查看: 3743|回復: 0
opencv 實現兩幅圖片特征匹配
ID:401842 發表于 2018-10-19 09:28 | 顯示全部樓層 |閱讀模式
#include <iostream>
#include <opencv2/core/core.hpp>
#include <opencv2/features2d/features2d.hpp>
#include <opencv2/highgui/highgui.hpp>
using namespace std;
using namespace cv;
int main ( int argc, char** argv )
    if ( argc != 3 )
        cout<<"usage: feature_extraction img1 img2"<<endl;
        return 1;
    //-- 讀取圖像
    Mat img_1 = imread ( argv[1], CV_LOAD_IMAGE_COLOR );
    Mat img_2 = imread ( argv[2], CV_LOAD_IMAGE_COLOR );
    //-- 初始化
    std::vector<KeyPoint> keypoints_1, keypoints_2;
    Mat descriptors_1, descriptors_2;
    Ptr<FeatureDetector> detector = ORB::create();
    Ptr<DescriptorExtractor> descriptor = ORB::create();
    // Ptr<FeatureDetector> detector = FeatureDetector::create(detector_name);
    // Ptr<DescriptorExtractor> descriptor = DescriptorExtractor::create(descriptor_name);
    Ptr<DescriptorMatcher> matcher  = DescriptorMatcher::create ( "BruteForce-Hamming" );
    //-- 第一步:檢測 Oriented FAST 角點位置
    detector->detect ( img_1,keypoints_1 );
    detector->detect ( img_2,keypoints_2 );
    //-- 第二步:根據角點位置計算 BRIEF 描述子
    descriptor->compute ( img_1, keypoints_1, descriptors_1 );
    descriptor->compute ( img_2, keypoints_2, descriptors_2 );
    Mat outimg1;
    drawKeypoints( img_1, keypoints_1, outimg1, Scalar::all(-1), DrawMatchesFlags::DEFAULT );
    imshow("ORB特征點",outimg1);
    //-- 第三步:對兩幅圖像中的BRIEF描述子進行匹配,使用 Hamming 距離
    vector<DMatch> matches;
    //BFMatcher matcher ( NORM_HAMMING );
    matcher->match ( descriptors_1, descriptors_2, matches );
    //-- 第四步:匹配點對篩選
    double min_dist=10000, max_dist=0;
    //找出所有匹配之間的最小距離和最大距離, 即是最相似的和最不相似的兩組點之間的距離
    for ( int i = 0; i < descriptors_1.rows; i++ )
        double dist = matches.distance;
        if ( dist < min_dist ) min_dist = dist;
        if ( dist > max_dist ) max_dist = dist;
    // 僅供娛樂的寫法
    min_dist = min_element( matches.begin(), matches.end(), [](const DMatch& m1, const DMatch& m2) {return m1.distance<m2.distance;} )->distance;
    max_dist = max_element( matches.begin(), matches.end(), [](const DMatch& m1, const DMatch& m2) {return m1.distance<m2.distance;} )->distance;
    printf ( "-- Max dist : %f \n", max_dist );
    printf ( "-- Min dist : %f \n", min_dist );
    //當描述子之間的距離大于兩倍的最小距離時,即認為匹配有誤.但有時候最小距離會非常小,設置一個經驗值30作為下限.
    std::vector< DMatch > good_matches;
        if ( matches.distance <= max ( 2*min_dist, 30.0 ) )
            good_matches.push_back ( matches );
    //-- 第五步:繪制匹配結果
    Mat img_match;
    Mat img_goodmatch;
    drawMatches ( img_1, keypoints_1, img_2, keypoints_2, matches, img_match );
    drawMatches ( img_1, keypoints_1, img_2, keypoints_2, good_matches, img_goodmatch );
    imshow ( "所有匹配點對", img_match );
    imshow ( "優化后匹配點對", img_goodmatch );
    waitKey(0);
    return 0;
