查看: 1085|回復: 0
二分法查表
ID:415781 發表于 2018-10-26 14:03 | 顯示全部樓層 |閱讀模式
unsigned short Get_Temp(unsigned short vlotage)
   unsigned short First=0;
   unsigned short End=800;
   unsigned short Difference;
   for(unsigned char i=0;i<11;i++)
      Difference=End-First;
      if(Difference>1)  //
        Difference=Difference/2+First;
        if(vlotage>temp_AD[Difference])
          First=Difference;
        else if(vlotage<temp_AD[Difference])
          End=Difference;
          return Difference;
      else            //(Difference < 1)
         if((temp_AD[End]-vlotage)<(vlotage-temp_AD[First]))
           return End;
           return First;
   return 0;
