適用于市面上128x64OLED模塊,SPI模式
oled_spi.h 單片機(jī)源程序如下:
- /*OLED控制用函數(shù)
- void OLED_WR_Byte(u8 dat,u8 cmd);
- void OLED_Display_On(void);
- void OLED_Display_Off(void);
- void OLED_Init(void);
- void OLED_Clear(void);
- void OLED_DrawPoint(u8 x,u8 y,u8 t);
- void OLED_Fill(u8 x1,u8 y1,u8 x2,u8 y2,u8 dot);
- void OLED_ShowChar(u8 x,u8 y,u8 chr);
- void OLED_ShowNum(u8 x,u8 y,u32 num,u8 len,u8 size2);
- void OLED_ShowString(u8 x,u8 y, u8 *p);
- void OLED_Set_Pos(unsigned char x, unsigned char y);
- void OLED_ShowCHinese(u8 x,u8 y,u8 no);
- void OLED_DrawBMP(unsigned char x0, unsigned char y0,unsigned char x1, unsigned char y1,unsigned char BMP[]);
- #include "oledfont_spi.h"
- #ifndef __OLED_SPI_H_
- #define __OLED_SPI_H_
- #define u8 unsigned char
- #define u32 unsigned int
- #define OLED_CMD 0 //寫命令
- #define OLED_DATA 1 //寫數(shù)據(jù)
- #define OLED_MODE 0
- sbit OLED_CS=P4^4; //片選
- sbit OLED_RST =P4^2;//復(fù)位
- sbit OLED_DC =P4^3;//數(shù)據(jù)/命令控制
- sbit OLED_SCL=P4^0;//時(shí)鐘 D0(SCLK?
- sbit OLED_SDIN=P4^1;//D1(MOSI) 數(shù)據(jù)
- #define OLED_CS_Clr() OLED_CS=0
- #define OLED_CS_Set() OLED_CS=1
- #define OLED_RST_Clr() OLED_RST=0
- #define OLED_RST_Set() OLED_RST=1
- #define OLED_DC_Clr() OLED_DC=0
- #define OLED_DC_Set() OLED_DC=1
- #define OLED_SCLK_Clr() OLED_SCL=0
- #define OLED_SCLK_Set() OLED_SCL=1
- #define OLED_SDIN_Clr() OLED_SDIN=0
- #define OLED_SDIN_Set() OLED_SDIN=1;
- //OLED模式設(shè)置
- //0:4線串行模式
- //1:并行8080模式
- #define SIZE 16
- #define XLevelL 0x02
- #define XLevelH 0x10
- #define Max_Column 128
- #define Max_Row 64
- #define Brightness 0xFF
- #define X_WIDTH 128
- #define Y_WIDTH 64
- unsigned char screen_data_array[8][128];
- //-----------------OLED端口定義----------------
- void delay_oled_spi(unsigned int ms)
- unsigned int a;
- while(ms)
- a=1800;
- while(a--);
- ms--;
- return;
- #if OLED_MODE==1
- //向SSD1106寫入一個字節(jié)。
- //dat:要寫入的數(shù)據(jù)/命令
- //cmd:數(shù)據(jù)/命令標(biāo)志 0,表示命令;1,表示數(shù)據(jù);
- DATAOUT(dat);
- if(cmd)
- OLED_DC_Set();
- else
- OLED_DC_Clr();
- OLED_CS_Clr();
- OLED_WR_Clr();
- OLED_WR_Set();
- OLED_CS_Set();
- OLED_DC_Set();
- #else
- //向SSD1306寫入一個字節(jié)。
- u8 i;
- if(cmd)
- OLED_DC_Set();
- else
- OLED_DC_Clr();
- OLED_CS_Clr();
- for(i=0;i<8;i++)
- OLED_SCLK_Clr();
- if(dat&0x80)
- OLED_SDIN_Set();
- else
- OLED_SDIN_Clr();
- OLED_SCLK_Set();
- dat<<=1;
- OLED_CS_Set();
- OLED_DC_Set();
- #endif
- OLED_WR_Byte(0xb0+y,OLED_CMD);
- OLED_WR_Byte(((x&0xf0)>>4)|0x10,OLED_CMD);
- OLED_WR_Byte((x&0x0f)|0x01,OLED_CMD);
- //開啟OLED顯示
- OLED_WR_Byte(0X8D,OLED_CMD); //SET DCDC命令
- OLED_WR_Byte(0X14,OLED_CMD); //DCDC ON
- OLED_WR_Byte(0XAF,OLED_CMD); //DISPLAY ON
- //關(guān)閉OLED顯示
- OLED_WR_Byte(0X10,OLED_CMD); //DCDC OFF
- OLED_WR_Byte(0XAE,OLED_CMD); //DISPLAY OFF
- //清屏函數(shù),清完屏,整個屏幕是黑色的!和沒點(diǎn)亮一樣!!!
