STM32+RC632(SPI)源代碼,這個是在CSDN論壇下載的程序,但是不知道怎樣才能尋卡ID,讀寫(已燒寫進硬件平臺中),例如:輸入不同的串口命令,可以串口助手中顯示卡號。
尋求搞過的人給出意見,謝謝!
IRQ => PA2
NSS => PA4
CE => PA0
SPI1_SCK => PA5
SPI1_MISO => PA6
SPI1_MOSI => PA7
- #include "includes.h"
- #include "rc632.h"
- #include "iso14443a.h"
- #include "iso15693.h"
- #define PDA_HEAD 0xA5
- #define PDA_COMT_SET 0x57
- #define PDA_COMT_REQ 0x52
- #define PDA_COMT_AUTO 0x41
- #define PACK_HEAD 0
- #define PACK_LENG 1
- #define PACK_NUMB 2
- #define PACK_COMT 3
- #define PACK_COMM 4
- #define PACK_ACKN 5
- #define PACK_DALE 6
- #define PACK_DATA 7
- unsigned char iso14443a_cardtype[2];
- unsigned char iso14443a_cardsnr[4];
- unsigned char iso15693_cardsnr[8];
- unsigned char iso14443a_buffer[6];
- unsigned char iso14443a_Zhe[30];
- unsigned char uart_indx, recv_flag;
- unsigned char uart_sbuf[50];
- unsigned char uart_rbuf[50];
- unsigned char PDA_product_ver[] = "EmbedSky PDA MCU-RFID ver0.1";
- void PDA_package(unsigned char num, unsigned char com_type,
- unsigned char com, unsigned char ack,
- unsigned char len, unsigned char *dat, unsigned char *buf);
- unsigned short crc16_table(unsigned char *pcrc, unsigned short cnt);
- void uart_putd(unsigned char *d);
- void uart_clr(void);
- void uart_puts(unsigned char *s);
- typedef enum{
- Card_Null,
- Card_AutoType,
- Card_ScanTag,
- Card_ScanCard,
- Card_InitOver,
- Card_ReadOver,
- Card_Recharge,
- Card_Buckle,
- Card_ReadData,
- Card_WriteData,
- }Card_Oper;
- Card_Oper CARD_OPER = Card_Null,CARD_FLAG = Card_Null;
- /* Private defines -----------------------------------------------------------*/
- /* Private function prototypes -----------------------------------------------*/
- /* Private functions ---------------------------------------------------------*/
- uint16_t led_count = 0;
- int main(void)
- unsigned char size, len, sta;
- unsigned char coded[12];
- unsigned char dat_buf[16], buf[70];
- unsigned int crc;
- unsigned char par, rst_dat[18];
- unsigned char cos_fwi, cos_cidnad, cos_len;
- unsigned char cos_dat[40];
- unsigned char Key_New[6] = {0x11,0x88,0x12,0x16,0x6D,0x89};
- int i;
- unsigned char iso14443a_cardsnr2[20]={0};
- uint8_t count = 0;
- SystemInit();
- delay_init(72);
- //延時函數(shù)初始化
- // bsp_InitUart(COM1,115200);
- //調(diào)試用的串口1
- HardWare_Init();
- // Checki_Sys();
- //檢查系統(tǒng)頻率
- bsp_NVIC_Configuration();
- rc_init();
- sta = PCD_reset();
- delay_ms(200);
- // PCD_AntennaOFF();
- PCD_AntennaON();
- // delay_ms(5);
- PCD_cfg_iso_type('A');
- delay_ms(5);
- while(1)
- // 尋卡
- // 0x52:ALL 尋找感應(yīng)區(qū)內(nèi)所有符合14443A標準的卡
- // 0x26:IDLE 尋找感應(yīng)區(qū)內(nèi)未進入休眠狀態(tài)的卡
- // 0x4400 mifare_ultralight
- // 0x0400 mifare_one s50
- // 0x0200 mifare_one s70
- // 0x0800 mifare_pro
- // 0x0403 mifare_proX
- // 0x4403 mifare_desfire
