查看: 2348|回復: 1
tcs230顏色傳感器的單片機程序+原理圖
ID:416201 發表于 2018-10-27 11:05 | 顯示全部樓層 |閱讀模式
???о???AT89S52 ???? STC89C52 ??AT89S51 STC89C51
????12MHZ
????????Keil
?????zhengzhongxign39*/
#include <reg52.h>
#define uint  unsigned int
//==============LCD1602??????????=====================
       |DB0-----P2.0 | DB4-----P2.4 | RW-------P0.6    |
       |DB1-----P2.1 | DB5-----P2.5 | RS-------P0.7    |
       |DB2-----P2.2 | DB6-----P2.6 | E--------P0.5    |
       |DB3-----P2.3 | DB7-----P2.7 |
#define LCM_Data     P0   //LCD1602??????
#define Busy         0x80   //??????LCM?????е?Busy???
sbit    LCM_RW     = P3^6;  //??д??????????LCD1602??????
sbit    LCM_RS     = P3^5;  //??????????????LCD1602??????
sbit    LCM_E      = P3^4;  //???????????,LCD1602???6??
       |EO-----GND
       |S0-----VCC | S2-----P1.0 | OUT-------P3.5
       |S1-----VCC | S3-----P1.1 |
sbit    tcs230_s2=P1^0;//TCS230 S2??????P1.0
sbit    tcs230_s3=P1^1;//TCS230 S3??????P1.1
sbit    tcs230_en=P3^0; //TCS230 EN(E0)??GND
void    WriteDataLCM  (uchar WDLCM);//LCD???д????
void    WriteCommandLCM (uchar WCLCM,BuysC); //LCD???д???
uchar   ReadStatusLCM(void);//??LCD???????
void    DisplayOneChar(uchar X,uchar Y,uchar ASCII);//???X+1?е??Y+1λ???????????
void    LCMInit(void);//LCD???
void    DelayMs(uint Ms);//1MS??????????
void    baipingheng();//??????????
void    celiang();//??????????
uint    ryz,gyz,byz;//??????????? ??????? ???????
uint    rb,gb,bb;//RGB?
uchar   tab1[]={'0','1','2','3','4','5','6','7','8','9','A','B','C','D','E','F'};
main()
   TMOD=0x51;//?趨T0????????1???10????
   LCMInit();//LCD???
   baipingheng();//?????????????
       celiang();//???????
       DisplayOneChar(0, 0,'R');//??????????RGB?к??????
       DisplayOneChar(0, 1, rb/100+0x30); //?????λ????
       DisplayOneChar(0, 2, rb/10%10+0x30);//????λ????
       DisplayOneChar(0, 3, rb%10+0x30);//?????λ????
       DisplayOneChar(0, 5,'G');//??????????RGB?????????
       DisplayOneChar(0, 6, gb/100+0x30); //?????λ????
       DisplayOneChar(0, 7, gb/10%10+0x30);
       DisplayOneChar(0, 8, gb%10+0x30);
       DisplayOneChar(0, 10,'B');//??????????RGB?????????
       DisplayOneChar(0, 11, bb/100+0x30);
       DisplayOneChar(0, 12, bb/10%10+0x30);
       DisplayOneChar(0, 13, bb%10+0x30);
       //*****??LCD1602????????16???????RGB*******************
       DisplayOneChar(1, 1, tab1[rb/16]);
       DisplayOneChar(1, 2, tab1[rb%16]);
       DisplayOneChar(1, 3, 'H');
       DisplayOneChar(1, 6, tab1[gb/16]);
       DisplayOneChar(1, 7, tab1[rb%16]);
       DisplayOneChar(1, 8, 'H');
       DisplayOneChar(1, 11,tab1[bb/16]);
       DisplayOneChar(1, 12,tab1[bb%16]);
       DisplayOneChar(1, 13,'H');
       DelayMs(250);//???0.25???????????
void   celiang()
     //*********??R?************************************
     TH0=(65536-10000)/256;
    TL0=(65536-10000)%256;
     TH1=0;
     TL1=0;
     tcs230_s2=0;
     tcs230_s3=0;//??????????
     tcs230_en=0;
     TR0=1;//10????????
     TR1=1;//???????
     while(TF0==0);//???????????
