基于MSP430單片機的四旋翼 僅供大家參考
PID Control種群遺傳算法:
- #include "io430x14x.h"
- #include "stdlib.h"
- #include "sys.h"
- #include "Control.h"
- #define col_MAX 50 //群體空間大小
- #define var_p 65 //變異概率:65 對應的變異概率約等于0.001,655 為0.01 rand():0-65535
- #define epoch_MAX 200 //進化代數(shù)
- void inherit(void) //遺傳進化PID
- unsigned int colony[col_MAX]={
- 62267,15148,39769,31849,58411,49944,29915,58375 ,53831
- ,29144,40332,51900,60411,48378,11552,26588,61306,60089
- ,26887,58565, 3794,23125,53291, 646, 9102,13288,13023
- ,39570,17838,13029, 1001,48941,29169,61066,30539,27436
- ,55457,34416,13280,44049,54926, 1287,44647,24869,54512
- ,32952,46495,28107,19963,12429
- unsigned int health[col_MAX]; //對應colony[] ,每個個體的適應值,
- unsigned int dad,mum,baby1,baby2;
- unsigned int mini_health,mini_id;
- unsigned int temp_health;
- unsigned char i,epoch; //epoch 遺傳代數(shù)
- mini_health = found(&colony[0],&health[0]); //評估初始個體,并作適應值縮放,找出最小適應值
- for(epoch=0; epoch < epoch_MAX; epoch++) //開始進化
- i = roulette(&health[0]);//輪盤賭轉,返回數(shù)組下標
- dad = colony[i];
- mum = colony[i];
- baby1 = dad&0xff;baby1 |= mum&0xff00;
- baby2 = mum&0xff;baby2 |= dad&0xff00;
- baby1 = variation(baby1); //變異?
- baby2 = variation(baby2);
- temp_health = evaluating_unit(baby1); //評估個體適應值
- if(temp_health > mini_health)
- mini_id = evaluating(&health[0]); //取得最差適應值的個體id(數(shù)組下標)
- colony[mini_id] = baby1;
- health[mini_id] = temp_health - mini_health;
- temp_health = evaluating_unit(baby2); //評估個體適應值
- mini_id = evaluating(&health[0]); //取得最差個體的適應值,及其id
- colony[mini_id] = baby2;
- while(1); //結束進化
- #define ev_N 25
- #define aim_value 300
- uint evaluating_unit(uint unit)//評估個體適應值 順便PWM輸出
- uint ret=0,temp=0,max=0;
- uchar i=0;
- int uk=0; //PID增量
- redressal(pid, unit); //根據(jù)個體,對基因進行解碼 修改PID三個參數(shù)
- while(i<ev_N) //PID調(diào)整 ev_N.PID調(diào)整次數(shù)
- if(measured > desired)
- temp = measured - desired;
- if(temp > max)
- max=temp; //最大超調(diào)量
- else
- temp = desired - measured;
- ret+=temp;
- uk = (int)(PID_Posi(pid, measured, desired)); //PWM輸出
- M1 = speed[0] - uk; //y軸
- M3 = speed[0] + uk; //y軸
- i++;
- ret=65535/(ret/ev_N+max);
- return ret; //返回適應值
- void redressal(float* pid,uint colon)
- pid[0]=(float)((colon&0xFC00)>>10)*5.0/63; //[0:0.079:5]
- pid[1]=(float)((colon&0x3E0)>>5)*0.1/31.0; //[0:0.0032:0.1]
- pid[2]=(float)(colon&0x1F)/31.0; //[0:0.032:1]
- uint found(uint colony,uint health) //計算初始群體適應值,并找出最小值
- uchar i;
- uint mini=0xff;
- for(i=0;i<col_MAX;i++)
- *(health+i) = evaluating_unit(*(colony+i)); //評估個體適應值
- if(*(health+i)<mini)
- mini=*(health+i);
- for(i=0;i<col_MAX;i++) //適應值縮放
- *(health+i)-=mini;
- return mini;
- uchar roulette(uint health)
- uchar i;
- uint temp=0;
- i=(uchar)(rand()%col_MAX); //0~(col_MAX-1) 隨機選擇起點
- while(1)
- if((col_MAX-1)==i) //實現(xiàn)首尾相接
- i=0;
