利用ADC的第14通道對開發(fā)板上單圈電位器的電壓值作AD轉(zhuǎn)換,采用連續(xù)轉(zhuǎn)換模式,轉(zhuǎn)換結(jié)果通過DMA通道1讀取。ADC轉(zhuǎn)換的結(jié)果,每間隔1秒鐘向串口發(fā)送一次。
- * File Name : main.c
- * Author : Wuhan R&D Center, Embest
- * Description : Main program body
- /* Includes ------------------------------------------------------------------*/
- #include "stm32f10x_lib.h"
- #include"stdio.h"
- /************ 用于定義ITM Viewer相關(guān)的ITM激勵寄存器端口 ************************/
- #define ITM_Port8(n) (*((volatile unsigned char *)(0xE0000000+4*n)))
- #define ITM_Port16(n) (*((volatile unsigned short*)(0xE0000000+4*n)))
- #define ITM_Port32(n) (*((volatile unsigned long *)(0xE0000000+4*n)))
- #define DEMCR (*((volatile unsigned long *)(0xE000EDFC)))
- #define TRCENA 0x01000000
- /*用于定義是否使用ITM Viewer*/
- //#define DBG_ITM
- /* Private typedef -----------------------------------------------------------*/
- /* Private define ------------------------------------------------------------*/
- #define ADC1_DR_Address ((u32)0x4001244C)
- int AD_value;
- static unsigned long ticks;
- unsigned char Clock1s;
- /* Private macro -------------------------------------------------------------*/
- /* Private variables ---------------------------------------------------------*/
- ADC_InitTypeDef ADC_InitStructure;
- DMA_InitTypeDef DMA_InitStructure;
- vu16 ADC_ConvertedValue;
- ErrorStatus HSEStartUpStatus;
- /* Private function prototypes -----------------------------------------------*/
- void RCC_Configuration(void);
- void GPIO_Configuration(void);
- void NVIC_Configuration(void);
- void USART_Configuration1(void);
- void SetupClock (void);
- int fputc(int ch, FILE *f);
- /* Private functions ---------------------------------------------------------*/
- * Function Name : main
- * Input : None
- * Output : None
- * Return : None
- int main(void)
- #ifdef DEBUG
- debug();
- #endif
- /* System clocks configuration ---------------------------------------------*/
- RCC_Configuration();
- /* NVIC configuration ------------------------------------------------------*/
- NVIC_Configuration();
- /* GPIO configuration ------------------------------------------------------*/
- GPIO_Configuration();
- /* Configure the USART1 */
- USART_Configuration1();
- printf("\r\n USART1 print AD_value -------------------------- \r\n");
- /* DMA channel1 configuration ----------------------------------------------*/
- DMA_DeInit(DMA1_Channel1);
- DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
- DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;
- DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
- DMA_InitStructure.DMA_BufferSize = 1;
- DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
- DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
- DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
- DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
- DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
- DMA_InitStructure.DMA_Priority = DMA_Priority_High;
- DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
- DMA_Init(DMA1_Channel1, &DMA_InitStructure);
- /* Enable DMA channel1 */
- DMA_Cmd(DMA1_Channel1, ENABLE);
- /* ADC1 configuration ------------------------------------------------------*/
- ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
- ADC_InitStructure.ADC_ScanConvMode = ENABLE;
- ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
- ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
- ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
- ADC_InitStructure.ADC_NbrOfChannel = 1;
- ADC_Init(ADC1, &ADC_InitStructure);
- /* ADC1 regular channel14 configuration */
- ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_55Cycles5);
- /* Enable ADC1 DMA */
- ADC_DMACmd(ADC1, ENABLE);
- /* Enable ADC1 */
- ADC_Cmd(ADC1, ENABLE);
- /* Enable ADC1 reset calibaration register */
- ADC_ResetCalibration(ADC1);
- /* Check the end of ADC1 reset calibration register */
- while(ADC_GetResetCalibrationStatus(ADC1));
- /* Start ADC1 calibaration */
- ADC_StartCalibration(ADC1);
- /* Check the end of ADC1 calibration */
- while(ADC_GetCalibrationStatus(ADC1));
- /* Start ADC1 Software Conversion */
- ADC_SoftwareStartConvCmd(ADC1, ENABLE); /*使能ADC1軟件開始轉(zhuǎn)換*/
- while(1)
- AD_value=ADC_GetConversionValue(ADC1);
- if (ticks++ >= 900000) { /* Set Clock1s to 1 every 1 second */
- ticks = 0;
- Clock1s = 1;
- /* Printf message with AD value to serial port every 1 second */
- if (Clock1s) {
- Clock1s = 0;
- printf("The current AD value = 0x%04X \r\n", AD_value);
- * Function Name : RCC_Configuration
- * Description : Configures the different system clocks.
