查看: 1343|回復: 0
實用的51單片機程序
ID:406037 發表于 2018-10-7 10:12 | 顯示全部樓層 |閱讀模式
分享一個 拉幕式數碼顯示技術程序和仿真電路圖源碼:
#include <REGX51.H>
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,
                               0x66,0x6d,0x7d,0x07,
                               0x7f,0x6f,0x77,0x7c,
                               0x39,0x5e,0x79,0x71,0x00};
/*unsigned char code dispcode[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xff};
unsigned char dispbitcode[]={0xf8,0xf9,0xfa,0xfb,
                             0xfc,0xfd,0xfe,0xff};
unsigned char dispbuf[8]={16,16,16,16,16,16,16,16};
unsigned char dispbitcnt;
unsigned int t02scnt;
unsigned char t5mscnt;
unsigned char u;
unsigned char i;
void main(void)
  TMOD=0x02;
  TH0=0x06;
  TL0=0x06;
  TR0=1;
  ET0=1;
  EA=1;
  while(1);
void t0(void) interrupt 1 using 0
  t5mscnt++;
  if(t5mscnt==4)
      t5mscnt=0;
      P3=dispcode[dispbuf[dispbitcnt]];
      P1=dispbitcode[dispbitcnt];
      dispbitcnt++;
      if(dispbitcnt==8)
          dispbitcnt=0;
  t02scnt++;
  if(t02scnt==1600)
      t02scnt=0;
      u++;
      if(u==9)
          u=0;
      for(i=0;i<8;i++)
          dispbuf[i]=16;
      for(i=0;i<u;i++)
          dispbuf[i]=i+1;
電路圖
電路圖
