此文件適合于STM32上移植UCOSII系統(tǒng),通過信號量的方法創(chuàng)建程序,完成3個LED燈的閃爍。
- * 本例程在 奮斗版STM32開發(fā)板V2,2.1,V3,MINI上調試通過
- * 文件名: app.c
- * 內容簡述:
- * 本例程操作系統(tǒng)采用ucos2.86a版本, 建立了4個任務
- 任務名 優(yōu)先級
- APP_TASK_START_PRIO 2 主任務
- Task_Led1_PRIO 7 LED1 閃爍任務
- Task_Led2_PRIO 8 LED2 閃爍任務
- Task_Led3_PRIO 9 LED3 閃爍任務
- 當然還包含了系統(tǒng)任務:
- OS_TaskIdle 空閑任務-----------------優(yōu)先級最低
- OS_TaskStat 統(tǒng)計運行時間的任務-------優(yōu)先級次低
- 通過建立3個信號量,通過主任務的延時發(fā)送,控制3個led閃爍任務的響應
- * 文件歷史:
- * 版本號 日期 作者 說明
- * v0.1 2012-11-08 sun68 創(chuàng)建該文件
- * INCLUDE FILES
- #define GLOBALS
- #include "stdarg.h"
- #include "includes.h"
- #include "globals.h"
- OS_EVENT* Led1_SEM;
- OS_EVENT* Led2_SEM;
- OS_EVENT* Led3_SEM;
- * LOCAL DEFINES
- * LOCAL GLOBAL VARIABLES
- static OS_STK App_TaskStartStk[APP_TASK_START_STK_SIZE];
- static OS_STK Task_Led1Stk[Task_Led1_STK_SIZE];
- static OS_STK Task_Led2Stk[Task_Led2_STK_SIZE];
- static OS_STK Task_Led3Stk[Task_Led3_STK_SIZE];
- * LOCAL FUNCTION PROTOTYPES
- static void App_TaskCreate(void);
- static void App_TaskStart(void* p_arg);
- static void Task_Led1(void* p_arg);
- static void Task_Led2(void* p_arg);
- static void Task_Led3(void* p_arg);
- #define LED_LED1_ON() GPIO_SetBits(GPIOB, GPIO_Pin_5 ); //LED1 亮
- #define LED_LED1_OFF() GPIO_ResetBits(GPIOB, GPIO_Pin_5 ); //LED1 滅
- #define LED_LED2_ON() GPIO_SetBits(GPIOD, GPIO_Pin_6 ); //LED2 亮
- #define LED_LED2_OFF() GPIO_ResetBits(GPIOD, GPIO_Pin_6 ); //LED2 滅
- #define LED_LED3_ON() GPIO_SetBits(GPIOD, GPIO_Pin_3 ); //LED3 亮
- #define LED_LED3_OFF() GPIO_ResetBits(GPIOD, GPIO_Pin_3 ); //LED3 滅
- * main()
- * Description : This is the standard entry point for C code. It is assumed that your code will call
- * main() once you have performed all necessary initialization.
- * Argument : none.
- * Return : none.
- int main(void)
- CPU_INT08U os_err;
- //禁止CPU中斷
- CPU_IntDis();
- //UCOS 初始化
- OSInit(); /* Initialize "uC/OS-II, The Real-Time Kernel". */
- //硬件平臺初始化
- BSP_Init(); /* Initialize BSP functions. */
- //建立主任務, 優(yōu)先級最高 建立這個任務另外一個用途是為了以后使用統(tǒng)計任務
- os_err = OSTaskCreate((void (*) (void *)) App_TaskStart, //指向任務代碼的指針
- (void *) 0, //任務開始執(zhí)行時,傳遞給任務的參數(shù)的指針
- (OS_STK *) &App_TaskStartStk[APP_TASK_START_STK_SIZE - 1], //分配給任務的堆棧的棧頂指針 從頂向下遞減
- (INT8U) APP_TASK_START_PRIO); //分配給任務的優(yōu)先級
- //ucos的節(jié)拍計數(shù)器清0 節(jié)拍計數(shù)器是0-4294967295 對于節(jié)拍頻率100hz時, 每隔497天就重新計數(shù)
- OSTimeSet(0);
- OSStart(); /* Start multitasking (i.e. give control to uC/OS-II). */
- /* Start multitasking (i.e. give control to uC/OS-II). */
- return (0);
- * App_TaskStart()
- * Description : The startup task. The uC/OS-II ticker should only be initialize once multitasking starts.
- * Argument : p_arg Argument passed to 'App_TaskStart()' by 'OSTaskCreate()'.
- * Return : none.
- * Caller : This is a task.
- * Note : none.