- u8 i,n;
- for(i=0;i<8;i++)
- OLED_WR_Byte (0xb0+i,OLED_CMD); //設(shè)置頁地址(0~7)
- OLED_WR_Byte (0x00,OLED_CMD); //設(shè)置顯示位置—列低地址
- OLED_WR_Byte (0x10,OLED_CMD); //設(shè)置顯示位置—列高地址
- for(n=0;n<128;n++)OLED_WR_Byte(0,OLED_DATA);
- } //更新顯示
- //在指定位置顯示一個字符,包括部分字符
- //x:0~127
- //y:0~63
- //mode:0,反白顯示;1,正常顯示
- //size:選擇字體 16/12
- unsigned char c=0,i=0;
- c=chr-' ';//得到偏移后的值
- if(x>Max_Column-1){x=0;y=y+2;}
- if(SIZE ==16)
- OLED_Set_Pos(x,y);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i],OLED_DATA);
- OLED_Set_Pos(x,y+1);
- for(i=0;i<8;i++)
- OLED_WR_Byte(F8X16[c*16+i+8],OLED_DATA);
- else {
- for(i=0;i<6;i++)
- OLED_WR_Byte(F6x8[c][i],OLED_DATA);
- //m^n函數(shù)
- u32 oled_pow(u8 m,u8 n)
- u32 result=1;
- while(n--)result*=m;
- return result;
- //顯示2個數(shù)字
- //x,y :起點(diǎn)坐標(biāo)
- //len :數(shù)字的位數(shù)
- //size:字體大小
- //mode:模式 0,填充模式;1,疊加模式
- //num:數(shù)值(0~4294967295);
- u8 t,temp;
- u8 enshow=0;
- for(t=0;t<len;t++)
- temp=(num/oled_pow(10,len-t-1))%10;
- if(enshow==0&&t<(len-1))
- if(temp==0)
- OLED_ShowChar(x+(size2/2)*t,y,' ');
- continue;
- }else enshow=1;
- OLED_ShowChar(x+(size2/2)*t,y,temp+'0');
- //顯示一個字符號串
- void OLED_ShowString(u8 x,u8 y,u8 *chr)
- unsigned char j=0;
- while (chr[j]!='\0')
- { OLED_ShowChar(x,y,chr[j]);
- x+=8;
- if(x>120){x=0;y+=2;}
- j++;
- //顯示漢字
- u8 t,adder=0;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no][t],OLED_DATA);
- adder+=1;
- for(t=0;t<16;t++)
- OLED_WR_Byte(Hzk[2*no+1][t],OLED_DATA);
- adder+=1;
- /***********功能描述:顯示顯示BMP圖片128×64起始點(diǎn)坐標(biāo)(x,y),x的范圍0~127,y為頁的范圍0~7*****************/
- unsigned int j=0;
- unsigned char x,y;
- if(y1%8==0) y=y1/8;
- else y=y1/8+1;
- for(y=y0;y<y1;y++)
- OLED_Set_Pos(x0,y);
- for(x=x0;x<x1;x++)
- OLED_WR_Byte(BMP[j++],OLED_DATA);
- void clearScreenData(){
- u8 i,n;
- for(i=0;i<8;i++)
- for(n=0;n<128;n++) screen_data_array[i][n]=0x00;
- void refresh_screen(){
- u8 i,n;
- for(i=0;i<8;i++)
- for(n=0;n<128;n++)OLED_WR_Byte(screen_data_array[i][n],OLED_DATA);
- } //更新顯示
- //初始化SSD1306
- OLED_RST_Set();