- * Input : None
- * Output : None
- * Return : None
- /* RCC system reset(for debug purpose) */
- RCC_DeInit();
- /* Enable HSE */
- RCC_HSEConfig(RCC_HSE_ON);
- /* Wait till HSE is ready */
- HSEStartUpStatus = RCC_WaitForHSEStartUp();
- if(HSEStartUpStatus == SUCCESS)
- /* HCLK = SYSCLK */
- RCC_HCLKConfig(RCC_SYSCLK_Div1);
- /* PCLK2 = HCLK */
- RCC_PCLK2Config(RCC_HCLK_Div1);
- /* PCLK1 = HCLK/2 */
- RCC_PCLK1Config(RCC_HCLK_Div2);
- /* ADCCLK = PCLK2/4 */
- RCC_ADCCLKConfig(RCC_PCLK2_Div4);
- /* Flash 2 wait state */
- FLASH_SetLatency(FLASH_Latency_2); /*設(shè)置代碼延時值(參數(shù)里的是指2延時周期)*/
- /* Enable Prefetch Buffer */
- FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); /*使能或者失能預(yù)取指緩存*/
- /* PLLCLK = 8MHz * 9 = 56 MHz */
- RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
- /* Enable PLL */
- RCC_PLLCmd(ENABLE);
- /* Wait till PLL is ready */
- while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
- /* Select PLL as system clock source */
- RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
- /* Wait till PLL is used as system clock source */
- while(RCC_GetSYSCLKSource() != 0x08)
- /* Enable peripheral clocks --------------------------------------------------*/
- /* Enable DMA clock */
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
- /* Enable ADC1 and GPIOC clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOC, ENABLE);
- /* Enable USART1 and GPIOA clock */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
- * Function Name : GPIO_Configuration
- * Description : Configures the different GPIO ports.
- * Input : None
- * Output : None
- * Return : None
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Configure PC.04 (ADC Channel14) as analog input -------------------------*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
- GPIO_Init(GPIOA, &GPIO_InitStructure);
- /* Configure USART1 Tx (PA.09) as alternate function push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- /* Configure USART1 Rx (PA.10) as input floating */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- * Function Name : NVIC_Configuration
- * Description : Configures Vector Table base location.
- * Input : None
- * Output : None
- * Return : None
- #ifdef VECT_TAB_RAM
- /* Set the Vector Table base location at 0x20000000 */
- NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
- #else /* VECT_TAB_FLASH */
- /* Set the Vector Table base location at 0x08000000 */
- NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
- #endif
- #ifdef DEBUG
- * Function Name : assert_failed
- * Description : Reports the name of the source file and the source line number
- * where the assert error has occurred.
- * Input : - file: pointer to the source file name
- * - line: assert error line source number
- * Output : None
- * Return : None
- void assert_failed(u8* file, u32 line)
- /* User can add his own implementation to report the file name and line number,
- ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* Infinite loop */
- while (1)
- #endif
- * Function Name : USART_Configuration
- * Description : Configures the USART1.
- * Input : None
- * Output : None
- * Return : None
- USART_InitTypeDef USART_InitStructure;
- USART_ClockInitTypeDef USART_ClockInitStructure;
- /* USART1 configuration ------------------------------------------------------*/
- /* USART1 configured as follow:
- - BaudRate = 115200 baud
- - Word Length = 8 Bits
- - One Stop Bit
- - No parity
- - Hardware flow control disabled (RTS and CTS signals)
- - Receive and transmit enabled
- - USART Clock disabled
- - USART CPOL: Clock is active low
- - USART CPHA: Data is captured on the middle
- - USART LastBit: The clock pulse of the last data bit is not output to
- the SCLK pin
- USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
- USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
- USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
- USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
- /* Configure the USART1 synchronous paramters */
- USART_ClockInit(USART1, &USART_ClockInitStructure);
- USART_InitStructure.USART_BaudRate = 115200;
- USART_InitStructure.USART_WordLength = USART_WordLength_8b;
- USART_InitStructure.USART_StopBits = USART_StopBits_1;
- USART_InitStructure.USART_Parity = USART_Parity_No ;
- USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
- USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
- /* Configure USART1 basic and asynchronous paramters */
- USART_Init(USART1, &USART_InitStructure);
- /* Enable USART1 */
- USART_Cmd(USART1, ENABLE);
- * Function Name : fputc
- * Description : Retargets the C library printf function to the USART or ITM Viewer.
- * Input : None
- * Output : None
- * Return : None
- #ifdef DBG_ITM
- /* 將Printf內(nèi)容發(fā)往ITM激勵寄存器端口 */
- if (DEMCR & TRCENA) {
- while (ITM_Port32(0) == 0);
- ITM_Port8(0) = ch;
- #else
- /* 將Printf內(nèi)容發(fā)往串口 */
- USART_SendData(USART1, (unsigned char) ch);
- while (!(USART1->SR & USART_FLAG_TXE));
- #endif
- return (ch);
- /******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
ADC_test.zip
(638.43 KB, 下載次數(shù): 23)
2018-10-15 15:01 上傳
下載積分: 黑幣 -5
