查看: 1410|回復: 0
按鍵小燈左右移的單片機程序
ID:410287 發表于 2018-10-15 23:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit key1=P3^5;
sbit key2=P3^4;
void delay(uchar k)
     uchar i,j;
     for(i=k;i>0;i--)
         for(j=110;j>0;j--);
void moveleft()
    if(P1 == 0x7f)    //0111 1111
         P1 = 0xfe;    //1111 1110
         P1 = (P1 << 1) + 1 ; // 1111 1100 ->  1111 1101
void moveright()
    if(P1 == 0xfe)
         P1 = 0x7f;
         P1 = (P1 >> 1) + (1 << 7);
    P3 = 0xff;    //1111 1111
          if(key1 == 0)
                delay(20);
                if(key1 == 0)
                      while(!key1); //等待按鍵抬起
                      moveleft();
           if(key2 == 0)
                delay(20);
                if(key2 == 0)
                     while(!key2);
                     moveright();