- temp+=*(health+i); //累加適應值
- if (temp>1200)
- return i;
- i++;
- uchar evaluating(uint health) //取得最小適應值的個體id(數(shù)組下標)
- uchar i,id;
- uint mini=0xffff;
- mini=*(health+i);
- id=i;
- return id;
- uint variation(uint baby) //對基因進行變異
- uchar i;
- for(i=0;i<16;i++)
- if(rand()<var_p) //rand()0-65535,變異概率:65 對應的變異概率約等于0.001,655 為0.01
- if(0==(baby&(1<<i)))
- baby|=(1<<i);
- else
- baby &= ~(1<<i);
- return baby;
- #include "sys.h"
- #include "24L01.h"
- #include "MPU6050.h"
- #include "HMC5883L.h"
- #include "EEPROM.h"
- #include "math.h"
- uchar RxBuf[32]={0};
- uchar TxBuf[32]={0};
- uchar EEPROMBuffer[SIZE]={0};
- int speed[5] = {1300,0,0,0,0};//M0,M1-M4
- int desire[4]={0,0,0,0};//HMC_YAW,ROLL,PITCH,YAW
- float PID_Roll[6]={0}, PID_Pitch[6]={0}, PID_Yaw[6]={0};
- float roll = 0, pitch = 0, yaw = 0;
- int gyro[3]={0}, accel[3]={0}, magne[3]={0};
- uchar RX = 0, TX = 0, CALC = 0, Fly = 0, EEPROMWR = 0;
- uint ms2 = 0, ms10 = 0, ms500 = 0;
- /********************************Main*********************************/
- void main(void)
- uchar Flag_TX = 0;
- Init_Sys(); //系統(tǒng)功能初始化
- _EINT(); //開啟中斷功能
- HMC5883_Init();
- MPU6050_Init();
- NRF24L01_Init();
- while(AT24CXX_Check());//檢測不到24c16
- AT24CXX_Read(20,EEPROMBuffer,SIZE);
- Init_datas(PID_Roll, PID_Pitch, PID_Yaw, desire, speed, EEPROMBuffer);
- /********************************Start*********************************/
- while(1)
- if(RX)
- NRF24L01_RX_Mode();
- if(NRF24L01_RxPacket(RxBuf)==RX_OK) //判斷是否收到數(shù)據(jù)
- if(RxBuf[0]==0xAA)//有數(shù)據(jù)更新
- Data_Update(PID_Roll, PID_Pitch, PID_Yaw, desire, speed, RxBuf);
- Fly = RxBuf[START_STOP];//Stop?
- if(TX)
- TX = 0;
- if(Flag_TX == 0)
- Flag_TX = 1;
- Data_Send_Status(roll, pitch, yaw, desire, speed, TxBuf);
- else if(Flag_TX == 1)
- Flag_TX = 0;
- // Data_Send_Senser(accel, gyro, magne, TxBuf);
- Data_Send_PID(PID_Roll, PID_Pitch, PID_Yaw, TxBuf);
- NRF24L01_TxPacket(TxBuf);
- if(CALC)
- CALC = 0;
- MPU6050_Read(accel, gyro);
- AHRSupdate(accel, gyro, magne);
- yaw = get_angle(magne, roll, pitch);
- if(Fly)
- EEPROMWR = 1;
- MotoCtrl(PID_Roll, PID_Pitch, PID_Yaw, desire, speed, roll, pitch, yaw, gyro, 1);
- else
- M1=900;M2=900;M3=900;M4=900;
- if(EEPROMWR)
- EEPROMWR = 0;
- AT24CXX_BufferWrite(PID_Roll, PID_Pitch, PID_Yaw, desire, speed, EEPROMBuffer);
- //TIMERA中斷服務程序
- //定時時間:1ms
- #pragma vector = TIMERA1_VECTOR
- __interrupt void Timer_A1(void)
- if(TAIV==2)//定時溢出標志位
- ms2++;
- ms10++;
- // ms500++;
- if(ms2 == 2) {CALC = 1; ms2 = 0;}
- if(ms10 == 4) {TX = 1; }
- if(ms10 == 8) {TX = 1; }
- if(ms10 == 12) {TX = 1; }
- if(ms10 == 16) {TX = 1; }
- if(ms10 == 20) {RX = 1; ms10 = 0;}
- // if(ms500 == 5000)
- // ms500 = 0;
四旋翼飛行器,采用MSP430F149,通過卡爾曼濾波實現(xiàn)自穩(wěn)。其中包括陀螺儀MPU6505、地.rar
(180.89 KB, 下載次數(shù): 77)
2018-10-25 13:22 上傳
