查看: 1873|回復: 1
51單片機按鍵控制舵機程序
ID:405273 發表于 2018-10-17 10:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "reg52.h"
unsigned char count;      //0.5ms次數標識
sbit pwm =P1^0;          //PWM信號輸入
sbit jia =P3^3;           //??????角度增加?IO??
sbit jan =P3^2;           //???????角度減少?IO??
unsigned char jd;         //?????
void delay(unsigned char i)//???
  unsigned char j,k;
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void Time0_Init()          //??????????
TMOD = 0x01;           //?????0????????1
IE   = 0x82;
TH0  = 0xfe;
TL0  = 0x33;     //11.0592MZ????0.5ms
    TR0=1;                 //????????
void Time0_Int() interrupt 1 //?ж????
TH0  = 0xfe;             //??????
TL0  = 0x33;
    if(count< jd)              //?ж?0.5ms???????С??????
      pwm=1;                  //??С???PWM???????
      pwm=0;                  //?????????????
    count=(count+1);          //0.5ms??????1
    count=count%40;     //???????????40 ???????????20ms
void keyscan()              //按鍵掃描
   if(jia==0)               //???????????????
    delay(10);              //?????????????
    if(jia==0)              //??????
      jd++;                 //???????1
      count=0;              //???????? ??20ms?????????
      if(jd==6)
        jd=5;               //?????180???????
      while(jia==0);        //??????????
  if(jan==0)                //????С?????????
    delay(10);
    if(jan==0)
      jd--;                 //???????1
      count=0;
      if(jd==0)
        jd=1;               //?????0???????
      while(jan==0);
jd=1;
count=0;
Time0_Init();
  keyscan();               //???????
收藏收藏2 分享淘帖 頂 踩
ID:405273 發表于 2018-10-19 09:21 | 只看該作者
我想問一下 要是高精度控制舵機轉角怎么調?比如說 按一下轉5度
