查看: 2108|回復: 1
一個51單片機的8位搶答器
ID:417955 發表于 2018-10-30 15:29 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define START        0X01
#define TIME_OUT 0x02
#define BEGIN        0x03
//#define END 0x04
//#define RIGHT         0X05
#define ERROR        0x06
#define ACK        0x07
#define WAIT        0X08
unsigned char table[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0x88,0x83,0xC6,0xA1,0x86,0x8E};
unsigned char state=START;
unsigned char last_time=20,ack_time=30,num;
unsigned char i,tmp,count,count1,time;
sbit led1=P2^0;
sbit led2=P2^1;
sbit led3=P2^2;
sbit led4=P2^3;
sbit LIGHT=P3^2;
sbit SPK=P3^1;
sbit STR=P3^3;
sbit CLR=P3^4;
sbit ADD=P3^5;
sbit SUB=P3^6;
void init();
void display();
void delayms(unsigned char a);
void keyscan();
        init();
                switch(state)
                        case START:
                                while(P1==0xff)
                                        keyscan();
                                        display();
                                        if(state!=START)
                                                break;
                                        num=0;
                                tmp=P1;
                                for(i=0;i<8;i++)
                                        if((~tmp)&(1<<i))
                                                num=i+1;
                                                state=ERROR;
                                                P1=0XFF;
                                                break;
                                break;
                        case BEGIN:
                                while(P1==0xff)
                                        display();
                                //        keyscan();
                                        if(state!=BEGIN)
                                                break;
                                tmp=P1;
                                TR0=0;
                                for(i=0;i<8;i++)
                                        if((~tmp)&(1<<i))
                                                num=i+1;
                                                state=WAIT;
                                                TR0=1;
                                                break;
                                break;
                        case WAIT:
                                 keyscan();
                                 display();
                        case ACK:
                        //        num=0xff;
                                keyscan();
                                display();
                                break;
                        case TIME_OUT:
                                last_time=0;
                                display();
                                keyscan();
                                SPK=0;
                                LIGHT=0;
                                break;
                        case ERROR:
                                keyscan();
                                display();
                                SPK=0;
                                LIGHT=0;
                                break;
                        default:
                                break;
void display()
        unsigned char temp;
        if(state==BEGIN)
                temp=last_time;
                temp=ack_time;
        P0=table[temp/10];
        led1=0;
        led2=1;
        led3=1;
        led4=1;
        delayms(5);
        P0=table[temp%10];
        led1=1;
        led2=0;
        led3=1;
        led4=1;
        delayms(5);
        P0=table[num>>4];
        led1=1;
        led2=1;
        led3=0;
        led4=1;
        delayms(5);
        P0=table[num&0x0f];
        led1=1;
        led2=1;
        led3=1;
        led4=0;
        delayms(5);
        led1=1;
        led2=1;
        led3=1;
        led4=1;
void keyscan()
        if(state==START)
                if(STR==0)
                        delayms(10);
                        if(STR==0)
                                state=BEGIN;
                                TR0=1;
                        while(!STR);
                if(CLR==0)
                        delayms(10);
                        if(CLR==0)
                                last_time=20;
                                ack_time=30;
                                num=0;
                                SPK=1;
                                LIGHT=1;
                        while(!CLR);
                if(ADD==0)
                        delayms(10);
                        if(ADD==0)
                                ack_time++;
                                if(ack_time==100)
                                        ack_time=10;
                        while(!ADD);
                if(SUB==0)
                        delayms(10);
                        if(SUB==0)
                                ack_time--;
                                if(ack_time==10)
                                        ack_time=99;
                                while(!SUB);
        if(state==TIME_OUT||state==ACK||state==ERROR)
                if(CLR==0)
                        delayms(10);
                        if(CLR==0)
                                state=START;
                                last_time=20;
                                num=0;
                                TR0=0;
                                SPK=1;
                                LIGHT=1;
        //        while(!CLR);
        unsigned char j;
        for(a;a>0;a--)
                for(j=110;j>0;j--);
基于51單片機的8路搶答器設計c程序.rar
1.22 KB, 下載次數: 6, 下載積分: 黑幣 -5
ID:1 發表于 2018-10-30 16:47 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