     TF0=0;//????????0??????
     TR0=0;//?????0
     TR1=0;
     rb=(unsigned long)(TH1*256+TL1)*255/ryz;
     if(rb>255)rb=255;//?ж?RGB??????
     //***********??B?**************************************
     TH1=0;
     TL1=0;
     tcs230_s2=0;
     tcs230_s3=1;//???????????
     TR0=1;//10????????
     TR1=1;//???????
     TR0=0;//?????0
     TR1=0;
     bb=(unsigned long)(TH1*256+TL1)*255/byz;
     if(bb>255)bb=255;//?ж?RGB??????
     //***********??G?**************************************
     TH1=0;
     TL1=0;
     tcs230_s2=1;
     TR0=1;//10????????
     TR1=1;//???????
     TR0=0;//?????0
     TR1=0;
     tcs230_en=1;
     gb=(unsigned long)(TH1*256+TL1)*255/gyz;
     if(gb>255)gb=255;//?ж?RGB??????
void    baipingheng()
     TH1=0;
     TL1=0;
     tcs230_s2=0;
     tcs230_en=0;
     TR0=1;//10????????
     TR1=1;//???????
     TR0=0;//?????0
     TR1=0;
     ryz=TH1*256+TL1;//???????????????????255/(TH1*256+TL1)
     TH1=0;
     TL1=0;
     tcs230_s2=0;
     TR0=1;//10????????
     TR1=1;//???????
     TR0=0;//?????0
     TR1=0;
     byz=TH1*256+TL1;//???????????????????255/(TH1*256+TL1)
     TH1=0;
     TL1=0;
     tcs230_s2=1;
     TR0=1;//10????????
     TR1=1;//???????
     TR0=0;//?????0
     TR1=0;
     tcs230_en=1;
     gyz=TH1*256+TL1;//???????????????????255/(TH1*256+TL1)
LCM?????
void LCMInit(void)
LCM_Data = 0;
WriteCommandLCM(0x38,0); //???????????????????????
DelayMs(5);
DelayMs(5);
DelayMs(5);
WriteCommandLCM(0x38,1); //?????????,????????μ??????
WriteCommandLCM(0x08,1); //??????
WriteCommandLCM(0x01,1); //???????
WriteCommandLCM(0x06,1); // ?????????????
WriteCommandLCM(0x0C,1); // ??????????????
DelayMs(100);
//==============================LCD1602????????================================================
// д???????: E =?????? RS=1 RW=0
void WriteDataLCM(uchar WDLCM)
ReadStatusLCM(); //????
LCM_Data = WDLCM;
LCM_RS = 1;
LCM_RW = 0;
LCM_E = 0; //????????????????????С?????
LCM_E = 0; //???
LCM_E = 1;
  д?????: E=?????? RS=0 RW=0
void WriteCommandLCM(uchar WCLCM,BuysC) //BuysC?0?????????
if (BuysC) ReadStatusLCM(); //???????????
LCM_Data = WCLCM;
LCM_RS = 0;
LCM_RW = 0;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
  ??????д????????????LCD????????:E=1 RS=0 RW=1;
  DB7: 0 LCD?????????У?1 LCD?????????
LCM_Data = 0xFF;
LCM_RS = 0;
LCM_RW = 1;
LCM_E = 0;
LCM_E = 0;
LCM_E = 1;
while (LCM_Data & Busy); //???????
return(LCM_Data);
?? ??:     ??1602 ???λ???????????:?????λ??0~15,?????16~31
? ??:     ?? X ??,?? y ??  ???:????????????16?????
void DisplayOneChar( uchar X, uchar Y, uchar ASCII)
  X &= 0x1;
  Y &= 0xF; //????Y???????15??X???????1
  if (X) Y |= 0x40; //?????????????????+0x40;
  Y |= 0x80; // ????????
  WriteCommandLCM(Y, 0); //????????????????????
  WriteDataLCM(ASCII);
  ?趨??????:x*1ms
  uint i,TempCyc;
  for(i=0;i<Ms;i++)
    TempCyc = 250;
    while(TempCyc--);
ID:441878 發表于 2018-12-7 21:57 | 顯示全部樓層
復制黏貼時,格式不同出現問題啊
