) { MOSIO= BT1 >> 7; //從高位到低位 BT1<<= 1; S_CLK= 0; S_CLK= 1; }
//--發送第一個字節--// for(i=0;i<8;i++) { MOSIO= BT0 >> 7; //從高位到低位 BT0<<= 1; S_CLK= 0; S_CLK= 1; }
//--輸出--// R_CLK= 0; //set dataline low R_CLK= 1; //片選 R_CLK= 0; //set dataline low }