- delay_oled_spi(100);
- OLED_RST_Clr();
- OLED_RST_Set();
- OLED_WR_Byte(0xAE,OLED_CMD);//--turn off oled panel
- OLED_WR_Byte(0x00,OLED_CMD);//---set low column address
- OLED_WR_Byte(0x10,OLED_CMD);//---set high column address
- OLED_WR_Byte(0x40,OLED_CMD);//--set start line address Set Mapping RAM Display Start Line (0x00~0x3F)
- OLED_WR_Byte(0x81,OLED_CMD);//--set contrast control register
- OLED_WR_Byte(0xCF,OLED_CMD); // Set SEG Output Current Brightness
- OLED_WR_Byte(0xA1,OLED_CMD);//--Set SEG/Column Mapping 0xa0左右反置 0xa1正常
- OLED_WR_Byte(0xC8,OLED_CMD);//Set COM/Row Scan Direction 0xc0上下反置 0xc8正常
- OLED_WR_Byte(0xA6,OLED_CMD);//--set normal display
- OLED_WR_Byte(0xA8,OLED_CMD);//--set multiplex ratio(1 to 64)
- OLED_WR_Byte(0x3f,OLED_CMD);//--1/64 duty
- OLED_WR_Byte(0xD3,OLED_CMD);//-set display offset Shift Mapping RAM Counter (0x00~0x3F)
- OLED_WR_Byte(0x00,OLED_CMD);//-not offset
- OLED_WR_Byte(0xd5,OLED_CMD);//--set display clock divide ratio/oscillator frequency
- OLED_WR_Byte(0x80,OLED_CMD);//--set divide ratio, Set Clock as 100 Frames/Sec
- OLED_WR_Byte(0xD9,OLED_CMD);//--set pre-charge period
- OLED_WR_Byte(0xF1,OLED_CMD);//Set Pre-Charge as 15 Clocks & Discharge as 1 Clock
- OLED_WR_Byte(0xDA,OLED_CMD);//--set com pins hardware configuration
- OLED_WR_Byte(0x12,OLED_CMD);
- OLED_WR_Byte(0xDB,OLED_CMD);//--set vcomh
- OLED_WR_Byte(0x40,OLED_CMD);//Set VCOM Deselect Level
- OLED_WR_Byte(0x20,OLED_CMD);//-Set Page Addressing Mode (0x00/0x01/0x02)
- OLED_WR_Byte(0x02,OLED_CMD);//
- OLED_WR_Byte(0x8D,OLED_CMD);//--set Charge Pump enable/disable
- OLED_WR_Byte(0x14,OLED_CMD);//--set(0x10) disable
- OLED_WR_Byte(0xA4,OLED_CMD);// Disable Entire Display On (0xa4/0xa5)
- OLED_WR_Byte(0xA6,OLED_CMD);// Disable Inverse Display On (0xa6/a7)
- OLED_WR_Byte(0xAF,OLED_CMD);//--turn on oled panel
- OLED_WR_Byte(0xAF,OLED_CMD); /*display ON*/
- OLED_Clear();
- OLED_Set_Pos(0,0);
- #endif
oled_spi.zip
(2.99 KB, 下載次數(shù): 54)
2018-10-11 20:02 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
