查看: 1220|回復: 0
1602顯示Hello! Baby!
ID:376586 發表于 2018-10-31 11:33 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
uchar code table[]="Hello! Baby!";
uchar table1[]="0123456789" ;
uint sec,min,hour,tt,num;
sbit  RS=P3^1;
sbit  LE=P3^0;
sbit  k1=P3^4;
sbit  k2=P3^5;
void delay(uint i)
        while(i--);
void write_com(uchar com)
        RS=0;
        P0=com;
        delay(50);
        LE=1;
        delay(50);
        LE=0;
void write_data(uchar date)
        RS=1;
        P0=date;
        delay(50);
        LE=1;
        delay(50);
        LE=0;
void init()
        LE=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
        write_com(0x80);
        sec=00;
        min=00;
        hour=00;
void init1()
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
void diaplay()
        write_com(0x80+2);
        for(num=0;num<13;num++)
                write_data(table[num]);
void diaplay1()
        uchar i;
        for(i=0;i<8;i++)
                if(sec==60)
                        sec=0;
                        min++;
                        if(min==60)
                                min=0;
                                hour++;
                                if(hour==24)
                                        hour=0;
        write_com(0xc0+10);
        write_data(table1[sec/10]);
        write_com(0xc0+11);
        write_data(table1[sec%10]);
        write_com(0xc0+8);
        write_data(':');
        write_com(0xc0+6);
        write_data(table1[min/10]);
        write_data(table1[min%10]);
        write_com(0xc0+4);
        write_data(':');
        write_com(0xc0+2);
        write_data(table1[hour/10]);
        write_data(table1[hour%10]);
void keyscan()
        if(k1==0)
                sce=0;
                delay(10);
                if(k1==0)
                        while(!k1);
                        min++;
                        if(min==60)
                                min=0;
        if(k2==0)
        {  sce=0;
                delay(10);
                if(k2==0)
                        while(!k2);
                        hour++;
                        if(hour==24)
                                hour=0;
        init();
        init1();
          diaplay();
          diaplay1();
          keyscan();
void time() interrupt 1
        tt++;
        if(tt==20)
                tt=0;
                sec++;