- //PCD_request(0x26, unsigned char *p_tagtype)
- delay_ms(5);
- // memcpy(iso14443a_cardsnr2,0,8);
- for(i=0;i<8;i++)
- iso14443a_cardsnr2[i]=0;
- //sta = PDA_15693_snr(iso14443a_cardsnr2);
- sta = PCD_request(0x52, iso14443a_cardtype);
- sta = PCD_anticoll(iso14443a_cardsnr2);
- // sta = PDA_15693_snr(iso15693_cardsnr);
- //CARD_OPER = Card_Null;
- //PDA_package(uart_rbuf[PACK_NUMB], uart_rbuf[PACK_COMT],
- //uart_rbuf[PACK_COMM], 0x00,
- // 4, iso14443a_cardsnr, uart_sbuf);
- for(count = 0; count<10; count++)
- // BUZZER_ONCE();
- delay_ms(10);
- sta = PCD_request(0x26, iso14443a_cardtype);
- sta = PCD_anticoll(iso14443a_cardsnr);
- // BUZZER_ONCE();
- delay_ms(20);
- while(1)
- // 自動尋卡,有新命令則停止尋卡操作
- // 協(xié)議為ISO14443A,執(zhí)行一次讀卡類型和讀卡號操作
- if(CARD_OPER != Card_Null && recv_flag == 0)
- CARD_FLAG = CARD_OPER;
- sta = MI_OK;
- PCD_AntennaOFF();
- delay_ms(3);
- delay_ms(3);
- if (MI_OK == sta)
- if(sta == MI_OK)
- //uart_puts(" 1.CardType ");
- if(CARD_OPER == Card_AutoType) //協(xié)議為ISO14443A
- CARD_OPER = Card_Null;
- memcpy(&buf[0], iso14443a_cardtype, 2);
- memcpy(&buf[2], iso14443a_cardsnr, 4);
- PDA_package(0x00, PDA_COMT_AUTO, 'a', 0x00, 6, buf, uart_sbuf);
- PCD_AntennaOFF();
- uart_putd(uart_sbuf);
- delay_ms(2);
- else if(CARD_OPER == Card_ScanCard)//MF卡
- PDA_package(uart_rbuf[PACK_NUMB], uart_rbuf[PACK_COMT],
- uart_rbuf[PACK_COMM], 0x00,
- 4, iso14443a_cardsnr, uart_sbuf);
- PCD_AntennaOFF();
- delay_ms(2);
- else
- sta = PCD_select(iso14443a_cardsnr, &size);
- if(MI_OK == sta)
- //uart_puts(" 2.CardSelect ");
- getCardKey(iso14443a_cardsnr,&uart_rbuf[PACK_DATA+2],Key_New);
- change_code_key(Key_New, coded);
- sta = PCD_auth_key(coded);
- if(MI_OK == sta)
- //uart_puts(" 3.CardFillKey ");
- sta = PCD_auth_state(uart_rbuf[PACK_DATA], uart_rbuf[PACK_DATA+1],
- iso14443a_cardsnr);
- if(MI_OK == sta)
- //uart_puts(" 4.CardAuthKey ");
- if(CARD_OPER == Card_WriteData)
- if(MI_OK == PCD_write(uart_rbuf[PACK_DATA+1], &uart_rbuf[PACK_DATA+8]))
- //uart_puts(" 5.WriteData ");
- memcpy(dat_buf,&uart_rbuf[PACK_DATA+8],16);
- 16, dat_buf, uart_sbuf);
- else if(CARD_OPER == Card_ReadData)
- if(MI_OK == PCD_read(uart_rbuf[PACK_DATA+1], dat_buf))
- //uart_puts(" 5.ReadData ");
- uart_rbuf[PACK_COMM], sta,
- else if(CARD_OPER == Card_InitOver)
- if(MI_OK == PCD_val_init(uart_rbuf[PACK_DATA+1], &uart_rbuf[PACK_DATA+8]))
- //uart_puts(" 5.InitOver ");
- uart_rbuf[PACK_COMM], sta, 4, &uart_rbuf[PACK_DATA+8], uart_sbuf);
- else if(CARD_OPER == Card_Recharge)
- if(MI_OK == PCD_value(PICC_INCREMENT, uart_rbuf[PACK_DATA+1], &uart_rbuf[PACK_DATA+8]))
- //uart_puts(" 5.Recharge ");
- sta = PCD_read(uart_rbuf[PACK_DATA+1], dat_buf);
- if(MI_OK == sta)
- uart_rbuf[PACK_COMM], sta,4, dat_buf, uart_sbuf);
- else if(CARD_OPER == Card_Buckle)//??
