查看: 2813|回復(fù): 1
三路循跡小車程序
ID:406145 發(fā)表于 2018-10-7 15:31 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit IN1 = P1^0;         //P20與電機驅(qū)動IN1相連
sbit IN2 = P1^1;         //P21與電機驅(qū)動IN2相連
sbit IN3 = P1^2;         //P22與電機驅(qū)動IN3相連
sbit IN4 = P1^3;         //P23與電機驅(qū)動IN4相連
       //P00左邊模塊
sbit D1 = P0^0;       //P01中間模塊
sbit D3 = P0^3;      //P02右邊模塊
sbit D6 = P0^6;
uint temp;
void left_zheng(void);
void left_fan(void);
void right_zheng(void);
void right_fan(void);
void ting(void);
void go(void);
void back(void);
void delayms(uint z);
void main(void)
// temp = P0&0xff;
if(D1 == 0 && D3 == 0 && D6 == 0)
  ting();
if(D1 == 0 && D3 == 0 && D6 == 1)
   left_zheng();
if(D1 == 0 && D3 == 1 && D6 == 0)
   go();
if(D1 == 0 && D3 == 1 && D6 == 1)
    left_zheng();
if(D1 == 1 && D3 == 0 && D6 == 0)
    right_zheng();
if(D1 == 1 && D3 == 0 && D6 == 1)
   go();
if(D1 == 1 && D3 == 1 && D6 == 0)
   right_zheng();
if(D1 == 1 && D3 == 1 && D6 == 1)
   ting();
/* switch(temp)
   case 0x00: ting();   break;
   case 0x01: right_zheng();  break;
   case 0x02: go();            break;
   case 0x03:  go();           break;
   case 0x04:  left_zheng();   break;
   case 0x05:  go();           break;
   case 0x06:  go();           break;
   case 0x07:  ting();        break;
   default:  break;
void left_zheng(void)     //IN1 = 1, IN2 = 0;反轉(zhuǎn)
{             //IN1 = 0, IN2 = 1;正轉(zhuǎn)
IN1 = 0;       //IN3 = 1, IN4 = 0;反轉(zhuǎn)
IN2 = 0;       //IN3 = 0, IN4 = 1;正轉(zhuǎn)
IN3 = 0;
IN4 = 1;
delayms(100);
void left_fan(void)
IN1 = 0;
IN2 = 0;
IN3 = 1;
IN4 = 0;
delayms(50);
IN1 = 0;
IN2 = 1;
IN3 = 0;        //IN1 = 0, IN2 = 0;制動
IN4 = 0;
delayms(100);       //IN1 = 1, IN2 = 1;制動
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 0;
delayms(50);
void go(void)
IN1 = 0;
IN2 = 1;
IN3 = 0;
IN4 = 1;
delayms(30);
void back(void)
IN1 = 1;
IN2 = 0;
IN3 = 1;
IN4 = 0;
delayms(50);
void ting(void)
IN1 = 0;
IN2 = 0;
IN3 = 0;
IN4 = 0;
delayms(50);
uint i,j;
for(i = 0; i < z; i++)
  for(j = 0; j < 110; j++);
ID:1 發(fā)表于 2018-10-7 17:03 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
