查看: 2588|回復: 0
STM32F103C8 PWM源碼
ID:403544 發表于 2018-10-20 17:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
void RCC1_HSE_Configuration(void) //HSE作為PLL時鐘,PLL作為SYSCLK
   RCC_DeInit(); /*將外設RCC寄存器重設為缺省值 */
   RCC_HSEConfig(RCC_HSE_ON);          /*設置外部高速晶振(HSE) HSE晶振打開(ON)*/
   if(RCC_WaitForHSEStartUp() == SUCCESS) {  /*等待HSE起振,  SUCCESS:HSE晶振穩定且就緒*/
   RCC_HCLKConfig(RCC_SYSCLK_Div1);/*設置AHB時鐘(HCLK)RCC_SYSCLK_Div1——AHB時鐘 = 系統時*/
   RCC_PCLK2Config(RCC_HCLK_Div1); /*設置高速AHB時鐘(PCLK2)RCC_HCLK_Div1——APB2時鐘 = HCLK*/
   RCC_PCLK1Config(RCC_HCLK_Div2); /*設置低速AHB時鐘(PCLK1)RCC_HCLK_Div2——APB1時鐘 = HCLK / 2*/
   RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);/*設置PLL時鐘源及倍頻系數*/
   RCC_PLLCmd(ENABLE);          /*使能PLL */
   while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET) ; /*檢查指定的RCC標志位(PLL準備好標志)設置與否*/
   RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);  /*設置系統時鐘(SYSCLK) */
   while(RCC_GetSYSCLKSource() != 0x08);     /*0x08:PLL作為系統時鐘 */
void TurnLeft1()
         IN1_H IN2_L
         IN3_H IN4_L
         XX=500;
         YY=800;
         TimCounterInit1(XX,YY);
void TurnRight1(void)
         IN1_H IN2_L
         IN3_H IN4_L
         XX=800;
         YY=500;
void straight1(void)
         IN1_H IN2_L
         IN3_H IN4_L
         XX=600;
         YY=600;
void sternway1(void)
        IN1_L        IN2_H
        IN3_L IN4_H
        XX=700;
        YY=700;
void Gpio_PWM_Init1(void)
  //以下設定是將TIM1的通道1(PA0)的復用功能打開,這很重要很容易被忘掉
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
        GPIO_InitStructure.GPIO_Pin        = GPIO_PWM_8;              //選擇PA0 PA8|GPIO_PWM_B
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;          //管腳頻率為50MHZ
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;         //模式為復用推挽輸出
  GPIO_Init(GPIO_A, &GPIO_InitStructure);           //初始化寄存器
void Gpio_M_Init1(void)
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
        GPIO_InitStructure.GPIO_Pin        = GPIO_Pin_IN1|GPIO_Pin_IN2|GPIO_Pin_IN3|GPIO_Pin_IN4;              //選擇1256
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIO_IN, &GPIO_InitStructure);           //初始化寄存器GPIOB  1 2 5 6
*函數名稱:void TimCounterInit(void)
*功能說明:TIM計數初始化配置
*               TIMCLK = 72 MHz, Prescaler = TIM_PSC, TIM counter clock = TIMCLK/TIM_COUNTER MHz
void TimCounterInit1(int rate_1,int rate_2)        //rate可以改變占空比
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        /* TIM時鐘使能 */
        RCC_APB1PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        /* 基定時器初始化 */
        TIM_TimeBaseStructure.TIM_Period = 1000000*0.001;        //計數值 1000;須介于0~65535
        TIM_TimeBaseStructure.TIM_Prescaler = 72;          //分頻系數,為了設定值數值較大,這里選得較小
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;                //時鐘分割:計數模式中無作用
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;        //計數模式,向上計數
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;        //重復計數值
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);                //初始化TIM
        /* PWM1 Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;//輸出模式設定
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//輸出模式使能
  TIM_OCInitStructure.TIM_Pulse = rate_1; //設置占空比,0時全低電平,1001時全高電平.須介于0~65535
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;//輸出比較極性;最終輸出值是高/低電平
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);//輸出通道x,參數寫入
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);//使能通道x預裝載寄存器
        TIM_OCInitStructure.TIM_Pulse = rate_2; //設置占空比,0時全低電平,1001時全高電平.須介于0~65535
        TIM_OC2Init(TIM1, &TIM_OCInitStructure);//輸出通道x,參數寫入
        TIM_OC2PreloadConfig(TIM1, TIM_OCPreload_Enable);//使能通道x預裝載寄存器
        TIM_Cmd(TIM1, ENABLE);                                                //使能TIM