- if(MI_OK == PCD_value(PICC_DECREMENT, uart_rbuf[PACK_DATA+1], &uart_rbuf[PACK_DATA+8]))
- //uart_puts(" 5.Buckle ");
- if(MI_OK == sta)
- else if(CARD_OPER == Card_ReadOver)//????
- if(MI_OK == sta)
- //uart_puts(" 5.ReadOver ");
- }//驗證密鑰 if_end
- }//填充密鑰if_end
- }//選擇卡片if_end
- }//else end
- if(CARD_OPER == Card_Null)
- PCD_AntennaOFF();
- BUZZER_ON();
- delay_ms(100);
- BUZZER_OFF();
- CARD_OPER = CARD_FLAG;
- if (recv_flag)
- crc = uart_rbuf[uart_rbuf[PACK_LENG]]<<8 | uart_rbuf[uart_rbuf[PACK_LENG]+1];
- if (crc == crc16_table(uart_rbuf, uart_rbuf[PACK_LENG]))
- recv_flag = 0;
- else
- uart_rbuf[PACK_COMM], 0xFF,
- 2, (unsigned char*)&crc, uart_sbuf);
- uart_clr();
- recv_flag = 0;
- uart_indx = 0;
- continue;
- if (uart_rbuf[PACK_COMT] == PDA_COMT_SET)
- sta = 0;
- if(uart_rbuf[PACK_COMM] >= 'A' && uart_rbuf[PACK_COMM] <= 'Z')
- if(uart_rbuf[PACK_COMM] == 'O')
- CARD_OPER = Card_InitOver;
- else if(uart_rbuf[PACK_COMM] == 'C')
- CARD_OPER = Card_Recharge;
- else if(uart_rbuf[PACK_COMM] == 'B')
- CARD_OPER = Card_Buckle;
- else if(uart_rbuf[PACK_COMM] == 'W')
- CARD_OPER = Card_WriteData;
- else
- uart_rbuf[PACK_COMM], 0x11, 0, 0, uart_sbuf);
- else
- switch (uart_rbuf[PACK_COMM])
- case 'd':
- CARD_OPER = Card_AutoType;
- break;
- case 'l':
- //PDA_LED_switch(uart_rbuf[PACK_DATA]);
- break;
- case 'b':
- //PDA_BEEP_soud(uart_rbuf[PACK_DATA], uart_rbuf[PACK_DATA+1]);
- break;
- case 'u':
- //PDA_UART_baud(uart_rbuf[PACK_DATA]);
- break;
- case 'a':
- //PDA_ANT_switch(uart_rbuf[PACK_DATA]);
- break;
- case 'i':
- PCD_AntennaOFF();
- delay_ms(10);
- sta = PCD_cfg_iso_type(uart_rbuf[PACK_DATA]);
- break;
- case 'h':
- sta = PCD_halt();
- break;
- case 'w':
- sta = PCD_write(uart_rbuf[PACK_DATA], &uart_rbuf[PACK_DATA+1]);
- break;
- case 'f':
- change_code_key(&uart_rbuf[PACK_DATA], coded);
- break;
- case 'k':
- &uart_rbuf[PACK_DATA+2]);
- break;
- case 's':
- sta = PCD_select(&uart_rbuf[PACK_DATA], &size);
- break;
- case 'v':
- sta = PCD_val_init(uart_rbuf[PACK_DATA], &uart_rbuf[PACK_DATA+1]);
- break;
- case '+':
