查看: 907|回復: 0
51單片機循環號碼,中斷程序
ID:415752 發表于 2018-10-26 12:44 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
char num [8] = {0x66,0x0fe,0x0fe,0x0da,0X0b6,0x0be,0x0fe,0x0fe};
int ii=0;
int count=0;
void int0() interrupt 0{
TMOD = 0x01;
TH0 = 0x3C;
TL0 = 0x0B0;
EA = 1;
ET0 = 1;
TR0 = 1;
EX0 = 1;
IT0 = 0;
while(1){
void Timer0Interrupt() interrupt 1
TH0 = 0x3C;
TL0 = 0x0B0;
count++;
if(count==10){
        count=0;
        P2=num[ii];
        ii++;
        if (ii==9){
                ii=0;
