查看: 1490|回復: 0
我的單片機24s計時器
ID:416198 發表于 2018-10-27 10:57 | 顯示全部樓層 |閱讀模式
#include <REGX51.H>
#include <intrins.h>
sbit    BEEP=P0^0;
sbit        LED=P1^1;
sbit        CLEAR=P1^2;
sbit        START=P1^3;
void    delay(unsigned int i )
    while(i--);
void   main()
   uint T_Count = 0;
   uchar count;
   LED=1;
   BEEP=1;
   CLEAR =1;
   START =1;
   TMOD=0X01;
   TH0=(65535-50000)/256;
   TL0=(65535-50000)/256;
   while(START);
   TR0=1;
   count=48;
         if(TF0==1)
         TF0=0;
         if(++T_Count==10)
          T_Count=0        ;
          LED=LED;
          count--;
          if(count=0)
           while(CLEAR)
            BEEP=1;
                delay(200);
                BEEP=0;
                delay(200);
                BEEP=1;
                while(START);
                count=48;