- sta = PCD_value(PICC_INCREMENT, uart_rbuf[PACK_DATA], &uart_rbuf[PACK_DATA+1]);
- break;
- case '-':
- sta = PCD_value(PICC_DECREMENT, uart_rbuf[PACK_DATA], &uart_rbuf[PACK_DATA+1]);
- break;
- default:
- sta = 0x11;
- break;
- uart_rbuf[PACK_COMM], sta, 0, 0, uart_sbuf);
- else if (uart_rbuf[PACK_COMT] == PDA_COMT_REQ)
- if(uart_rbuf[PACK_COMM] == 'S')
- CARD_OPER = Card_ScanCard;
- else if(uart_rbuf[PACK_COMM] == 'T') //返回卡號
- CARD_OPER = Card_ScanTag;
- else if(uart_rbuf[PACK_COMM] == 'G' || uart_rbuf[PACK_COMM] == 'R')
- if(uart_rbuf[PACK_COMM] == 'G') //讀余額
- CARD_OPER = Card_ReadOver;
- else if(uart_rbuf[PACK_COMM] == 'R') //讀塊數(shù)據(jù)
- CARD_OPER = Card_ReadData;
- else if (uart_rbuf[PACK_COMM] == 'p')
- len = sizeof(PDA_product_ver);
- uart_rbuf[PACK_COMM], 0x00,len, PDA_product_ver, uart_sbuf);
- else if (uart_rbuf[PACK_COMM] == 'c')
- uart_rbuf[PACK_COMM], sta,2, iso14443a_cardtype, uart_sbuf);
- else if (uart_rbuf[PACK_COMM] == 'n')
- uart_rbuf[PACK_COMM], sta,4, iso14443a_cardsnr, uart_sbuf);
- else if (uart_rbuf[PACK_COMM] == 'r')
- sta = PCD_read(uart_rbuf[PACK_DATA], dat_buf);
- else if (uart_rbuf[PACK_COMM] == 't')
- { // 15693??
- sta = PDA_15693_snr(iso15693_cardsnr);
- 8, iso15693_cardsnr, uart_sbuf);
- for (i=0; i<8; i++)
- iso15693_cardsnr[i] = 0x00;
- else if (uart_rbuf[PACK_COMM] == '=')
- uart_rbuf[PACK_COMM], sta, 4, dat_buf, uart_sbuf);
- else if (uart_rbuf[PACK_COMM] == 'o')
- { // COS??
- par = (4<<4) & 0xF0;
- sta = PCD_mfpro_rst(par, &len, &rst_dat[2]);
- rst_dat[0] = par;
- rst_dat[1] = len;
- uart_rbuf[PACK_COMM], sta, 0x12, rst_dat, uart_sbuf);
- cos_fwi = rst_dat[3];
- cos_cidnad = 0;
- for (i=0; i<18; i++)
- rst_dat[i] = 0x00;
- else if (uart_rbuf[PACK_COMM] == 'm')
- { // ??COS??
- cos_len = uart_rbuf[PACK_DALE];
- memcpy(cos_dat, &uart_rbuf[PACK_DATA], cos_len);
- sta = PCD_mfpro_comm(cos_cidnad, cos_fwi, &cos_len, cos_dat);
- uart_rbuf[PACK_COMM], sta, cos_len, cos_dat, uart_sbuf);
- else
- else
- uart_rbuf[PACK_COMM], 0x10, 0, 0, uart_sbuf);
- if(CARD_OPER == Card_Null) //???????,????