- (void) p_arg;
- //初始化ucos時鐘節(jié)拍
- OS_CPU_SysTickInit(); /* Initialize the SysTick. */
- //使能ucos 的統(tǒng)計任務
- #if (OS_TASK_STAT_EN > 0)
- //----統(tǒng)計任務初始化函數(shù)
- OSStatInit(); /* Determine CPU capacity. */
- #endif
- //建立其他的任務
- App_TaskCreate();
- while (1)
- //1秒一次循環(huán)
- OSSemPost(Led1_SEM);
- OSTimeDlyHMSM(0, 0,0, 300);
- OSSemPost(Led2_SEM);
- OSTimeDlyHMSM(0, 0,0, 500);
- OSSemPost(Led3_SEM);
- OSTimeDlyHMSM(0, 0,0,350);
- //LED1閃爍任務----------------------------------------
- INT8U err;
- (void) p_arg;
- while (1)
- OSSemPend(Led1_SEM,0,&err); //等待Led1信號量
- LED_LED1_ON();
- LED_LED2_OFF();
- LED_LED3_OFF();
- OSTimeDlyHMSM(0, 0,0, 200);
- //LED2閃爍任務----------------------------------------
- INT8U err;
- (void) p_arg;
- while (1)
- OSSemPend(Led2_SEM,0,&err); //等待Led2信號量
- LED_LED2_ON();
- LED_LED1_OFF();
- LED_LED3_OFF();
- //LED3閃爍任務----------------------------------------
- { INT8U err;
- (void) p_arg;
- while (1)
- OSSemPend(Led3_SEM,0,&err); //等待Led3信號量
- LED_LED3_ON();
- LED_LED1_OFF();
- LED_LED2_OFF();
- OSTimeDlyHMSM(0, 0,0,200);
- * App_TaskCreate()
- * Description : Create the application tasks.
- * Return : none.
- * Caller : App_TaskStart().
- * Note : none.
- //CPU_INT08U os_err;
- Led1_SEM=OSSemCreate(1); //建立Led1的信號量
- Led2_SEM=OSSemCreate(1); //建立Led2的信號量
- Led3_SEM=OSSemCreate(1); //建立Led3的信號量
- //LED1 閃爍任務------------------------------------------------------
- OSTaskCreateExt(Task_Led1,(void *)0,(OS_STK *)&Task_Led1Stk[Task_Led1_STK_SIZE-1],Task_Led1_PRIO,Task_Led1_PRIO,(OS_STK *)&Task_Led1Stk[0],
- Task_Led1_STK_SIZE,
- (void *)0,
- OS_TASK_OPT_STK_CHK|OS_TASK_OPT_STK_CLR);
- //LED2 閃爍任務------------------------------------------------------
- OSTaskCreateExt(Task_Led2,(void *)0,(OS_STK *)&Task_Led2Stk[Task_Led2_STK_SIZE-1],Task_Led2_PRIO,Task_Led2_PRIO,(OS_STK *)&Task_Led2Stk[0],
- Task_Led2_STK_SIZE,
- (void *)0,
- //LED3 閃爍任務------------------------------------------------------
- OSTaskCreateExt(Task_Led3,(void *)0,(OS_STK *)&Task_Led3Stk[Task_Led3_STK_SIZE-1],Task_Led3_PRIO,Task_Led3_PRIO,(OS_STK *)&Task_Led3Stk[0],
- Task_Led3_STK_SIZE,
- (void *)0,
- * uC/OS-II APP HOOKS
- #if (OS_APP_HOOKS_EN > 0)
- * TASK CREATION HOOK (APPLICATION)
- * Description : This function is called when a task is created.
- * Argument : ptcb is a pointer to the task control block of the task being created.
- * Note : (1) Interrupts are disabled during this call.
- void App_TaskCreateHook(OS_TCB* ptcb)
- * TASK DELETION HOOK (APPLICATION)
- * Description : This function is called when a task is deleted.
- * Argument : ptcb is a pointer to the task control block of the task being deleted.
- void App_TaskDelHook(OS_TCB* ptcb)
- (void) ptcb;
- * IDLE TASK HOOK (APPLICATION)
- * Description : This function is called by OSTaskIdleHook(), which is called by the idle task. This hook
- * has been added to allow you to do such things as STOP the CPU to conserve power.
- * Note : (1) Interrupts are enabled during this call.
- #if OS_VERSION >= 251
- void App_TaskIdleHook(void)
- #endif
- * STATISTIC TASK HOOK (APPLICATION)
- * Description : This function is called by OSTaskStatHook(), which is called every second by uC/OS-II's
- * statistics task. This allows your application to add functionality to the statistics task.
- void App_TaskStatHook(void)
- * TASK SWITCH HOOK (APPLICATION)
- * Description : This function is called when a task switch is performed. This allows you to perform other
- * operations during a context switch.
- * Note : 1 Interrupts are disabled during this call.
- * 2 It is assumed that the global pointer 'OSTCBHighRdy' points to the TCB of the task that
- * will be 'switched in' (i.e. the highest priority task) and, 'OSTCBCur' points to the
- * task being switched out (i.e. the preempted task).
- #if OS_TASK_SW_HOOK_EN > 0
- void App_TaskSwHook(void)
- #endif
- * OS_TCBInit() HOOK (APPLICATION)
- * Description : This function is called by OSTCBInitHook(), which is called by OS_TCBInit() after setting
- * up most of the TCB.
- * Argument : ptcb is a pointer to the TCB of the task being created.
- * Note : (1) Interrupts may or may not be ENABLED during this call.
- #if OS_VERSION >= 204
- void App_TCBInitHook(OS_TCB* ptcb)
- (void) ptcb;
- #endif
- #endif
STM32-LED閃爍-信號量.rar
(382.15 KB, 下載次數(shù): 21)
2018-10-19 10:40 上傳
