查看: 2972|回復: 1
STC51單片機OLED 屏幕8八針源碼程序
ID:411564 發表于 2018-10-18 10:36 | 顯示全部樓層 |閱讀模式
OLED 屏幕.c文件
ulong  fontaddr = 0;
void Write_Command_OLED(int data1)
    char i;
    OLED_DC = 0;
    OLED_CLK = 0;
    for(i = 0; i < 8; i++)
        if(data1 & 0x80)
            OLED_MOS = 1;
            OLED_MOS = 0;
        OLED_CLK = 1;
        _nop_();
        OLED_CLK = 0;
        data1 <<= 1;
void Write_Data_OLED(int data1)
    char i;
    OLED_DC = 1;
    OLED_CLK = 0;
        if(data1 & 0x80)
            OLED_MOS = 1;
            OLED_MOS = 0;
        OLED_CLK = 1;
        _nop_();
        OLED_CLK = 0;
        data1 <<= 1;
void Delay_Nms(int n_ms)
    int j, k;
    for(j = 0; j < n_ms; j++)
        for(k = 0; k < 110; k++);
void Write_Address_OLED(uchar page, uchar column)
    Write_Command_OLED(0xb0 + column);
    Write_Command_OLED((((page + 2) & 0xf0) >> 4) | 0x10);
    Write_Command_OLED(((page + 2) & 0x0f) | 0x00);
void Initial_OLED(void)
    OLED_CS1 = 0;
    Rom_CS = 1;
    //        OLED_reset=0;
    Delay_Nms(20);
    //OLED_reset=1;
    Delay_Nms(20);
    Write_Command_OLED(0xAE);  //display off
    Write_Command_OLED(0x20);        //Set Memory Addressing Mode
    Write_Command_OLED(0x10);        //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
    Write_Command_OLED(0xb0);        //Set Page Start Address for Page Addressing Mode,0-7
    Write_Command_OLED(0xc8);        //Set COM Output Scan Direction
    Write_Command_OLED(0x02);        //---set low column address
    Write_Command_OLED(0x10);        //---set high column address
    Write_Command_OLED(0x40);        //--set start line address
    Write_Command_OLED(0x81);        //--set contrast control register
    Write_Command_OLED(0x7f);
    Write_Command_OLED(0xa1);        //--set segment re-map 0 to 127
    Write_Command_OLED(0xa6);        //--set normal display
    Write_Command_OLED(0xa8);        //--set multiplex ratio(1 to 64)
    Write_Command_OLED(0x3F);        //
    Write_Command_OLED(0xa4);        //0xa4,Output follows RAM content;0xa5,Output ignores RAM content
    Write_Command_OLED(0xd3);        //-set display offset
    Write_Command_OLED(0x00);        //-not offset
    Write_Command_OLED(0xd5);        //--set display clock divide ratio/oscillator frequency
    Write_Command_OLED(0xf0);        //--set divide ratio
    Write_Command_OLED(0xd9);        //--set pre-charge period
    Write_Command_OLED(0x22);         //
    Write_Command_OLED(0xda);        //--set com pins hardware configuration
    Write_Command_OLED(0x12);
    Write_Command_OLED(0xdb);        //--set vcomh
    Write_Command_OLED(0x20);        //0x20,0.77xVcc
    Write_Command_OLED(0x8d);        //--set DC-DC enable
    Write_Command_OLED(0x14);        //
    Write_Command_OLED(0xaf);        //--turn on OLED panel
    OLED_CS1 = 1;
void OLED_CLEAR(void)
    unsigned char i, j;
    OLED_CS1 = 0;
    Rom_CS = 1;
        Write_Command_OLED(0xb0 + i);
        for(j = 0; j < 132; j++)
            Write_Data_OLED(0x00);
    OLED_CS1 = 1;
void OLED_Display_Graphic_16x16(uint page, uint column, uchar *dp)
    uint i, j;
    OLED_CS1 = 0;
    Rom_CS = 1;
    for(j = 2; j > 0; j--)
        Write_Address_OLED(column, page);
        for (i = 0; i < 16; i++)
            Write_Data_OLED(*dp);
            dp++;
        page++;
    OLED_CS1 = 1;
void OLED_Display_Graphic_8x16(uint page, uchar column, uchar *dp)
    uint i, j;
    OLED_CS1 = 0;
        for (i = 0; i < 8; i++)
        page++;
    OLED_CS1 = 1;
void Write_Command_ROM( uchar datu )
    uchar i;
    for(i = 0; i < 8; i++ )
        if(datu & 0x80)
            OLED_MOS = 1;
            OLED_MOS = 0;
        datu = datu << 1;
        OLED_CLK = 0;
        OLED_CLK = 1;
uchar Read_Data_From_ROM(void)
    uchar i;
    uchar ret_data = 0;
    OLED_CLK = 1;
        Rom_OUT = 1;
        OLED_CLK = 0;
        ret_data = ret_data << 1;
        if( Rom_OUT )
            ret_data = ret_data + 1;
            ret_data = ret_data + 0;
        OLED_CLK = 1;
    return(ret_data);
void Read_N_Bytes_Data_From_ROM(uchar addrHigh, uchar addrMid, uchar addrLow, uchar *pBuff, uchar DataLen )
    uchar i;
    Rom_CS = 0;
    OLED_CS1 = 1;
    OLED_CLK = 0;
    Write_Command_ROM(0x03);
    Write_Command_ROM(addrHigh);
    Write_Command_ROM(addrMid);
    Write_Command_ROM(addrLow);
    for(i = 0; i < DataLen; i++ )
        *(pBuff + i) = Read_Data_From_ROM();
    Rom_CS = 1;
void OLED_Display_String(uchar y, uchar x, uchar *text)