- for (i=0; i<16; i++)
- dat_buf[i] = 0x00;
- uart_clr();
- recv_flag = 0;
- uart_indx = 0;
- unsigned short crc16_tab[256] = {
- 0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50A5, 0x60C6, 0x70E7,
- 0x8108, 0x9129, 0xA14A, 0xB16B, 0xC18C, 0xD1AD, 0xE1CE, 0xF1EF,
- 0x1231, 0x0210, 0x3273, 0x2252, 0x52B5, 0x4294, 0x72F7, 0x62D6,
- 0x9339, 0x8318, 0xB37B, 0xA35A, 0xD3BD, 0xC39C, 0xF3FF, 0xE3DE,
- 0x2462, 0x3443, 0x0420, 0x1401, 0x64E6, 0x74C7, 0x44A4, 0x5485,
- 0xA56A, 0xB54B, 0x8528, 0x9509, 0xE5EE, 0xF5CF, 0xC5AC, 0xD58D,
- 0x3653, 0x2672, 0x1611, 0x0630, 0x76D7, 0x66F6, 0x5695, 0x46B4,
- 0xB75B, 0xA77A, 0x9719, 0x8738, 0xF7DF, 0xE7FE, 0xD79D, 0xC7BC,
- 0x48C4, 0x58E5, 0x6886, 0x78A7, 0x0840, 0x1861, 0x2802, 0x3823,
- 0xC9CC, 0xD9ED, 0xE98E, 0xF9AF, 0x8948, 0x9969, 0xA90A, 0xB92B,
- 0x5AF5, 0x4AD4, 0x7AB7, 0x6A96, 0x1A71, 0x0A50, 0x3A33, 0x2A12,
- 0xDBFD, 0xCBDC, 0xFBBF, 0xEB9E, 0x9B79, 0x8B58, 0xBB3B, 0xAB1A,
- 0x6CA6, 0x7C87, 0x4CE4, 0x5CC5, 0x2C22, 0x3C03, 0x0C60, 0x1C41,
- 0xEDAE, 0xFD8F, 0xCDEC, 0xDDCD, 0xAD2A, 0xBD0B, 0x8D68, 0x9D49,
- 0x7E97, 0x6EB6, 0x5ED5, 0x4EF4, 0x3E13, 0x2E32, 0x1E51, 0x0E70,
- 0xFF9F, 0xEFBE, 0xDFDD, 0xCFFC, 0xBF1B, 0xAF3A, 0x9F59, 0x8F78,
- 0x9188, 0x81A9, 0xB1CA, 0xA1EB, 0xD10C, 0xC12D, 0xF14E, 0xE16F,
- 0x1080, 0x00A1, 0x30C2, 0x20E3, 0x5004, 0x4025, 0x7046, 0x6067,
- 0x83B9, 0x9398, 0xA3FB, 0xB3DA, 0xC33D, 0xD31C, 0xE37F, 0xF35E,
- 0x02B1, 0x1290, 0x22F3, 0x32D2, 0x4235, 0x5214, 0x6277, 0x7256,
- 0xB5EA, 0xA5CB, 0x95A8, 0x8589, 0xF56E, 0xE54F, 0xD52C, 0xC50D,
- 0x34E2, 0x24C3, 0x14A0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
- 0xA7DB, 0xB7FA, 0x8799, 0x97B8, 0xE75F, 0xF77E, 0xC71D, 0xD73C,
- 0x26D3, 0x36F2, 0x0691, 0x16B0, 0x6657, 0x7676, 0x4615, 0x5634,
- 0xD94C, 0xC96D, 0xF90E, 0xE92F, 0x99C8, 0x89E9, 0xB98A, 0xA9AB,
- 0x5844, 0x4865, 0x7806, 0x6827, 0x18C0, 0x08E1, 0x3882, 0x28A3,
- 0xCB7D, 0xDB5C, 0xEB3F, 0xFB1E, 0x8BF9, 0x9BD8, 0xABBB, 0xBB9A,
- 0x4A75, 0x5A54, 0x6A37, 0x7A16, 0x0AF1, 0x1AD0, 0x2AB3, 0x3A92,
- 0xFD2E, 0xED0F, 0xDD6C, 0xCD4D, 0xBDAA, 0xAD8B, 0x9DE8, 0x8DC9,
- 0x7C26, 0x6C07, 0x5C64, 0x4C45, 0x3CA2, 0x2C83, 0x1CE0, 0x0CC1,
- 0xEF1F, 0xFF3E, 0xCF5D, 0xDF7C, 0xAF9B, 0xBFBA, 0x8FD9, 0x9FF8,
- 0x6E17, 0x7E36, 0x4E55, 0x5E74, 0x2E93, 0x3EB2, 0x0ED1, 0x1EF0
- unsigned short crc16 = 0;
- unsigned char crc_reg;
- for ( ; cnt>0; cnt--)
- crc_reg = (unsigned char) (crc16>>8);
- crc16 <<= 8;
STM32+RC632(SPI)源代碼.rar
(1.14 MB, 下載次數(shù): 104)
2018-10-23 04:42 上傳
STM32+RC632(SPI)源代碼
