2018-10-19 13:37 上傳
TM1637數(shù)碼管顯示模塊原理圖如下:
2018-10-19 13:38 上傳
現(xiàn)象:顯示4444
要求:計算1-9的段碼,用16進(jìn)制數(shù);
顯示學(xué)號后四位
動態(tài)顯示全部學(xué)號
計數(shù):從0-9999
stm32單片機源程序如下:
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32f1xx_hal.h"
- /* USER CODE BEGIN Includes */
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- static uint8_t fac_us=0;
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- void Error_Handler(void);
- static void MX_GPIO_Init(void);
- /* USER CODE BEGIN PFP */
- void ALIX_Delay_init(void);
- void ALIX_Delay_us(uint32_t nus);
- void TMserialstart(void);
- void TMserialstop(void);
- void TMserialask(void);
- void TMserialWrByte(uint8_t oneByte);
- void TMSegDisplay(uint8_t *DISCODE);
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- int main(void)
- /* USER CODE BEGIN 1 */
- uint8_t NUM[]={0X3F,0X06,0X5B,0X4F,0X66,0X6D,0X7D,0X07,0X7F,0X6F};
- uint8_t abc[]={0x00,0x00,0x00,0x00};
- // 0 1 2 3 4 5 6 7 8 9
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* Configure the system clock */
- SystemClock_Config();
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- /* USER CODE BEGIN 2 */
- ALIX_Delay_init();
- int b=0;
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- int c,d,e,f;
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- if(HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_5)==0)
- if(HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_5)==1)
- b++;
- c=b%10;
- d=b/10%10;
- e=b/100%10;
- f=b/1000%10;
- abc[0]=NUM[f];
- abc[1]=NUM[e];
- abc[2]=NUM[d];
- abc[3]=NUM[c];
- TMSegDisplay(abc);
- HAL_GPIO_TogglePin(led_GPIO_Port,led_Pin);
- ALIX_Delay_us(90000);
- if(b==9999)
- b=0;
- /* USER CODE END 3 */
- /** System Clock Configuration
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- Error_Handler();
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- Error_Handler();
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /** Configure pins as
- * Analog
- * Input
- * Output
- * EVENT_OUT
- * EXTI
- GPIO_InitTypeDef GPIO_InitStruct;
- /* GPIO Ports Clock Enable */
- __HAL_RCC_GPIOC_CLK_ENABLE();
- __HAL_RCC_GPIOD_CLK_ENABLE();
- __HAL_RCC_GPIOA_CLK_ENABLE();
- /*Configure GPIO pin Output Level */
- HAL_GPIO_WritePin(led_GPIO_Port, led_Pin, GPIO_PIN_SET);
- HAL_GPIO_WritePin(GPIOA, TM_DIO_Pin|TM_CLK_Pin, GPIO_PIN_SET);
- /*Configure GPIO pin : led_Pin */
- GPIO_InitStruct.Pin = led_Pin;
- GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
- GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH;
- HAL_GPIO_Init(led_GPIO_Port, &GPIO_InitStruct);
- /*Configure GPIO pins : TM_DIO_Pin TM_CLK_Pin */
- GPIO_InitStruct.Pin = TM_DIO_Pin|TM_CLK_Pin;
- HAL_GPIO_Init(GPIOA, &GPIO_InitStruct);
- /*Configure GPIO pin : PA2 */
- GPIO_InitStruct.Pin = GPIO_PIN_2;
- GPIO_InitStruct.Mode = GPIO_MODE_IT_RISING;
- GPIO_InitStruct.Pull = GPIO_NOPULL;
- /*Configure GPIO pin : PA5 */
- GPIO_InitStruct.Pin = GPIO_PIN_5;
- GPIO_InitStruct.Mode = GPIO_MODE_INPUT;
- /* USER CODE BEGIN 4 */
- void ALIX_Delay_init()
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK_DIV8);
- fac_us=SystemCoreClock/8000000;
- uint32_t temp;
- SysTick->LOAD=nus*fac_us;
- SysTick->VAL=0x00;
- SysTick->CTRL|=SysTick_CTRL_ENABLE_Msk ;
- do
- temp=SysTick->CTRL;
- }while((temp&0x01)&&!(temp&(1<<16)));
- SysTick->CTRL&=~SysTick_CTRL_ENABLE_Msk;
- SysTick->VAL =0X00;
- HAL_GPIO_WritePin(TM_CLK_GPIO_Port,TM_CLK_Pin,GPIO_PIN_SET); // CLK = 1
- HAL_GPIO_WritePin(TM_DIO_GPIO_Port,TM_DIO_Pin,GPIO_PIN_SET); // DIO = 1
- ALIX_Delay_us(2);
- HAL_GPIO_WritePin(TM_DIO_GPIO_Port,TM_DIO_Pin,GPIO_PIN_RESET); // DIO = 0
- HAL_GPIO_WritePin(TM_CLK_GPIO_Port,TM_CLK_Pin,GPIO_PIN_RESET); // CLK = 0
- ALIX_Delay_us(2);
- ALIX_Delay_us(2);
- ALIX_Delay_us(2);
- TM1637_DIO_IN();
- ALIX_Delay_us(5);
- while(HAL_GPIO_ReadPin(TM_DIO_GPIO_Port,TM_DIO_Pin));
- ALIX_Delay_us(2);
- TM1637_DIO_OUT();
- uint8_t i;
- for(i=0;i<8;i++)
- if(oneByte&0x01)
- else
- ALIX_Delay_us(3);
- oneByte=oneByte>>1;
- ALIX_Delay_us(3);
- uint8_t i;
- TMserialstart();
- TMserialWrByte(0x40);
- TMserialask();
- TMserialstop();
- TMserialstart();
- TMserialWrByte(0xc0);
- TMserialask();
- for(i=0;i<4;i++)
- TMserialWrByte(*(DISCODE+i));
- TMserialask();
- TMserialstop();
- TMserialstart();
- TMserialWrByte(0x8f);
- TMserialask();
- TMserialstop();
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param None
- * @retval None
- /* USER CODE BEGIN Error_Handler */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
TM1637數(shù)碼管顯示模塊資料包.7z
(1.66 MB, 下載次數(shù): 327)
2019-6-14 02:25 上傳
666 下載積分: 黑幣 -5