    uchar i = 0;
    uchar addrHigh, addrMid, addrLow ;
    uchar fontbuf[32];
    while((text[i] > 0x00))
        if(((text[i] >= 0xb0) && (text[i] <= 0xf7)) && (text[i + 1] >= 0xa1))
                       fontaddr = (text[i] - 0xb0) * 94;
            fontaddr += (text[i + 1] - 0xa1) + 846;
            fontaddr = (ulong)(fontaddr * 32);
            addrHigh = (fontaddr & 0xff0000) >> 16;
            addrMid = (fontaddr & 0xff00) >> 8;
            addrLow = fontaddr & 0xff;
            Read_N_Bytes_Data_From_ROM(addrHigh, addrMid, addrLow, fontbuf, 32 );
            OLED_Display_Graphic_16x16(y, x, fontbuf);
            i += 2;
            x += 16;
        else if(((text[i] >= 0xa1) && (text[i] <= 0xa3)) && (text[i + 1] >= 0xa1))
                     fontaddr = (text[i] - 0xa1) * 94;
            fontaddr += (text[i + 1] - 0xa1);
            i += 2;
            x += 16;
        else if((text[i] >= 0x20) && (text[i] <= 0x7e))
            unsigned char fontbuf[16];
            fontaddr = (text[i] - 0x20);
            fontaddr = (unsigned long)(fontaddr * 16);
            fontaddr = (unsigned long)(fontaddr + 0x3cf80);
            Read_N_Bytes_Data_From_ROM(addrHigh, addrMid, addrLow, fontbuf, 16 );
            OLED_Display_Graphic_8x16(y, x, fontbuf);
            i += 1;
            x += 8;
            i++;
void OLED_Display_Number(uchar y, uchar x, ulong Number)
    uchar Number_String[10][2] = {"0", "1", "2", "3", "4", "5", "6", "7", "8", "9"};
    if(Number < 10)
        OLED_Display_String(y, x, Number_String [Number]);
    else if(Number < 100)
        OLED_Display_String(y, x, Number_String[ Number / 10 % 10]);
        OLED_Display_String(y, x + 8, Number_String[Number % 10]);
    else if(Number < 1000)
        OLED_Display_String(y, x, Number_String[Number / 100 % 10]);
        OLED_Display_String(y, x + 1 * 8, Number_String [Number / 10 % 10]);
        OLED_Display_String(y, x + 2 * 8, Number_String [Number % 10]);
    else if(Number < 10000)
        OLED_Display_String(y, x, Number_String [Number / 1000 % 10]);
        OLED_Display_String(y, x + 1 * 8, Number_String [Number / 100 % 10]);
        OLED_Display_String(y, x + 2 * 8, Number_String [Number / 10 % 10]);
        OLED_Display_String(y, x + 3 * 8, Number_String [Number % 10]);
    else if(Number < 100000)
        OLED_Display_String(y, x, Number_String [Number / 10000 % 10]);
        OLED_Display_String(y, x + 1 * 8, Number_String [Number / 1000 % 10]);
        OLED_Display_String(y, x + 2 * 8, Number_String [Number / 100 % 10]);
        OLED_Display_String(y, x + 3 * 8, Number_String [Number / 10 % 10]);
        OLED_Display_String(y, x + 4 * 8, Number_String [Number % 10]);
    else if(Number < 1000000)
        OLED_Display_String(y, x, Number_String [Number / 100000 % 10]);
        OLED_Display_String(y, x + 1 * 8, Number_String [Number / 10000 % 10]);
        OLED_Display_String(y, x + 2 * 8, Number_String [Number / 1000 % 10]);
        OLED_Display_String(y, x + 3 * 8, Number_String [Number / 100 % 10]);
        OLED_Display_String(y, x + 4 * 8, Number_String [Number / 10 % 10]);
        OLED_Display_String(y, x + 5 * 8, Number_String [Number % 10]);
void OLED_Display_Timer_Data(uchar y, uchar x, ulong Number)
OLED 屏幕.h文件
#include<STC89C5xRC.H>
#include<intrins.h>
#ifndef __OLED_H__
#define __OLED_H__
#define uint         unsigned int
#define ulong unsigned long
#define OLED_CLK  P20
#define        OLED_MOS         P21
#define        OLED_DC                P22
#define        OLED_CS1        P23
#define        Rom_OUT         P24
#define        Rom_CS                P25
void Send_Command_To_OLED(int data1);
void Send_Data_To_OLED(int data1);
void Delay_Nms(int n_ms);
void Initial_OLED();
void Send_Address_To_OLED(uchar page, uchar column);
void OLED_Clear();
void OLED_OLED_Display_Graphic_16x16(uint page, uint column, uchar *dp);
void OLED_OLED_Display_Graphic_8x16(uint page, uchar column, uchar *dp);
void Send_Command_To_ROM( uchar datu );
uchar Get_data_From_ROM( );
void Get_N_Bytes_Data_From_ROM(uchar addrHigh, uchar addrMid, uchar addrLow, uchar *pBuff, uchar DataLen );
void OLED_Display_String(uchar y, uchar x, uchar *text);
void Display_GB2312_One_String(uchar y, uchar x, uchar *text);
void OLED_Display_Timer_Data(uchar y, uchar x, ulong Number);
void OLED_Display_Number(uchar y, uchar x, ulong Number);
#endif
ID:1 發表于 2018-10-18 14:42 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
