查看: 2338|回復: 5
有沒有大神知道為什么這個單片機籃球計分板的電路是亂碼 并且按鈕無效
  1. #include<reg51.h>
  2. unsigned char codeseg[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x00,0x90 };
  3. inti=11,j=59,a=0,b=0,m=0,n=0,temp,s=0,r=24,k;
  4. sbit aa=P0^0;
  5. sbit bb=P0^1;
  6. sbit one=P0^2;
  7. sbit two=P0^3;
  8. sbit three=P0^4;
  9. sbit exchange=P0^5;
  10. sbit stop=P0^6;
  11. sbit led=P3^6;
  12. sbit tt=P3^7;
  13. void delay(int x)
  14. {
  15.        intw,q;
  16.        for(w=0;w<x;w++)
  17.               for(q=0;q<120;q++);
  18. }
  19. void display(int i,int j,int a,int b)
  20. {
  21.        P2= 0x01;
  22.        P1= seg[i/10];
  23.        delay(1);
  24.        P2= 0x00;
  25.        P2= 0x02;
  26.        P1= seg[i%10];
  27.        delay(1);
  28.        P2= 0x00;
  29.
  30.        P2= 0x04;
  31.        P1= seg[j/10];
  32.        delay(1);
  33.        P2= 0x00;
  34.
  35.        P2= 0x08;
  36.        P1= seg[j%10];
  37.        delay(1);
  38.    P2 = 0x00;
  39.
  40.        P2=0x10;
  41.        P1= seg[a/10];
  42.        delay(1);
  43.        P2=0x00;
  44.
  45.        P2=0x20;
  46.      P1 = seg[a%10];
  47.        delay(1);
  48.        P2= 0x00;
  49.
  50.      P2 = 0x40;
  51.        P1= seg[b/10];
  52.        delay(1);
  53.        P2= 0x00;
  54.
  55.        P2=0x80;
  56.      P1 = seg[b%10];
  57.        delay(1);
  58.        P2= 0x00;
  59.
  60. }
  61. void time0() interrupt 1
  62. {
  63.    TH0 = 0xb1;
  64.        TL0= 0xe0;
  65.        m++;
  66.        if(m==50)
  67.        {
  68.      m=0;
  69.               j--;
  70.               if(j==-1)
  71.                      j= 59;
  72.               n++;
  73.               if(n==60)
  74.               {
  75.                      n=0;
  76.                      i--;
  77.                      if(i==0&&j==0){
  78.                             ET0=1;
  79.                             TR0= 1;
  80.                      }
  81.               }
  82.        }
  83.        display(i,j,a,b);
  84. }
  85. void main()
  86. {
  87.        P0= 0x00;
  88.        display(12,0,0,0);
  89.        TMOD= 0x01;
  90.        TH0= 0xb1;
  91.        TL0= 0xe0;
  92.        IE= 0x82;
  93.        TR0= 1;
  94.        while(1)
  95.        {
  96.               if(aa==1&&one==1)
  97.                      {a++;display(i, j, a, b);while(one==1);}
  98.                      elseif(aa==1&&two==1)
  99.                             {a=a+2;display( i, j, a, b);while(two==1);}
  100.                             elseif(aa==1&&three==1)
  101.                                    {a=a+3;display(i, j, a, b);while(three==1);}
  102.                                    elseif(bb==1&&one==1)
  103.                                           {b++;display(i, j, a, b);while(one==1);}
  104.                                           elseif(bb==1&&two==1)
  105.                                                  {b=b+2;display( i, j, a, b);while(two==1);}
  106.                                                  elseif(bb==1&&three==1)
  107.                                                         {b=b+3;display( i, j, a, b);while(three==1);}
  108.                                                     else if(exchange==1)
  109.                                                         {temp= a;a = b;b = temp;delay(500);}
  110.        elseif(stop==1)                                         {ET0=0;TR0=0;while(stop==1);while(stop==0);while(stop==1){ET0=1;TR0=1;}}
  111.        }
  112. }
ID:295874 發表于 2018-10-24 09:37 | 只看該作者
整體有點小問題,需要修改一下。顯示與按鍵處理電路及邏輯需要修改。
ID:413820 發表于 2018-10-24 11:16 | 只看該作者
liyongan_1985 發表于 2018-10-24 09:37
能具體說一下計分板顯示如何修改嗎
ID:414543 發表于 2018-10-24 11:49 | 只看該作者
led亂碼檢查一下數碼管對應的值,還有建議寫代碼要注釋,不然別人看的很累
ID:94031 發表于 2018-10-24 15:30 | 只看該作者
1 P0口要上拉
2 初始化時應該P0= 0xff;
ID:413820 發表于 2018-11-6 11:12 | 只看該作者
xuyaqi 發表于 2018-10-24 15:30
1 P0口要上拉
2 初始化時應該P0= 0xff;
厲害
